Wheel bearing size?
Old Apr 12, 2022
argentargle's Avatar
argentargle is an unknown quantity at this point
Wheel bearing size?
Hey guys. Recently picked up a new steering knuckle for my swap, but stupidly didn't grab the trim level or check for abs... Its out of a '99 4 door. My questions are, is there a way to check the bearing size from the code on the knuckle? Or is my best bet going to be pressing out the bearing and measuring? If so is there a good resource for matching bearing size to honda part numbers? Thanks
"HM-6", or "HM-8", cant tell, "SOR-13"
Old Apr 12, 2022
Re: Wheel bearing size?
if it's out of a 99, search for the bearing for the car you removed it from
Old Apr 12, 2022
I have, however the sizes change based on trim level and abs equipment, as far as I know
Old Apr 12, 2022
Colin42's Avatar
Think your SOL.
Buy both and return what you don't need, or press out the old bearing and look for a part number on the bearing
Old Apr 12, 2022
Originally Posted by Colin42
Think your SOL.
I didn't realize the part number would be on the bearing, I will try that when I get my press in a few days, thanks.
JacobRhea
Suspension
Feb 18, 2025 06:09 AM
Starsd
Jul 3, 2017 11:07 AM
whiteformula98
Oct 25, 2015 07:00 PM
lobomic
May 8, 2008 01:23 AM
maxquebec
Jun 11, 2006 04:14 PM
