New home for my battery
Re: New home for my battery
So what is your question? Installing a battery in the trunk is child's play you just need the have proper Positive and Negative cable length. You can use your hood or oem battery tray to hold it in the back seat and weld j hook homes. In all should take about 1-3 hrs.
not really worth it for the amount of cable you need to run. just leave the battery spot alone and get a smaller one. braille makes nice little mounts you can put anywhere.
Batteries give off hydrogen when they are charging, that's why all cars from the factory with trunk batteries have some sort of venting system/tube. You might want to look into that.
if you get a sealed agm, they do not give off any gases provided you charge it properly. the hydrogen is recycled internally.
Thanks for the feed back.
I'm not going to get a smaller battery, that's pretty homosexual. I'm cleaning out my engine bay. A/C is out and battery is next. I appreciate the comments though.
you can get full size or even better than stock agm sealed battery if you want to relocate inside the car.
jzhartman
22
Jul 23, 2015 10:42 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Jul 12, 2015 11:54 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
