What nut goes to this bolt?
Old Nov 29, 2021
andis28's Avatar
andis28 is an unknown quantity at this point
Hey, I was putting new coilovers on my 1998 Civic EX and ran into some trouble with stuck bolts. I ended up cutting off one of the rear arm bolts that has a nut welded on to the strut. Could anybody give me a link to where I can buy the correct size nut for the bolt pictured? I couldn’t find anything at Home Depot.
Old Nov 29, 2021
Re: What nut goes to this bolt?
what's the part number on that honda bag in the background? That will at least let us look up the actual thread OD by looking up the part number
Purely based off the diameter and your finger being a frame of reference, prolly M10x1.5? Maybe M12x1.5? idk, I don't have the biggest hands, so I'm naturally assuming your pinky is the width of my middle finger.
here's my math for my best guess, using a digital caliper as closely as I could without scratching my monitor:
the middle section of your pinky finger on my screen: 24mm
the outer diameter of the threads on my screen: 17mm
this makes the thread OD 70% of your finger.
My middle finger middle section: about 16.5mm
so.. 70% of that is 11.68mm. M12 is the closest. The x1.5 thread pitch is a pure shot in the dark, but it is the most common thread pitch for M12 bolts on a Honda.
Old Nov 29, 2021
andis28's Avatar
Thanks for the quick response! The number on the bag says “90173-SR3-003” does that help?
Old Nov 29, 2021
Damn, your fingers in the pic looked much bigger than mine. Using that 70% ratio on my middle finger, I got like 9.84mm or something close to that for the thread OD. That part number tells me it's a m10 bolt with an 80mm length. Not 100% on the thread pitch, but I'd be willing to bet it's m10x1.5. if you wanna do a quick check, pull off a single lug nut and see if it threads in properly. If it does, it's for sure m10x1.5
Old Nov 29, 2021
Another search told me M10x1.25.. Definitely do the lug nut check. If it threads on easily, then 1.5 thread pitch. If it doesn't, likely 1.25
Old Nov 30, 2021
andis28's Avatar
So I tested it on one of my lug nuts and the bolt went straight in without any threading, does that mean I need smaller than 10 mm? I am not sure.
Old Nov 30, 2021
i am afraid he means nut, not lug nut...
go with the M10 and search on a hardware store
Old Nov 30, 2021
oh wait... I'm dumb. Lug nuts are m12x1.5. My fault. @sdaidoji I was saying to use a known thread pitch to test what actual thread pitch on the bolt is.
Do you have a MT? The shift **** should be m10x1.5
Old Nov 30, 2021
BrotatoChip's Avatar
Super Moderator
Even if the bolt is smaller than a wheel stud you can still compare the thread pitch. If the thread spacing on your bolt matches the wheel stud then it is 1.5 mm.
A set of digital calipers or a very accurate metric ruler/tape would make quick work of this. First measure how wide the stud part of the bolt is (this is the M10 part, 10 mm is our guess), then measure the distance between two threads (1.5 is in mm, 1.25 mm would be the next guess).
A_cortes
Jun 12, 2021 11:14 PM
old97civic
Jul 9, 2015 12:19 PM
chiphum
Dec 18, 2011 09:41 PM
SITNLOW97
Sep 8, 2007 06:48 PM
ZSKCivic01
May 28, 2004 11:29 PM
