Lower control arms help
Old Aug 1, 2021
Califmike33's Avatar
Califmike33 is an unknown quantity at this point
Installing rear LCA on my 98 civic, do i need to grease the bushings before i put them on the car ? Thanks for any replies.
Old Aug 1, 2021
Colin42's Avatar
Re: Lower control arms help
Probably a good idea
Old Aug 1, 2021
Do I need to pop the whole bushing out of the lower control arm and grease it or just put grease inside the metal bushing?
Old Aug 1, 2021
Colin42's Avatar
If it comes pre-installed don't worry about it
Old Aug 1, 2021
Thanks again. I have one more question, there are 3 bolts on each rear LCA, if mine broke off. I ordered new bolts and they came with nuts, but i only remember there being a nut on the strut mount bolt not the the other 2, is there a fixed nut on the car ? Cant find a good diagram of the 98 civic rear suspension to see if those bolts take nuts.
Old Aug 2, 2021
tj4fa's Avatar
tj4fa is an unknown quantity at this point
Agree
Old Aug 2, 2021
tj4fa's Avatar
Go here - enter your vehicle information and you can see a parts breakdown.
I entered some info but don't know what model your car is...
https://www.hondapartsnow.com/parts-...lower_arm.html
Old Aug 2, 2021
98 Honda Civic sedan LX I will go there and check it thank you for the link.
Appreciate the link I went on there and found out only the bolt that actually goes through the strut through the lower control arm has a nut the other two on the lower control arm are built into the car already so I'm wondering the new bolt I bought why did they come with nuts? And are the threads going to match to be able to screw into that word already has a built-in net already attached to the car I guess I'll find out today.
Old Aug 2, 2021
tj4fa's Avatar
My guess is those two extra nuts will probably replace the old nuts for those two studs built into the car.
Old Aug 2, 2021
You're right the guy that sold me the new bolt kit that comes with the nuts he said we give you nuts because a lot of times all those nuts are rusted and the bolts are frozen and they break he said don't be afraid to cut the nuts off to get the arm off and then you can just replace the nuts with the ones we gave you.
dwils
Sep 7, 2010 08:09 PM
em2allday
Nov 26, 2008 10:58 PM
crazea03
Nov 21, 2005 08:56 AM
wildkingdom007
Aug 2, 2004 07:48 AM
