View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
Old Mar 18, 2018
  #1261
mac25's Avatar
Dr Krieger of Modification
Re: How do throttle body spacers work?
Exactly. They do most likely nothing, to a modern FI N/A Build and especially nothing on a stock car.
Old Mar 18, 2018
  #1262
mac25's Avatar
Originally Posted by D17VTECPOWER
"The whole point of ITBs is to basically eliminate the volume in the intake manifold that's under vacuum. The less volume under vacuum, the faster air will fill the space and the quicker the engine will respond to throttle."
No you miss understand ITBs.
They don't eliminate volume they maximize it.
The volume in a manifold is the maximum amount of air that is available to be consumed by each cylinder.
Running an ITB set up basically places a TB on each intake port and allows each to breath in as much air volume as they can.
Old Mar 18, 2018
  #1263
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Originally Posted by mac25
No you mis understand ITBs.
Since ITBs eliminate the plenum and runners, there is much less volume that's under vacuum. That's why throttle response is so quick.
Old Mar 18, 2018
  #1264
mac25's Avatar
...you're swapping volume, atmospheric pressure and vacuum around with each other.
But yes throttle response is increased.
He literally says, at 2:30, with ITB "...you have instantaneous throttle response because the second you step on the throttle that atmospheric pressure [which is higher, not lower, as he explained earlier] is right there and it goes right in your cylinder...."
It has nothing to do with you're statement of "less volume under vacuum". Yes it's less volume under vacuum but less isn't better, in the case of the non ITB that has volume under vacuum, more is better, that's why upgraded intake manifolds have larger diameter runners (which may be shorter) and larger plenum volumes.
The easiest way to picture an engine is as an air pump. The faster you can get the maximum amount of air into and out of an engine, the more power it will make. That's why large diameter throttle bodies, and large intake manifolds flow more air and make more power. With ITB basically the entire worlds supply of air is the intake manifold when you run ITBs the right way, which is with no intake manifold, which he also mentioned as seen bellow.
Old Mar 18, 2018
  #1265
but then reduces low end torque, which is actually what matter on day-to-day use
Old Mar 19, 2018
  #1266
mac25's Avatar
Yes, but I didn't want to get into torque curves and runner lengths, lol.
Old Mar 20, 2018
  #1267
Bad gas mileage
I have a few problems with my Civic that I think are contributing to getting only 25-28 MPG. My questions are how much, if any, can each of these problems effect mileage? I’m going to fix all of it, but I’d like to know what is likely hurting my mileage the most. Here’s the list:
1. EVAP purge solenoid completely broken and non-functional
2. Fairly large crack in my exhaust header right above the upstream o2 sensor.(New header is on the way)
3. Front right plastic wheel well liner missing
4. Questionable wheel alignment
5. Whatever is causing my fuel trim to be -15 to -25
Could these issues reduce my mileage this much? I should be getting 32-35 MPG.
Old Mar 20, 2018
  #1268
Re: Bad gas mileage
What leads you to believe this?
Old Mar 20, 2018
  #1269
Re: Bad gas mileage
It’s what I used to get.
Old Mar 20, 2018
  #1270
Re: Bad gas mileage
You must have been driving pretty dang conservatively:
https://www.fueleconomy.gov/
Fix the known issues first (everything on your shopping list) then recheck fuel economy.. Consider other contributing factors as well
Old Mar 20, 2018
  #1271
Re: Bad gas mileage
I’m not an extreme hypermiler, so I don’t do P&G, EOC, drafting or anything else stupid. However, I try to drive easy, and use the gas and brake as little as possible. It’s safer, easier on the car, and more efficient. My driving style hasn’t really changed either. Other than the list of problems above, I don’t know why my mileage decreased.
Old Mar 20, 2018
  #1272
Re: Bad gas mileage
Well, your list seems to be a great place to start
I might start with the exhaust leaks just to see how fixing that affects the fuel trims
When you say header, do you mean you're getting an OEM exhaust manifold?
Old Mar 20, 2018
  #1273
Re: Bad gas mileage
No. My DC Sports header cracked, so I bought this one:
https://www.amazon.com/gp/product/B00JA1C8WS/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00JA1C8WS/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
I’ve put that header on a few people’s cars, and it’s great. It should be here Friday. I think the crack is pulling in air and making the o2 sensor falsely read lean, causing extra fuel to be added. However, I would think a cracked header would cause positive fuel trim, not negative. I expect the fuel trim to go even more negative with the new header.
