View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
#1711
Re: Should I adjust my MAP sensor voltage?
His issues are beyond scope.
He is not using stock intake , intake manifold, or injectors or exhaust manifold or right pcm or right spark plugs or the right other parts.
I suggested he gets a adjustable fuel pressure regulator months ago since he has a Frankenstein setup and besides Programmable PCM that’s about all he can do.. well except hack a feedback sensor I suppose.
#1712
Is it running okay after that dude drained the oil and coolant out of it?
#1714
#1716
Really, you verified with DC sports that header was made for a D17 running a D16 full intake including sensors, throttle body and injectors and a catless exhaust and it should not create a rich condition?
#1720
I think my transmission is dying
Earlier today, my transmission started acting weird. So far, the only symptom seems to be with first gear. What it's doing is from a dead stop, when I give it gas, it sort of hesitates for a second, then it "catches" and lurches forward and drives normal. It also has started itself from a stop in second gear a few times. If I manually put the shifter in 2, it starts out normal every time. I think what it's doing is not downshifting to first gear, then downshifting to first gear when I take off. I think the trans was damaged when the PCM was shifting it erratically. Does this sound like the transmission is starting to go out? I think this is the beginning of the end of this transmission. What do you think?
#1721
Re: I think my transmission is dying
It's either broken, or not.
Low fluid level? Are you checking it the correct way?
Try a USA PCM?
Try a USA PCM?
#1723
Rep Power: 78 Re: I think my transmission is dying
maybe your arch nemesis in the cavalier has put some foreign substance in the fluid. normally a car that hesitates for a second has low fluid or a dirty/clogged filter.
#1725
#1727
You all don’t know this guy, he will pull the tranny out of a 1992 civic abandoned down his street, bolt it up and ask us help getting his speedo working right...
#1728
#1730
Update: It's fixed. The problem ended up being a bad brake light switch. I'm not sure how it's related, but I noticed that the brake lights were staying on when parked, so I changed the brake light switch and everything is good now. Thanks for your help!
#1732
See my similar reaction at the 1:18 time mark on video below. Substitute "what?" for the line "you quit?"
#1733
I believe that the government mandates that the brake light switch is on its own isolated circuit, which is why there is usually a separate brake switch for shifting out of park, cancelling cruise, etc. I'm pretty sure your problem will be back soon
#1734
This is a 4 wire switch, so I think 2 wires are for the lights and 2 wires are to tell the computer maybe? Maybe that's a new regulation? Not sure. My car only has 1 brake pedal switch. But it was consistently acting up with the old switch and it's consistently fine with the new switch, so I think it's fixed.
#1735
4 wires because the brake switch has two separate sets of switch contacts.
When pedal is depressed, one set of contacts opens, the other set of contacts closes.
Brake lights, cruise, multiplex, shift lock, ECM/PCM, ABS all use the N.O. set of contacts.
Cruise is usually the only unit that uses the N.C. contacts.
#1736
#1737
Will shaving my head make more power?
I would like to increase my compression to between 10.5:1 and 11:1 to make a little more power, but there aren't really any options for higher compression pistons for these engines, and no one seems to know if D16 pistons will fit. So my question is if shaving the head to increase the compression will make more power from higher compression. I don't see why it wouldn't, but I'm just making sure. Thanks!
#1738
Re: Will shaving my head make more power?
Here's many similar threads (various engines): https://www.google.com/search?num=50....0.6VhC2CAmY_4
#1739
Received 1,440 Likes
Rep Power: 338 Re: Will shaving my head make more power?
you will turn into a skin head
