View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
Old Mar 30, 2018
  #1351
Colin42's Avatar
Re: Dumb oil cap question
Originally Posted by D17VTECPOWER
I always used silicone paste on the gasket for the oil cap and filter.
FFS just use engine oil
Old Mar 30, 2018
  #1352
mikey1's Avatar
Old Mar 30, 2018
  #1353
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Oh.... so his Oil Cap is missing the Rubber Seal? "thats why Your having trouble taking it off" in all Honestly for what an oem honda Oil Cap costs even if You get one thats used from a Junk Yard that has the rubber seal Just clean it Up. its still alot better than smearing Oil or silicone on it, and getting it on the engine and then driveing it down the road and having the oil residue burn off it and make it smell like a Oil refinery in Your car LOL
Old Mar 30, 2018
  #1354
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
To clarify, I meant I use silicone grease, not RTV silicone.
Old Mar 31, 2018
  #1355
Re: Is my battery voltage too low?
I put the known good alternator on, and it's better, but not fixed. I had Advance Auto test the alternator before I put it on, and it tested good. I put it on and everything seemed good until I loaded it. But when I turned on the headlights, radio, blower motor, rear defroster, wipers, AC, and interior lights, the voltage goes all the way down to about 12, and it will go to 11.3 if I pull the window switches. When I rev up the engine to ~2K RPM though, the voltage goes up. I ordered a 48MM pulley for the alternator to replace the stock 66MM pulley, so hopefully the smaller pulley helps. I'll report back when I install the smaller pulley.
Old Mar 31, 2018
  #1356
anthonyelectric's Avatar
anthonyelectric is an unknown quantity at this point
Re: Looking for disc brakes
I have a parts car 04 EM2 - will that work?
Old Mar 31, 2018
  #1357
No. That has the same drum brakes that mine has. Thanks for responding though!
Old Apr 1, 2018
  #1358
I need a header for my D17A2
I'm looking for an exhaust header for my D17A2. My DC Sports header cracked, so I replaced it with a $47 DNA Motoring header, but I'm not satisfied with the new header. So I'm looking for a quality exhaust header for my Civic. I don't care if it looks good, as long as it's good quality. Does anyone have a header for my D17A2?
Old Apr 1, 2018
  #1359
Re: I need a header for my D17A2
bigger diameter tubes would give you more power on higher revs with less torque on lower RPM... was it not what you always wanted in all your posts? ...
have you thought on stock header? they are not that bad...
Old Apr 1, 2018
  #1360
Yes, I do want good top end power. But this is also a street car, so it needs reasonable low end torque, and this header is just not working. When I start out from a stop, the car just doesn't want to go. With this header, I literally have to back up at speed bumps and get going because the car barely goes over medium size speed bumps from a stop if I don't. And it doesn't feel any quicker at high RPMs either. It likely is a little quicker at high RPMs, but not enough to be noticed, and definitely not enough to give up this much low end torque. And I did not consider a stock header.
Old Apr 1, 2018
  #1361
Maybe you should.
Old Apr 1, 2018
  #1362
Originally Posted by ezone
Maybe you should.
Wouldn't a stock header become a restriction with all the other upgrades I have?
Old Apr 1, 2018
  #1363
Why would it?
Old Apr 2, 2018
  #1364
Why would it?
If the stock header was just as good as an aftermarket, why do so many people upgrade?
Old Apr 2, 2018
  #1365
Colin42's Avatar
"ooh shiny"
"it comes with this really cool sticker"
"i don't need a cat"
Old Apr 2, 2018
  #1366
Originally Posted by Colin42
"ooh shiny"
I understand that people buy a lot of stuff that they don’t need, and I agree that a fancy header won’t make much difference on an otherwise stock engine. However, is a stock header not undersized for an engine where everything else has been upgraded for more power? Would a performance header not make more power than a stock header on an engine as upgraded as mine?
Old Apr 2, 2018
  #1367
Correct way to add accessories?
I have heard that you shouldn’t get power directly from the battery’s terminals on Hondas with an ELD if you are going to install accessories because the ELD won’t detect the power draw, and might therefore keep the alternator in low charge mode when it really needs to be in high charge mode. So since you shouldn’t get power directly from the battery terminals, where should you get it from?
Old Apr 2, 2018
  #1368
Colin42's Avatar
Re: Correct way to add accessories?
When I installed my fog lights the wiring harness had a connector that plugged directly into the under dash fuse box for switched power.
You can do the same thing with a female blade terminal, look at the fuse box and you should see some empty connectors, use your multimeter to figure out which ones are switched power. Install an inline fuse.
Old Apr 2, 2018
  #1369
Stock is good enough.
You haven't increased the breathing capacity of the engine.
Old Apr 2, 2018
  #1370
Doesn’t upgrading the cam, intake manifold, air intake pipe, and exhaust system increase the engine’s breathing capacity? Isn’t that the whole point of upgrading the cam, intake and exhaust?
Old Apr 2, 2018
  #1371
No..
EDIT: Not in the way you are thinking
Old Apr 2, 2018
  #1372
No..
Isn’t the whole point of bigger cams, cold air intakes, high flow exhausts, etc to give the engine the ability to breathe more freely, thus move more air?
Old Apr 2, 2018
  #1373
In a way.
But what are ultimately the limiting factors?
Old Apr 2, 2018
  #1374
In a way.
I’m not sure what the limiting factors are. Maybe the size of the ports in the head?
Old Apr 2, 2018
  #1375
Yes.
Ports and valves.
And redline.
Old Apr 2, 2018
  #1376
Yes.
Ports and valves.
And redline.
Would porting and polishing the head noticibly improve power with the stock rev limit?
Old Apr 2, 2018
  #1377
Learn about volumetric efficiency, cylinder filling, velocity, swirl, turbulence
Old Apr 2, 2018
  #1378
I already know a little bit about that, but I’ll do more research on it. Thanks for your help!
Old Apr 2, 2018
  #1379
honestly, they are not that different.
the stock design is quite good on the EX.
Sure, the DC sports gave more oomf with the stage 1 cam. If the engine was stock, it would really not do much.
see comparison below. where the tubes join, is the biggest difference.
post #42
https://www.civicforums.com/forums/4...ml#post4702970
Old Apr 3, 2018
  #1380
UPDATE: I just installed the new billet aluminium oil cap. It fit perfectly. Thanks guys!
