Full Review on Hayame Coilovers
Old Mar 16, 2004
  #511
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
And the other one:
Name:	rear coilover - smaller.jpg
Old Mar 16, 2004
  #512
More Numbers:
Name:	rear numbers - smaller.jpg
Old Mar 16, 2004
  #513
civic01vtec's Avatar
it looks like u got the right ones and slammed got the wrong rears..........where did u order them from ?
Old Mar 16, 2004
  #514
Grey's Avatar
DIY King
Oo. Not good. I hope all of these issues get resolved soon. I had my mind set on the Hayame's, but I need to be sure that I get the ones I want!
Old Mar 16, 2004
  #515
tripledoublegs's Avatar
Euro-Spec
Originally posted by SlammedBlueEM2
Ready to see how low my Hayame's will go in the rear? THIS low!
Right...
How much preload did you put on them??
Old Mar 16, 2004
  #516
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
VNlilMAN: how long have you had your coilovers on?
I had my Hayames set to a lower point than yours, and my car was still higher than in your pics! So maybe 0530.2.50.008 has the same problem? My case isnt as bad as SlammedBlue, but it still did not drop as much as I believed it would.
how heavy is your sub box?
I have this problem with a 50+ pound sub box.. without it my car might rest at the same height as SlammedBlue. btw, change your nick to SlightlyLowerThanStockBlueEM2
btw, mine were purchased through Dezod
Old Mar 16, 2004
  #517
I ordered from Urban Import, No problem. Arrived on Thursday, so these are the correct ones:
0700.2.50.008 & 0530.2.50.010 ???
Old Mar 16, 2004
  #518
VNlilMAN's Avatar
The Standard One
I had them on for about 2 months now. The subs dont weigh that much, probably under 50. they're only 2 10" comps.
Are you saying your perch was set lower or the whole strut was set lower? cause right now the struts are as low as it can go. what size tires were you runnin again 215-45-17?
Old Mar 16, 2004
  #519
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
damn im about to order a set of hayames... what spring numbers do i want? i want to make sure they are the right ones before they ship them to me..
Old Mar 17, 2004
  #520
SlammedBlueEM2's Avatar
All Eyes On Z
That's not even an inch of preload. But even with the preload being on it's softest setting it'd still be the same.
Old Mar 17, 2004
  #521
All Eyes On Z
The ones that are NOT mine. They start with 4 #s instead of 2.
I wanna install mine on an RSX and see the results.
Old Mar 17, 2004
  #522
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
this is kinda confuseing, so which is the right part # for the front and rear spring?
Old Mar 17, 2004
  #523
All Eyes On Z
We don't know yet. We are waiting for UrbanImport to tell us that.
Old Mar 17, 2004
  #524
Mex's Avatar
Mex
in the photo's I've posted, my strut's height was dropped ALL the way. I had them set to the lowest point before I even put them on the car. so take a look at my photos again, and look at my height.
I need to make this clear, NEITHER OF THE REAR SPRING NUMBERS WILL GIVE YOU THE DESIRED RESULTS, only if you're planning on tucking the rear tire.
with my sub box out, I would be at the same height as SlammedBlue
Old Mar 17, 2004
  #525
All Eyes On Z
I don't want to tuck the rear at all. At the least, I just want a 1/2 inch gap when I have a 1/2 from stock drop in the rear. If I can't get that then Hayame has disappointed me. Nothing against UrbanImport at all, he's been doin what he can.
Old Mar 17, 2004
  #526
VNlilMAN's Avatar
The Standard One
At any rate, I said before that these springs take a long time to settle and now, I have a small finger gap in the rear. The car just seemed to get lower and lower all around, which ended up being a bad thing. Now I'm too low.
I'm going to raise the FRONT (sorry, edit) a bit and give the rear more preload since it's quite soft. The rear could also use some negative camber since I seem to have the rear tire hitting the wheel well. I didn't have that issue before my accident. I got a shitty alignment.
comparing to your newer pics, did it get that high because you put more preload? maybe you have more preload than i?
Old Mar 17, 2004
  #527
All Eyes On Z
That pic was having the spring lowered on the perch with no preload. It was absolutely loose when the car was raised and the shocks would bottom out at THAT height. Keep in mind, I did not lower it like that, I had a shop do it. They said I couldn't go any lower because the spring was compressed. Well, WTF... it's supposed to be compressed at the LEAST!
Old Mar 18, 2004
  #528
Unleaded's Avatar
Unleaded is an unknown quantity at this point
any news from hayame or the vendors regarding the rear spring in questioned? my alignment is whack and i need to know if there is a fix to the problem before i get the car aligned.
Old Mar 18, 2004
  #529
All Eyes On Z
He will post here, patience.
Old Mar 18, 2004
  #530
jaydub's Avatar
jaydub is an unknown quantity at this point
I know it's sort of unrelated, but many of us with EP3's were curious about the fitment, and it turns out that the EM2 and EP3 have different upper mounts, and since these come with new upper mounts, they won't work on the EP3.
Ah well.
Old Mar 18, 2004
  #531
UrbanImport's Avatar
UrbanImport is an unknown quantity at this point
OK talked to Hayame this morning. They are trying to get ahold of the factory to see which is the correct part # for the rear as they don't have any instock to cross reference. As soon as they find out what the correct part # is they are ordering a bunch of them so we can take care of any people who might have received the incorrect rears. On behalf of Hayame I apologize for the trouble this has caused.
Old Mar 18, 2004
  #532
jaydub's Avatar
If you have a chance to talk to them again, ask them if there would be a way of offering some EP3 coilovers. If the upper mounts from the RSX are the same as those from the EP3, then I can't see why Hayame couldn't piece a kit together out of existing parts.
Old Mar 18, 2004
  #533
VNlilMAN's Avatar
The Standard One
jaydub, sent you a PM
Old Mar 18, 2004
  #534
jaydub's Avatar
got your PM. I believe I should clarify that we believe that the upper mounts are different, but there is some things that don't make sense.
For example, people with EM2's are using the JIC magics which are for the EP3. If that is true, then they should work the other way too (except for the diameter of the camber bolts, which is a known issue).
Old Mar 18, 2004
  #535
Euro-Spec
19780 views....
Daaaamnn
almost as much as the "official suspension drop pictures"...and that one's sticky!!!
Old Mar 19, 2004
  #536
prccivic's Avatar
19780 views....
Daaaamnn
ya, i just noticed that too....i have viewed this thread about 200 times...
Old Mar 19, 2004
  #537
Yoyoio's Avatar
i check this thread about 20 times a day. lol
Old Mar 19, 2004
  #538
All Eyes On Z
This is the only thread I have subscribed to.
Old Mar 19, 2004
  #539
Yoyoio's Avatar
hahaha
so are you sending your rear coilover in and getting it replace?
Old Mar 19, 2004
  #540
Big Baller L's Avatar
Nugget Garage Since 2004
yah whats the deal with these messed up springs and everything? Ive been trying to read the pages but i got a headache trying to get all the info!!! I know u guys are still trying to figure it out, but the basic is that some srpings were reversed for rsx springs?
Also does anyone know if these coilovers are full stainless?
Thanks alot.