Old Mar 20, 2018
  #1274
Slumpertcivic's Avatar
Re: Bad gas mileage
Too many factors..
Old Mar 20, 2018
  #1275
Re: Bad gas mileage
No. My DC Sports header cracked, so I bought this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I'd go with stock
Old Mar 20, 2018
  #1276
dsm482's Avatar
dsm482 has a spectacular aura aboutdsm482 has a spectacular aura about
Re: Chassis bracing
you might as well weld a custom cage in then with supports..
if u ever rolled it , it will pay off itself by keeping you safe)
Old Mar 21, 2018
  #1277
Re: Bad gas mileage
I'd go with stock
Why? I've used that header before and haven't had problems. Performance wise, I'm not sure that there's much of a difference though.
Old Mar 21, 2018
  #1278
Re: Bad gas mileage
Where is YOUR primary O2 sensor located?
Old Mar 21, 2018
  #1279
Is manually shifting an automatic transmission safe?
When I do full throttle acceleration, I always put the transmission in a lower gear, and I upshift just before the rev limiter. If I leave it in D4, it upshifts much sooner and doesn’t accelerate as quickly. However, a friend that I took for a ride noticed, and he said I shouldn’t manually shift it. He said that I am causing a lot of extra wear on the transmission by keeping it in low gears too long. Is there any logic in what he said? To me, it seems like the transmission wouldn’t be harmed for staying in lower gears accelerating. However, I am far from a transmission expert, so if someone knows the answer to this question, please let me know.
Old Mar 21, 2018
  #1280
Re: Bad gas mileage
I put it in the exhaust pipe right below the header. Even though the header has an o2 sensor port, I always just put it in the exhaust pipe right below the collector. The same place as it would be with an OEM header.
Old Mar 21, 2018
  #1281
Colin42's Avatar
Re: Is manually shifting an automatic transmission safe?
Don't.
It's an automatic for a reason, let it do it's job.
Manualized valve bodies are a different story, but you don't have one.
Revving up to redline isn't good for fuel economy either by the way
Old Mar 21, 2018
  #1282
Originally Posted by Colin42
Don't.
Is forcing it to stay in lower gears for quicker acceleration damaging? The trans upshifts way before peak power is reached if I floor it in D4. Also, flooring it is obviously never good for fuel economy.
Old Mar 21, 2018
  #1283
This ain't right.
Throttle ain't all the way open?
Pull the stack of floor mats out from under the pedals and retry it.
Have someone mash the gas pedal to the floor while you check that the throttle is actually fully opened. Maybe the cable has too much slack and needs adjusted.
Make sure TPS starts at 0.49v closed, and ends up around 4.5v at wide open
Old Mar 21, 2018
  #1284
This ain't right.
I don't think there's a problem, I just think that the PCM was programmed for the lower peak power RPM of the stock setup. The cam and other mods shifted peak power to a higher RPM, but the PCM obviously doesn't have a way to know. Also, the throttle opens fully, and the TPS voltage is 0.5 at idle and 4.6 at full throttle, so it's good.
Old Mar 21, 2018
  #1285
GolNat's Avatar
Prelude Owner
When the gas pedal is floored it should go to redline and shift. Even my wifes Pilot does this.
Is this the same transmission that is at higher rpm at highway speeds then normal?
Old Mar 21, 2018
  #1286
This car never revved up to redline before shifting in D4. And yes, the trans won't shift to 4th gear on the highway. However, if I disconnect the battery, the trans will shift to 4th gear for a few minutes, then it'll downshift to 3rd and not go back to 4th unless I reset it again. However, there are no codes, and the desired gear is always the same as the gear it's in. What does this mean? PCM problem?
Old Mar 21, 2018
  #1287
GolNat's Avatar
Prelude Owner
I have no idea!
Was the PCM a possible cause discussed in your other transmission thread?
Old Mar 21, 2018
  #1288
Wait wait wait.....Are you meaning "fuel cut" instead of "redline"?
Old Mar 22, 2018
  #1289
No, I mean redline.
Old Mar 22, 2018
  #1290
No, I mean redline.
Then yeah, yours is probably broken:
^This describes correct operation, all day long^
