Ask Me About DIY Stuff V2!
Old Mar 3, 2009
  #271
CiViCPrAnInG2k1's Avatar
Re: Ask Me About DIY Stuff V2!
hey steve, wut kind of bulbs do hybrid fogs use? PM ME naowww PLEASE.
Old Mar 3, 2009
  #272
sebdiz's Avatar
sebdiz is an unknown quantity at this point
Hey i posted this elsewhere on this forum but trying to find an answer.. if i should purchase the exhaust.. heres the story..
I have a friend of mine who is selling me a skunk2 megapower exhaust for real cheap.. about $100.. thing is i have a 93 civic and its a sedan..auto on top of that.. and it doesn't seem to be able to fit on this car.. he tells me its able to fit it may just need some custom piping.. it would just be the skunk 2 exhaust piping with the muffler. no resinator or silencer.. so my question is should i go with this.. worth it?would there be any way i could make the exhaust fit on the car? will it be too big? some help would be greatly appreciated
Old Mar 3, 2009
  #273
lordhelmet's Avatar
Originally Posted by gearbox
check bellz DX-R site. i think he has a diy. i can look for the web address.
Well... I searched for it and found this:
https://www.civicforums.com/forums/3...e-updated.html
The link no worky. Is there any other place with that information?
Old Mar 3, 2009
  #274
have no idea on the hybrid fogs. that car is a whole different ballgame lol. no info about it in any of the normal service and acc books.
the exhaust, i would not bother. it wont be worth the trouble to have an exhaust shop cut and paste it on your car. and even after that its gonna be really loud and annoying.
heres the dx-r site. my comp had too much going on at the time so i couldnt search my bookmarks lol
http://www.geocities.com/bellz252/index.html
Old Mar 3, 2009
  #275
thanks steve, i guess i'm SOL..
Old Mar 3, 2009
  #276
lordhelmet's Avatar
Perfect. Thanks a bunch!
Old Mar 4, 2009
  #277
rdlarson's Avatar
rdlarson is an unknown quantity at this point
Yeah!!!!!! I aquired a 89 1.5 dual point lx I have been running it for 6 months and It get's about 35 MPG. Did some work Head gasket,tires,tune-up,water pump...ect...
Runs great switched over to all K&N filters, and good oil.....What should I do to get some
Extra zip
Old Mar 4, 2009
  #278
did you do any ignition system upgrades?
Old Mar 4, 2009
  #279
sethro's Avatar
sethro is an unknown quantity at this point
Hey Gear
I'm really wanting to get some VW side markers, you know the chrome bulb ones found on most Jetta's and Golfs. The only reason I'm not going JDM here is because they stick out too much, the V-dubs are kind of discreet. Look better too IMO
What do you think man?
Old Mar 5, 2009
  #280
jkjllkj's Avatar
jkjllkj is an unknown quantity at this point
Lightbulb Who needs that much velcro?
Why would anyone need that much velcro? These guys sell it by the roll http://www.liangdianup.com/miscellaneous_1.htm and is
hook and look and velcro the same thing?
Old Mar 5, 2009
  #281
well it wont really work because the vw ones are flush with the body. so unless you can cut a perfect hole in the fender, it wont work. and they are very dim cause of the chrome cover over the amber bulb. i have the clear si sidemarkers with amber led bulbs and they blend in really well (at least with silver paint). i can take some pic if you want.
Old Mar 5, 2009
  #282
fullgrown's Avatar
<---- I am really this short in person!
fullgrown is an unknown quantity at this point
gearbox,
couple days ago, all of a sudden my brake light started coming on and going off randomly.
is this a serious problem? could it suddenly hardbrake on me? or is it just the line messed up?
or how can i fix this problem?
Old Mar 5, 2009
  #283
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
rear brakelights or the brakelight in your cluster? no your car wont suddenly brake on you.
