98 EK thumping please help [solved]
Old Sep 5, 2022
Jbrown999's Avatar
Ek_Driven
Jbrown999 is an unknown quantity at this point
Exclamation 98 EK thumping please help [solved]
Hello everyone I recently replaced my cv axel seals and then started getting a thumping when driving.
Last time this happened to me it was loose lug nuts, not the case this time
I do have a torn cc boot I keep it greased the best I can until I can get a new axel.
It's constant thumping time between never changes with speed not to much though
I can't hear it in 3rd gear and up because of road and exhaust.
Top Answer
Sep 21, 2022
Colin42's Avatar
Colin42
re: 98 EK thumping please help [solved]
Aftermarket axle? Probably the wrong length
Old Sep 8, 2022
Wankenstein's Avatar
Are you sure the inner cv axle is all the way in? Did you hear a clicking sound when you installed them?
Are the new seals leaking?
Old Sep 21, 2022
Jbrown999's Avatar
Ek_Driven
You know it was leaking from seals got a new axel I looked and I need to go in another 1/4 inch but I can't get it to slide in any further
Old Sep 21, 2022
Colin42's Avatar
Old Sep 22, 2022
Jbrown999's Avatar
Ek_Driven
That was it the shaft that slides into the manual transmission was a bit longer. Length from boot to boot is same. I bought it online autozone then picked it up at store I didn't realize It's actually an ek it Asks before purchase I didn't know if it was or not. Is there really that big of a difference. Like 10mm difference.
Old Sep 23, 2022
BrotatoChip's Avatar
Super Moderator
Re: 98 EK thumping please help [solved]
What vehicle info did you enter into Autozone's website when ordering the axle and what is your actual car? The part details usually give specs, might tell you if one is supposed to be longer.
DMTgen7
Jul 21, 2009 04:38 PM
brodienuchies
Jul 25, 2005 10:51 AM
streetglower
Mar 16, 2004 11:27 PM
greeot
Dec 10, 2003 09:18 AM
Hiwind
Nov 11, 2002 02:38 PM
