View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
Old May 16, 2018
  #1621
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
OBD port and wiring melted
Long story short, my Scanguage went up in smoke. The company replaced the Scanguage, but now my OBD port is melted. I figured no big deal, I’ll just cut it off and put a new plug on. But it’s not that simple. I realized that the wiring for the port is melted as far into the harness as I can see. Not sure how that happened. I thought it was protected by a fuse. So I am going to need to replace all the wiring from the port to wherever the port goes to. So my question is what I do about this. Do all the wires just go right to the PCM? Does anyone have a wiring diagram for the OBD port? Thanks.
Old May 16, 2018
  #1622
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Re: OBD port and wiring melted
i can provide a wiring diagram from our shop computer if you provide year make model trim etc or i can look by vin
Old May 16, 2018
  #1623
That would be awesome. It's a 2005 Honda Civic LX sedan auto. Thanks for your help!
Old May 16, 2018
  #1624
GolNat's Avatar
Prelude Owner
Re: Can I use a JDM PCM?
[left]I bought a JDM PCM on Ebay for $15,
Didn't you buy like a $30 alternator from eBay that was crap?
Going rate for a PCM is over $50 so...
Old May 16, 2018
  #1625
huh...
does this somehow relates to your PCM issues, including not programming for key?
Old May 16, 2018
  #1626
RobertD's Avatar
the last one is the diagram you asked for. the first six are the troubleshooting steps for no communication. should keep you busy a while
Old May 16, 2018
  #1627
RobertD's Avatar
obd connector is called "DLC" or data link connector, just FYI (i didn't know)
Old May 16, 2018
  #1628
The alternator isn't crap. I had it tested, and everything was good. The first one was damaged in shipping, but the seller sent me another one.
Old May 16, 2018
  #1629
Originally Posted by sdaidoji
huh...
No. The PCM issues started over a year ago.
Old May 16, 2018
  #1630
Attachment 112214
Attachment 112215
Attachment 112216
Attachment 112217
Attachment 112218
Attachment 112219
Attachment 112220
Thank you so much. I guess I'll get on rewiring the port.
Old May 17, 2018
  #1631
How can I start my car with a replacement PCM?
So now my PCM is randomly activating the rev limiter while I’m driving. This is obviously annoying, but also dangerous since the car randomly won’t accelerate for no reason. So my question is how I can start the car with my replacement PCM temporarily until I can get it flashed. Will the immobilizer brake code start it with a replacement PCM, or is there something else I need to do? Thanks.
Old May 17, 2018
  #1632
Re: How can I start my car with a replacement PCM?
it won't
Old May 17, 2018
  #1633
it won't
Actually, I put my new JDM PCM in, and it started after I jumped the fuel pump relay. But it's far from perfect, as you will see in an update to that thread.
Old May 17, 2018
  #1634
Maaaaybe Hotwire that-- temporarily just so it will drive to get it programmed? (BUT IT'S UNSAFE AF)
Wait....Is this the same car that melted the data link wiring? That might really complicate things
Old May 17, 2018
  #1635
Yea... I have no idea how this worked either lol.
Old May 17, 2018
  #1636
Info about installing a JDM PCM in a USDM car
So I spent $15 on a JDM PCM, part number 37820-PSA-J83, and I don't regret it. I plugged it in and turned the key, but I was sure it wouldn't start since the green key light was flashing. But to my amazement, it started! I was shocked! I literally have no idea how it started. But then it died about 5 seconds later... I could tell by the way that it died that it ran out of fuel. So I manually powered the fuel pump, and it started right up and ran! I drove it down the street and back, and it ran perfect! I scanned it for codes, and it has a P1713, as well as a P0135, and P1253 because I didn't hook up VTEC yet. Those are the only codes it didn't have before though. I am still not sure about why it's setting a P1713 or P0135, but I will definitely report back when I have more information!
UPDATE: I hooked up the VTEC system correctly, and now the only unresolved codes I have is P0135, as well as P1713 if I put the shifter in 2. Not sure about those codes, I'll have to investigate further.
Old May 17, 2018
  #1637
More info: https://www.civicforums.com/forums/1...ml#post4745302
Old May 17, 2018
  #1638
Re: Info about installing a JDM PCM in a USDM car
Here's a picture of both PCMs side by side: (The JDM is on the left, the burned USDM is on the right.)
Old May 17, 2018
  #1639
huh...
not sure if JDM have the anti-theft system then...
that means if anyone tries to steal your car, they will have an easier life to do it...
Old May 17, 2018
  #1640
huh...
I may have to figure something out for security, like a kill switch or something. But I think it has some kind of immobilizer though since it wouldn't turn on the fuel pump by itself.
Old May 18, 2018
  #1641
I’m still not sure about the P1713 code. I did notice, however, that when I put the shifter in D3, the light on the dash doesn’t come on. But the code is only set when I put the shifter in 2, and the light does come on in 2. So I don’t know what’s with that. I think the JDM PCM just doesn’t get along with my USDM trans. Maybe this issue will be resolved when I install my JDM SLXA trans.
Also, I don’t know for sure why it’s setting a P0135 code. But my theory is that, like the 01-03 Civics, the JDM Civics have a standard o2 sensor instead of an A/F ratio sensor like my 05 Civic has. So maybe the PCM is looking for a standard o2 sensor, and it doesn’t recognize the A/F ratio sensor. Does that sound reasonable to you?
Old May 18, 2018
  #1642
The other thing I forgot to mention is that the case of the PCM is physically different, as you can probably see in the picture. I think it’s because JDM cars have the drivers seat on the right side of the car. So I think I am going to put the circuit board from the JDM PCM into the case for my USDM PCM, since the mounting holes don’t line up.
Old May 18, 2018
  #1643
Also, after filling it with 93 octane gas and driving it for a little while, I’m pretty sure it does have more power. I can’t be sure, especially since the old PCM was broken, but it feels a bit stronger with the JDM PCM. I feel the most difference in low end torque. The engine feels like it has more low end torque. Not a ton, but definitely noticible, especially starting out from a stop. However, it doesn’t feel much different in the higher RPMs. I’ll report back on gas mileage the next tank.
Old May 18, 2018
  #1644
RobertD's Avatar
so what's actually fried on the old one? did a trace burn off the board? a component melt? got a better carnage pic?
Old May 18, 2018
  #1645
I think a trace burned. I’ll get a better picture when I get home. I’ll take the circuit board out and get a picture from the back too. I wasn’t too focused on the burn mark when I took that picture, I was more focused on getting a side by side JDM vs USDM PCM picture. There are quite a few differences, as you can see.
Old May 18, 2018
  #1646
Re: High RPM on the highway
UPDATE: It was the PCM. I replaced it, and the trans shifts perfectly now. Thank you to everyone who helped!
Old May 18, 2018
  #1647
Wankenstein's Avatar
Can you 'feel' any difference in performance with the JDM pcm?
Old May 18, 2018
  #1648
Yes. It seems to perform a bit better with the JDM PCM, especially at low RPMs. Here’s the details: https://www.civicforums.com/forums/1...ml#post4745327
Nice work. Glad you got it sorted out.
Old May 18, 2018
  #1649
Originally Posted by mikey1
i would be careful driving it at those speeds,
years ago i had a high revving issue like that (in a different vehicle) and all of a sudden cruising at 60mph the trans downshifted to first gear and nearly put my head through the windshield....thank god i had my seat belt on
Just curious- Was anything damaged when it downshifted?
Old May 19, 2018
  #1650
mikey1's Avatar
yes....my neck!