Old Mar 5, 2009
  #284
hey steve, i got a question about fog wiring. when you have an existing fogs and you're replacing your fogs with different bulb/connection. do you have to remove the existing then rewire the new fog harness (too much work) OR can you just do the short way and cut and reconnect the new end connectors to accomodate the new one?
lmk ******
Old Mar 5, 2009
  #285
sl33pyriceboi's Avatar
hey steve. i got the LOAD FLASHER RELAY for me leds...where does it go on exactly?
Old Mar 5, 2009
  #286
sethro's Avatar
Yeah if you could that would be great, how much did you buy them for if you don't mind me asking
Old Mar 5, 2009
  #287
fullgrown's Avatar
it's my brakelight on my cluster. so if that red brakelight on my cluster doesn't bother me, i'm good?
Old Mar 5, 2009
  #288
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
Not a 100% sure but you do mean your parking brake right? If that is the case you either have a connection that somehow got crossed or shorted. The other possiblity is that the connector at your brack is actually loose. You can check this by taking apart your center console and see how much you have to move the break to set the light on your cluster off. It may be different per car but should be similar. If this gets you anywhere or if you have no success at all it may help figure out another problem.
Old Mar 5, 2009
  #289
for BRAKE light on cluster, it could either be a loose connection with the ground wire going to the e-brake (look under the console and check), or you actually have a problem with the braking system. the light also comes on for mechanical problems too i believe. does the light always turn on and off properly when you move the e-brake up/down?
for fog wiring, if you already have a complete wire harness with relays installed, its fine to just cut the old connector off and wire the new one at the end. same idea, different connector so long as the wattage is still around 55w and you still only have two bulbs, one on each side.
flasher goes in the fuse box under the dash (above the brake pedal). its a pain to get to cause you have to loosen a screw and then forcefully pull it down carefully cause all the wires get tangled. dont pull it too far or you may never get it back in. the flasher is a black box looking thing you unplug and put the new one in. check the diy hyperflash for the exact location in the fuse box.
sidemarkers i paid around $25 for the pair i believe, and you need to get the bulb sockets too for i think another $5. just look up a 2004 civic SI or something to find em. the leds are just those pnp bulbs at autozone with 4 leds on each bulb.
Old Mar 5, 2009
  #290
sethro's Avatar
That looks pretty clean Gear, did you cut out your fender by yourself? See I'm kind of worried about it rusting a couple of years down the road, maybe if I primed and repainted it.
Old Mar 5, 2009
  #291
yeah i cut it with radioshack sheet metal puncher, its really rough and i had to use glue to hold the lens on, but i painted around the edges before installing so it shouldnt rust too badly. just use touchup paint around the sides that are bare metal.
Old Mar 5, 2009
  #292
sethro's Avatar
Alright thanks man, this weekend I'm going to give it a shot.
Old Mar 5, 2009
  #293
Old Mar 5, 2009
  #294
hello i answered that already lol. okay fine since you too lazy to search dont forget to spread open the tabs before pulling it.
Old Mar 5, 2009
  #295
^oh no you didnt just use the "search" on me...HAHAHAHA
but thx again steve, ur awesome
Old Mar 5, 2009
  #296
fullgrown's Avatar
it doesn't turn on and off properly when i move the e-brake up and down. it'll randomly turn on and off whenever i'm driving.
Old Mar 5, 2009
  #297
sounds like the ebrake ground wire then. its prolly loose, it connects with a spade type terminal. but you gotta take the console off to be able to see it. its right next to the boot part at the bottom somewhere, the only single wire in that area.
Old Mar 6, 2009
  #298
Hey gearbox, looking for a wire tuck/fuse box relocation/battery relocation on a 6th gen. I can do them minus the fuse box without any help but you know how much easier things are with help. I more concerned about moving the fuse box and planned on putting it into the glove box. TIA.
Old Mar 6, 2009
  #299
hmm im not sure ive seen that done before.
Old Mar 6, 2009
  #300
Yeah that was what I was sort of affraid of. I know alot of people do the relocation but I can't find any diys for it. The only reason I want the box in the glove box is just incase I need to get to it ever. Would you have any idea of where to start at?
