Weld Nut for Rear Strut Broke
So the weld nut on the lower trailing arm on my 03 civic came loose when I used my impact wrench to get the stuck bolt off. Anybody else have this issue? I'm cutting the bolt off because I can't get the nut off now that it just spins w/ the bolt and vise grips don't work. I plan to try in just put another regular nut and new on bolt when I get new struts in. Doesn't look like weld nut was weld for structural support only to make it easier for assembly at the factory.
Re: Weld Nut for Rear Strut Broke
I looked at the thinnest vise grip i could and after swearing a lot i could get them off.
see it here - the nut is unnervingly... smooth round... no hex...
https://www.civicforums.com/forums/4...-take-out.html
Live for the Twisties
Naw, this is common on all cars regardless of the climate.
Bolts will always seize to some degree after a few years, this design is just a pain to deal with when they seize, despite numerous manufacturers using it.
Got a new arm and put the car back together. Got an alignment and camber is off a little but you can't adjust it on these cars so I figure if it needed to be adjusted Honda would have supplied a method. I'm not a tuner so no big deal. Strut job ~$400. Broke even on this job?
old97civic
Jul 9, 2015 12:19 PM
Causemo
Jul 4, 2015 07:11 AM
