Strut Recommendations?
Old Aug 25, 2021
DIYfan's Avatar
DIYfan is a jewel in the roughDIYfan is a jewel in the roughDIYfan is a jewel in the rough
I am planning to replace all 4 struts on my Son's 2000 EX. I prefer strut and spring assemblies and want to avoid messing with the springs. The car has 166k miles and the original factory struts. It rides pretty mushy. I have read a lot of reviews which state aftermarket struts work fine but it increased the ride height and their car now looks like a 4x4. Can anyone recommend good quality struts with normal ride height? Apparently the Honda OEM Front Left unit is available but not the Right.
Old Aug 25, 2021
Re: Strut Recommendations?
takes some time to settle springs.
couple weeks maybe.
have you tightened suspension with no load? Sometimes bushings get seized. Put tires on ramps, get under there and loosen/tighten suspension again.
if you assembled the shock/spring, check if the springs are seated correctly.
Old Aug 25, 2021
Colin42's Avatar
Kyb no issues on my '00 coupe
Uscman84
Suspension
Apr 11, 2021 01:17 PM
anguseg
General 7th Gen
Mar 29, 2019 03:04 PM
newyota
Jun 29, 2011 06:27 PM
brill
May 1, 2005 01:55 PM
RacerX
May 8, 2002 06:17 PM
