Ask Me About DIY Stuff V2!
Re: Ask Me About DIY Stuff V2!
I have a low howling going on that is driving me nuts. I've tried everything i can think of, maybe you could give me a quick list of stuff to check. The noise happens as soon as you start the car, it doesn't matter if the clutch is engaged or not. The noise stays the same while your driving doesn't get louder or faster. The only thing that changes is if you drive alot in a day it gets quieter... Oh yeah it's a 98 civic EX lightly modified. I'm a pretty good shade tree mechanic but this is driving me freakin crazy, thank you.
I'm pretty sure the bulbs are still good. When I tired plugging them into the rear, they at least lit up. Any other ideas?
hmm i really couldnt say except trace back the wiring. check the sockets and see if theyre connecting properly. sometimes the bulb seat gets twisted and the contacts cross and then nothing works.
Do you know if anybody has done a DIY on doing a grill chop on the '03 hybrid bumper? And what's your opinion, I am about to order my new bumper, should I just replace the bumper ('02 sedan), or do the hybrid swap?
I was also wondering where you got your grill?
yuck i dont like the hybrid grill at all lol. but people have done the whole bumper and grill swap from 03 hybrid to 01-03 civic. its the same.
my grill is just the type-r altezza grill off ebay with the lip painted ssm.
I have a 98 civic ex d16y8 that has a problem with the cooling fan. It doesnt run at all even when the car has heated up. I would like to think that this is due to the temperature never really deviating but i have no idea.
The car seems to run fine so I dont understand what it could be
A/C and heat work,
I havent smelt anything burning and the block and never felt overly hot
Temp gauge moves on start up but doesnt deviate much from there even after hard driving
Fuse is good, dont know how to check relay, motor test dunno how to do(will multimeter work?)
A/C and heat work,
yo gearbox i replaced my airride with some eibach coilovers on my 96 civic ex but for some reason its bouncy as hell and with the adjustable coilovers i dropped it bout an inch all around do u think it needs new struts or shocks or anything?
I know, I hate the grill on the hybrid too! That's why I was wondering if anybody had gotten that bumper, but cut out the grill. I thought it might look cleaner on my car since I don't have a front license plate.
i think the grill is part of the bumper tho...
not sure on the eibach coilovers, sounds like they are blown or not adjusted properly (if they are adjustable). some other guys have those and say they are very good. it should come with the full set of springs and shocks all eibach.
for the cooling fan, it has to be pretty hot outside for it to come on (above 80F). if you turn the ac on, both fans should come on instantly. if not, theres a problem with either the fan temp sensor or a relay or the fan wiring. the stock temp gauge is never accurate, it should sit at the same spot once warm and only go up if the engine is overheating.
do they have any adjustment for ride stiffness? maybe theyre set to the softest setting. i have eibach 1 inch springs and tokicos and feels very firm.
idk i had airride on my car b4 but the dudes said it ****ed up my suspension and they modified alot of it just so they can make it work or something i think they were just pulling my leg because i had to put my bodykit back on and everything looked fine and regular to me
hi, im new to this site. i have an 2007 LX coupe, and i recently rear ended someone. luckily, the other guy didnt want to report it to insurance. i need to replace my headlights as well as my front bumper cover, so i just ordered roku creation plug n play halos and a remanufactured OEM front bumper cover from ebay. I have a friend who will paint the cover, but the seller informed me that it does not come with any of the neccesarry screws or clips. where do i get those? and how do i attach the bumper cover to the car? im soo lost lol
Last edited by treen08; Sep 18, 2009 at 10:07 PM. Reason: forgot to put year of car
hi im just wondering if the drivers side mirror on a 02 coupe will fit on a 04 4dr sedan ..
and also if i purchase a pair of new mirrors that are electric can i make my own to switch to operate them
thanks in advance
thanks in advance
well first question, no i dont think coupe and sedan are the same. the bolt holes and plug are in a different spot so i dont think you will be able to bolt it on properly. for electric, you would have to find a way to make your own switches (one for each mirror) or find a honda switch and try to figure out what all the wires and pins do. that will be tough tho.
thank you very much i guess ill just pay about 30 bucks for more for a new one or is there a place i can only get the inside assembly of the mirror like the wire that operate the mirror are cut and mirror fell out other than everything is fine
From: thats for me to know and you to find out, if you want to know msg me.
