power lock switch not working!!
Old May 26, 2013
hootaz's Avatar
99 honda civic
hootaz is an unknown quantity at this point
Cool power lock switch not working!!
I currently just purchased a 99 civic with power locks but it don't work. I checked fuse but that was o.k. Any other ideas what I should look for?
Old May 26, 2013
Re: power lock switch not working!!
but it don't work
Is "it" plugged in?
Old May 29, 2013
hootaz's Avatar
99 honda civic
not sure where should I check? behind the door panel?
Old May 29, 2013
Is there a power lock button next to the door handle? I'd start there, take the handle out and see if that switch is still plugged in. Then I'd use a volt/ohm meter to check the wiring. Then check for broken wires in the door jamb.
Do you have a remote? Does it work?
Old May 31, 2013
nsxvtec's Avatar
nsxvtec will become famous soon enough
probably the door lock actuators are dead.
The small motors in the DLA rust and seize up or burns out.
Happens often.
roverben
Jan 21, 2019 05:16 PM
MamaBear2015
May 3, 2015 02:17 PM
ORskier
May 3, 2015 12:54 PM
ademarco6
Exterior
Nov 15, 2001 09:36 PM
JDock
Nov 9, 2001 08:53 AM
