power lock switch not working!!
Re: power lock switch not working!!
Is there a power lock button next to the door handle? I'd start there, take the handle out and see if that switch is still plugged in. Then I'd use a volt/ohm meter to check the wiring. Then check for broken wires in the door jamb.
Do you have a remote? Does it work?
MamaBear2015
May 3, 2015 02:17 PM
ORskier
May 3, 2015 12:54 PM
