Rate My Suspension Rebuild!
Old Jun 19, 2012
CivicVoz's Avatar
CivicVoz is an unknown quantity at this point
2002 Honda Civic EX - 100,000miles
Stabilizer Bar Links (front and rear) were recently replaced by warranty.
_______________________________________
Shocks/Springs
Tokico Spring/Shock Kit - HPK (TOHPK307)
(http://thmotorsports.com/tokico/toki.../i-526775.aspx)
Tie Rod Ends
MOOG#EV469
MOOG#ES3581
Ball Joints
MOOG#K90332
Front Control Arms (Less work then trying to press out the bushing)
DORMAN#520925
DORMAN#520926
Should I also replace the Strut Mounts and Rear Upper Control Arms?
Anything I missed?
Thanks for any input!
Old Jun 24, 2012
Re: Rate My Suspension Rebuild!
good except the control arms. just get the energy suspension bushings and have it pressed out (not that expensive, and they are lifetime bushings). why replacing ball joints and tie rods? are they bad?
Old Jun 26, 2012
CivicVoz's Avatar
Thanks for the reply!
Since the car has over 100,000miles and I'm already replacing the shocks/springs, I might as well replace the ball joints and tie rods..
I was thinking about just getting the bushing's from energy suspension but I heard they make sounds in the winter and being in central Canada winters last a looonng time. Also the local shops want 50-60bucks just to push out the bushing.
Should I replace the Strut Mounts?
Old Jun 26, 2012
probably yes. i didnt and mine make popping sounds. ofcourse thats 100k old top mounts. if you dont like noise, just stick with oem rubber bushings. but dorman is a pretty terrible brand, esp for critical parts like control arms.
Old Jun 29, 2012
CivicVoz's Avatar
Any good place online to buy OEM control arm rubber bushings and strut mounts?
Old Jun 29, 2012
CivicVoz's Avatar
What do you think about the list below?
Strut Bellows (Is it recommended to replace?)
MOOG Part # K90462 Incl. Bumper - Front
MOOG Part # K90467 Incl. Bumper - Rear
Strut Mounts
MOOG Part # K90648 Incl. Bearing - Front Upper
Stabilizer Bar Links (Second pair for when the stock ones go)
MOOG Part # K90455
If I did go with the Energy Suspension bushings, should I get the Front Control Arm Bushings (#16.3116) or just spend extra and get the whole kit (#PackageDeal002) (http://www.energysuspensionparts.com...PackageDeal002)
Am I missing anything?
thanks for the input
Old Jul 2, 2012
EM202's Avatar
EM202 is an unknown quantity at this point
You should only need to do these if they look bad
MOOG Part # K90455
The moog end links are thicker than the stock ones and should last longer
This is your choice, it would probably be a good idea to replace them all at once, esp if the fronts are bad, mine were when I got my car at 107k miles, and the kit makes it a bit cheaper
Old Jul 3, 2012
spartakus's Avatar
spartakus is an unknown quantity at this point
I'm changing my suspension bushings too, the car is at 145k km now and judging by the noises coming from the suspension I'm guessing even the arm and stabilizers bushings are bad. What are the cons of the polyurethane ones? I hear they are a lot harder than the oem's, and since my shock springs are modified(cut 2 turns) I guess those wouldn't be a good choice for me. Am I right?
Old Jul 3, 2012
i couldnt tell any ride comfort difference going from oem to poly for lca bushings. all they do is make more noise in the winter but only going over slanted driveways or taking a turn fast. driving normally on a paved road there is no sound. in the summer they are completely quiet in all conditions. with the poly, the car is more stable when cornering at high speeds because the alignment settings are held better. poly is also a lifetime part whereas oem maybe lasts 60k miles or less.
Old Jul 3, 2012
EM202's Avatar
Shocks and springs are gonna be the biggest thing that you would notice ride comfort change on, most everything else should be minimal. Even if you did notice ride comfort change a little bit, it should return back to normal in a few days/weeks when they settle and all that. Ive never really noticed any noises with my ES LCA bushings, only when the old ones I replaced were ripped apart into a few pieces it popped. I also want to think when I was looking prices for oem (advance etc) to the ES the ES ones were cheaper
Old Jul 3, 2012
spartakus's Avatar
You guys say that because you drive in the most plain flat streets in the world... But believe me, here in Brazil every single bushing plays a big role on minimizing noises. The roads are just ridiculously uneven and we have big *** speed bumps on almost every corner.
That's what concerns me the most... Otherwise I'd have already gotten one of those. But I'm still going to test it someday.
Old Jul 4, 2012
all the more reason to get poly bushings. those roads will tear up oem rubber parts and throw off the alignment, which will cause more tire wear (with more noise) and poor steering performance. that reminds me, softer compound tires can also greatly affect the ride comfort. even with a pretty stiff suspension setup, i am riding cushy with general altimax hp tires. they are almost broken in at 3k miles and finally starting to really perform in turns. ive had cheaper tires before and it felt like i was riding on metal lol. i run the new tires at 35psi too and they are still way softer than the old tires (junk fuzions) at 30psi. it feels like a different car.
Old Jul 5, 2012
EM202's Avatar
meh.... assumptions....love it when people do this and are completely wrong....I currently live on a farm in the midwest of the states, drive on plenty of gravel roads which are anything but flat, drive on a ton of county roads that hardly ever get taken care of (my work is in the middle of nowhere). Especially after the snow plows tear the crap out of them. At least when I move here in a few weeks, it will be a little better. My suspension was bad before I got this car, now it is completely horrible in bout 9 months time...I will soon be replacing shocks and springs, but have already had to replace bushings. Never noticed any noises or other issues with the energy suspension set, but the OEM were just horible for where I drive. Like gear said, oem won't last long in the crappy roads like the poly set would, the poly ones are way more durable.
Old Jul 5, 2012
spartakus's Avatar
Alright you guys have convinced me to get one of those!! I just hope I don't get the 60% taxes this stupid brazilian customs randomly applies over imported products.
And I'm sorry about my assumption, I should have considered situations like yours before actually saying.. Don't take me wrong, I just meant it in a general way
Thanks for your help guys!
Old Jul 6, 2012
EM202's Avatar
glad to hear, and taxes just suck
We all do it from time to time, meant or not
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
thatcham
Sep 30, 2015 08:28 AM
Whitexj
Sep 30, 2015 02:04 AM
Tedverseti
Sep 29, 2015 05:41 PM
