View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
#1681
Re: Is my engine okay?
I did call the cops. They told me that they have no proof of who did this, even though the suspect was making a joke about the oil running out. I asked them to see if they could get fingerprints, but they refused. They said the crime is so bad here in Memphis that they have bigger concerns. Also, you’re right, I should have reported this to my insurance company, but I didn’t think of it.
#1682
The legs in the public bathroom stall
I have a co worker that allows the same BS to happen to his cars. Sounds like you should invest in a dash cam with standby parking mode.
#1683
Re: Why is coolant run through the throttle body?
I think that since I have an aluminium intake manifold, the throttle body stays warm enough for this to not be a problem, especially in this climate. I think if it was going to freeze from the lines being disconnected, it would have done it when I was living in Chicago with a plastic intake manifold.
#1684
I had a dash cam. The person burned the camera with a burning laser, destroying the SD card, and scratched “I LUV KKK” in the back bumper. I would put a camera in my window, but I live in an apartment and I can’t park in front of the building.
#1685
8-10 seconds without oil isn't long. Especially only idling, not under load. We've seen far worse conditions without oil and engine still survived.
Refill and run it. If it doesn't knock, keep on driving it.
Coolant/overheat? You should already know what damage could occur.
All you can do now is refill everything, shoot your friend through the palms of both hands with buckshot, and drive it until you find out if there was damage done.
It will either survive, or it won't.
#1686
#1687
Could be wrong but since the KKK is considered a very racist organization and depending on your ethnicity you might have grounds for getting it ruled a "hate crime" which drastically changes how the cops respond to the situation especially if you can get it caught on video.
#1688
The same jerk that scratched "F*** U COPZ" in my back bumper drained my oil and coolant overnight. This morning, I started my car, and about 10 seconds later, I noticed that the low oil pressure light was on. I immediately shut off the engine and checked the oil. It was completely empty! I jacked up the car and checked the plug, and it was in, but the crush washer was sitting on the ground. As I was refilling the oil, this jerk is laughing and said "It looks like your oil done run out!" as he was driving past. So "someone" drained the oil. I put the crush washer back on the plug, refilled the oil, and tried to drive it. But when I got on the highway, the engine quickly overheated since it had no coolant. I immediately stopped, let the engine cool, and filled the radiator with water. It's not making any bad noises and it's not running hot, but now the engine doesn't quite feel right. I can't explain it, maybe I'm just paranoid. So my question is if I would immediately know if something was damaged from this. I'm really worried now.
Move to Chattanooga...Memphis sucks..lol
#1689
Sounds like a repeat offender. Have you told the cops about all these incidents? Do you have any friends that park in the same lot? Have the camera in their car. Check the surrounding parking lots/businesses see if anyone has cameras on the area.
#1690
Rep Power: 77 Re: Why is coolant run through the throttle body?
on my FORD the factory had coolant running through an EGR plate immediately behind the throttle body (picture it as a 2" throttle body spacer). IDK how the egr in your honda is routed, but it is not for heating the TB in winter, it prevents excessive heat as the EGR gas is hot and that is where it enters the intake. the coolant passing through it keeps that at a reasonable temperature(in a mustang anyways). just food for thought.
see the post by Joel. he is seen more or less as a guru. http://sbftech.com/index.php?topic=29072.0
#1691
So, this person that must really dislike you at some point (night or day) jacked up your car, used buckets to catch the oil and coolant or was oil and coolant all over ground/concrete under your car? Do you live in apartment building? Any witnesses? Did you do anything previously to **** that dude off?
#1692
on my FORD the factory had coolant running through an EGR plate immediately behind the throttle body (picture it as a 2" throttle body spacer). IDK how the egr in your honda is routed, but besides heating the TB in winter, it also prevents excessive heat as the EGR gas is hot and that is where it enters the intake. the coolant passing through it keeps that at a reasonable temperature(in a mustang anyways). just food for thought.