Hello Gearbox i am in need of your help. I would like to know how i can install a new headunit into my car so i can play cd's. So can you please guide me through this problem. Thank you
you need an aftermarket radio, the specific adapter harness for the car that will plug in to the stock harness, and a dash trim piece. the adapter wires need to be connected to the radio harness wires and matched to the proper functions. color should not be used as a guide. the adapter plug you bought and also the stereo instructions will tell you what each wire does. all these parts are available from most stereo shops like best buy.
Hey Gearbox, do U work @ a shop in Reno? Nevermind I'd go broke on mods if I met U. The dash LEDs are sooo purrrty. What year/model is your car? Also, DIYwise do you know if a 99-00si catback will fit a 96 hatch (direct bolt-on & hangers w/ no modification) if I upgrade cat & header to EX. I swear I've been trying to nail this down for days cuz I hate to ask a stupid question that the answer's everywhere. This http://www.hopupracing.com/5zficaexsywi1.html is what I want but no options say 96-98Ex.
I also have a question about the audio.
So i bought two harnesses, one that connects to the OEM harness, and one that goes to the aftermarket radio.
The aftermarket radio harness has that thing which you can use to screw the ground to the chassis, and the oem is just a wire cut at the end.
How do i connect those two together?
for the radio, you should ground the wire directly to the chassis in a good spot where it will not get loose or rusty. do not use the oem ground wire.
hb pickup-no im just an amateur mechanic lol. i know enough to keep my car running and do some extra stuff on the side. for the exhaust, im pretty sure it will bolt together, but the problem is you run the risk of having the hanger spots not line up and possibly having the muffler stick out or in too much. only way to know is try it out. you may only need slight modifications, and welding new hangers does not cost much at a shop.
You've opened the floodgates now, bro. But since i've seen you've broken into head unit faces, got an idea what to look for in a 12 year old Alpine that the far right lighting is way dim on? Prolly a light bulb of some sort out? Tips on getting in there? Any tiny springs gonna fly out or anything? It's a removable face type.
take the face apart, i know on the older alpines, they usually just use bulb. the face comes apart pretty easily, just look for tiny screws on the rear or sides and remove those. you need a mini screwdriver "precision" kit for $5 at auto store. once screws are out, the face is still held together with clips. you need to gently pry apart the two halves. there are usually one or two springs for some of the buttons (like the detatch face button) that will fly out. and some plastic light guides. most of it will stick together tho on the top half like the light shields and buttons. the bulbs should be at the bottom. the bulbs are prolly soldered onto a board, so youre gonna have to go check the auto store to find a comparable size and brightness bulb. then hopefully with some limited soldering skills you will be able to swap the bulb. just get a good 30w iron with tip, copper desoldering braid to remove the old solder, and a roll of new solder to use with new bulb. oh also if your face has any round dials, you will need to pull those out first before taking the face apart.
the newer alpines all use tiny smt leds which are nearly impossible to change without a tiny solder tip and a magnifying glass lol. i was gonna change mine to blue but the leds are so small i can barely see the solder joints.
Hey gearbox you know how to paint your own car?! The guy that painted it for me works at a body shop and he did it as a side job but that m-effer rushed the job and its crappy as hell. He's gonna redo it soon but if he messes up again I'm just gonna give up on him, and he wont give me the money back I already tried. Keep in mind I paid 1600 for this job and he'll only redo it if I pay for the paint and do all the prep for that SOB. These local hawaiians are scammers and it sucks for us mainlanders =/...
If it still doesnt turn out right I dont have any other option but do it myself. If you have any tips that would be awesome.
I just go a 93 Honda civic Dx Manual no engine or wire harness
I have the engine of my old wreck 94 Lx automatic has wire harness and everything
I know I need a another trany and ECU I was wondering if I can use the same harness of the 94 Automatic
Hope you can help thanks
