PDA
View Full Version : Suspension
  1. Rear lower control arm recommendations for 98 Civic DX Hatchback
  2. anyone know how much a front suspension kit goes for?
  3. What is your preferred brand of inner and outer tie rods?
  4. control arm subframe mount bent
  5. 1998 Civic Suspension Issue Help
  6. Lower ball joint angle capacity
  7. Parts interchange [solved]
  8. Suspension interchange?
  9. Steering feels weird (too light and free)
  10. 98 EK thumping please help [solved]
  11. Looking For Bolts [solved]
  12. Need help with suspension Honda Civic 2000
  13. Suspension torque specs
  14. Wandering steering STILL!! [solved]
  15. Power Steering and suspension kit for 98 civic 4 doors manual
  16. Shock/strut mount plate...help...2000 hatch
  17. Wheel bearing size?
  18. Power steering hose
  19. Steering Play after new rack install
  20. Rear suspension
  21. 1998 civic power steering leak
  22. What nut goes to this bolt?
  23. Rear wheel negative camber
  24. Broken rear driver side lower control arm/brake fluid leaking / brakes not Workin l.
  25. Strut Recommendations?
  26. Lower control arms help
  27. Help! lengths of inner tie rods
  28. Rusted subframe. Trusted mechanics Aurora IL?
  29. 1998 Civic LX front ride height
  30. steering wheel movement
  31. 2000 Honda Civic Ex, B Swapped
  32. 98 civic rusted sway bar mounts
  33. converting to manual steering rack and pinion
  34. Loud, constant, percussive popping/grinding from front suspension. CV axle? [video]
  35. 99 RR suspension issue!!
  36. Replacing suspension front and rear question...
  37. Tie rods and related components
  38. Experiment
  39. Steering Boot - 2000 Civic EX
  40. How Screwed?
  41. Bent
  42. Wrong struts???
  43. Front suspension sitting high
  44. caster LF 4.25 RF 3.50 Potential issue? CC kit fix?
  45. 2000 honda civic steering clunk
  46. Has any si 99 civic owner had this problem?
  47. Creaking/Squeaking from stock front end
  48. Can I use 185/70R14s on my '96 Civic DX 4 door sedan?
