View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
#1804
Received 1,442 Likes
#1806
What causes a battery to reverse polarity?
So I bought a 12v 5 Ah SLA battery on Amazon so I have a portable power source for testing electrical parts in junkyards and such. However, when I tried to charge it, I got a reverse polarity error on my charger. I verified with a voltmeter, this battery does indeed have reverse polarity. So my question is what would cause this? Was it likely mislabeled, or is it possible that it was charged backwards at the factory? Sorry for the dumb question, I'm just extremely curious what would cause this.
#1808
Rep Power: 338 Re: What causes a battery to reverse polarity?
there are cars that are that way. I have two of them.
are you sure you got the right one?
#1811
Also, wouldn't a positive ground car still use a normal battery?
What causes a battery to reverse polarity? So I bought a 12v 5 Ah SLA battery on Amazon
Check that one before install.
FWIW a lead acid battery can be charged up backwards. I've witnessed it.
#1815
#1818
#1820
#1821
Received 1,126 Likes
Rep Power: 191 Re: What causes a battery to reverse polarity?
Sorry was just trying to make sure I was on the same page as sdaidoji. Lack of caffeine on my end.
#1825
Re: I think this is the end of my transmission
#1827
#1829
#1830
Rep Power: 78 Re: I think this is the end of my transmission
at 4,000prm with your explosive refrigerant the AC is probably amazing
realistically, i have a friend that had a cavalier with only first and second gear. the only real problem with driving it like that is 50mph at 4000+ rpm is it is very loud and very embarrassing. he used to get up to speed and put it in neutral. i'm pretty sure the embarrassing car cost him his girlfriend