#1693
Yes, I live in an apartment. There are no witnesses either. This person must have used a bucket to catch the oil and coolant. There were only a few drops of oil under the car. And he’s pissed off at me because I called the police on him for repeatedly making an insane amount of noise with his riced Cavalier in the middle of the night. This moron literally drives through the apartment complex and revs the hell out of his car at about 1:00 in the morning. He literally rolls through with the clutch in and bounces off the rev limiter. After 2 weeks of this, I called the police on him and the police gave him a ticket for excessive noise. That’s when this started.
Find others in your complex that are pissed at this turd and collectively give him a solid beat-down his parents never did.
#1694
#1696
yes. it prevents the EGR from super-heating the intake. since i have no longer have EGR, i just leave the lines (to the brass nipples) unhooked. my EGR valve would be where the two nickel sized holes are between the two black studs. there was never any mention of the coolant having to do with helping in winter, only to cool things.
Attachment 112240
Attachment 112240
#1697
Rep Power: 77 Re: Is my engine okay?
if he lives with his parents you might go talk to them. i do this sometimes and not only does it work, it's hysterical. i'd have so much fun getting even with that guy in very strange ways.. i'm a little jealous
#1700
Prelude Owner
Dash cam on another car like stated and alarm with tilt and shock sensors wouldn't hurt.
Can you add a camera on your apartment pointing at the car? They are pretty cheap these days with good image quality.
#1701
Should I adjust my MAP sensor voltage?
As you know, my POS has been running rich for several years, and I can't figure out why. So I think I am simply going to install a potentiometer on my MAP sensor signal wire so I can basically tune the engine. If I reduce MAP sensor signal voltage, in theory, the PCM should quit running it rich and advance the timing a little, right?
#1703
Rep Power: 77 Re: Should I adjust my MAP sensor voltage?
if you adjust the map so your fuel trim is neither positive or negative, the car will still be running exactly the same, the only difference is you are tweaking what the MAP reports to the computer so it does not have the fuel trim correcting things. your AFR will still be exactly where it is now because the o2's are ultimately what keeps them there. you can adjust the map so the trim correction is not needed and you get numbers closer to no correction needed, but why? you're adding wiring and complexity to a very simple system and there is no good that will come from it, other than you might feel better seeing the fuel trim numbers change.
read here where it says Base Fuel www.efidynotuning.com/fuel.htm
i would have a new fuel pump, new o2's, new exhaust gaskets, new MAP, and a complete fresh tuneup with everything from plugs and wires to inspecting and perfecting ground connections before bothering.
personally i hate potentiometers. the reading they provide changes based on temperature, age, load, etc. i have potentiometers in my DeRale fan controllers and i have to mess with them weekly to get them to stay accurate. i would just leave it alone and not create a bandaid to a possibly non existent problem. even if it is a real problem, the only outcome to doing what you want will be a car that runs exactly the same but shows the fuel trim how you want it. there's no point, you'll just be twisting a **** constantly trying to get the car to run right. it doesn't sound like an upgrade or a fix. it sounds like a headache, a nightmare, one more thing to constantly try to adjust.
#1705
Received 1,440 Likes
#1707
Why not figure out why it's running rich?
Does it actually set a rich code?
I'd try to find where you previously posted specifics about the issue but I'm not sifting through 132 threads and almost 900 posts you've made to find it.
#1709
No other codes set as well for the MAP, EGR, VTEC or HO2S sensors correct?
Check the fuel pressure. If too high check fuel pressure regulator and the fuel return line. If too low, check fuel pump, the fuel line, fuel filter and fuel pressure regulator.
Check Primary HO2S sensor - you said you replaced.
Connect vacuum pump to EVAP canister purge valve on canister side. Disconnect 2P connector. Start engine. If vacuum on the gauge, replace EVAP canister purge valve. If no vacuum, check valve clearances and adjust if needed. If valve clearance OK, look at the injectors.
#1710
His issues are beyond scope.
He is not using stock intake , intake manifold, or injectors or exhaust manifold or right pcm or right spark plugs or the right other parts.
I suggested he gets a adjustable fuel pressure regulator months ago since he has a Frankenstein setup and besides Programmable PCM that’s about all he can do.. well except hack a feedback sensor I suppose.
