Suspension torque specs
Old Jul 10, 2022
Maqcro's Avatar
Maqcro is an unknown quantity at this point
Looking for some torque numbers for basically all suspension front and rear
I’m replacing
front:
upper control arm
lower control arm
lower ball joint
cv axle
wheel bearing
tie rod end
rack and pinion
struts/shock
sway bar links
rear:
shock/strut
compensator arm
trailing arm bushing
upper control arm
lower control arm
Thanks 🙏
Old Jul 10, 2022
Re: Suspension torque specs
https://www.civicforums.com/forums/2...hase-them.html
https://www.civicforums.com/forums/2...en-manual.html
mrohitredd
Jan 19, 2014 10:23 PM
CivicVoz
Jul 6, 2012 02:43 PM
sloth
Dec 20, 2011 04:45 PM
AznSaint
May 18, 2006 08:37 AM
ZSKCivic01
Jan 18, 2005 07:22 PM
