Ek Civic coupe, chopped wiring issues
Old Nov 3, 2017
Hondaguyej8's Avatar
Hondaguyej8 has a spectacular aura aboutHondaguyej8 has a spectacular aura about
So.... I have a 98 ek auto coupe. Wire bundle passes through firewall on driver's side. Some branch off onto engine harness. The wires in question pass between driver's strut tower and engine and head under cruise control unit. I need help figuring out what the following wires go to....
Red w/green
Red w/blue
Red w/yellow
Red w/white
Wires come from blue plug as pictured.
For some reason they have been cut into and twisted back together. Car runs like crap, assuming it has to do with these wires....
My personal un-molested, just for reference
Old Nov 3, 2017
Colin42's Avatar
Re: Ek Civic coupe, chopped wiring issues
If the colours match, just try splicing them properly and see if that helps?
Can you follow the wires to see where they go to?
Edit: If you can download the factory service manual that has all the connectors and wire colours, it would be a huge help to you
Old Nov 3, 2017
I've traced them as far as I can without removing components, ie: Cruse control, power steering reservoir, etc. Proper repair will be happening tonight, I have to splice wire in to give me the length I need to route them properly.
Just hoping a Honda guru would know what the blue plug drives.
Thanks for the speedy reply though
Old Nov 3, 2017
Colin42's Avatar
If I had my girlfriend's car at work with me I'd go look for you.
I posted a link to download a manual here:
https://www.civicforums.com/forums/1...pdated-13.html
not sure if the download link is still working. You would have to look through to find the connector.
Old Nov 3, 2017
Thanks for the link. I'll just have to search the PDF. It would seem that multiple plugs have red w/stripe wires but with your input I'm sure I can figure it out. I mean it was a $300 car
Screenshot, so that play button doesn't work
Old Nov 3, 2017
Colin42's Avatar
oh no! not marrettes! best of luck
