Ask Me About DIY Stuff V2!
Old Nov 4, 2008
  #181
Running Riot's Avatar
^Warranty voider
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
Re: Ask Me About DIY Stuff V2!
trying to fab a pressurized box for my intake, thought about going to a GSR OEM box. any ideas? got some drawings on cad.
Old Nov 5, 2008
  #182
yeah airbox type setup, someone here modded the gsr intake box. but really its not gonna help much. the stock system is basically the same thing. were talking a few hp here not worth the effort. if you want a different looking intake with a box, get the volant.
Old Nov 5, 2008
  #183
^Warranty voider
im running a conical filter now and im looking to quiet the b20 down as much as i can. im not worried about a 3 hp drop to be honest. the factory airbox makes more torque anyways. ill look into the volant. thanks
Old Nov 5, 2008
  #184
Krieger's Avatar
Krieger is an unknown quantity at this point
err... if the company is based in japan... and has a branch here... and they deliver to residence or bussines... why not?
thats kinda like saying i cant get a custom leather seat made for me in Italy and they won't ship it to my door...
and on the drive home.. it sounded like ***. alot of vibrating now, when i cruise, and it sounds like metal sliding or knocking on metal...
everyone i know says to let my warranty fix it... but idk... i mean, i COULD let them fix it, and then just do a tranny swap, OR, i could replace the engine...
hmm...
1.2k vs. 5k...
also, any DIY on tranny swap yet? lol
Old Nov 5, 2008
  #185
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
ok believe what you want then
Old Nov 14, 2008
  #186
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Hey gearbox, I've been researching possibly doing a TSX retrofit what bulbs and ballasts do you recommend?
Old Nov 14, 2008
  #187
you can get oem ballast 35w (matsushita are okay), or go with aftermarket 50w ballast which will make the bulb much brighter. ebay seller yourhid has the 50w d2s ballast kit. for bulbs, only use philips oem bulbs either 85122 or 85122+ are both fine and will handle 50w ballast.
Old Nov 14, 2008
  #188
Vinnie's Avatar
Is this the ballast kit you're talking about?
http://cgi.ebay.com/ebaymotors/50W-5...3A1|240%3A1318
And what is the difference between the 85122 and 85122+ bulbs?
Old Nov 14, 2008
  #189
yup thats the one, be sure to specify you want d2s kit so he includes the free adapters. do not use the bulbs that come with the kit. they are junk. the philips bulbs are pretty much the same, they both have the same life hours and lumen maintenance, the only thing is the + bulb resists colorshifting (where over time, the light turns whiter). so if you want more yellowish light over the course of the bulb life, get + bulb. if you want them to shift to a whiter color, get 85122 regular. here are the official specs, but with error margins they are basically the same. 85122 is 4100k color temp, 3200 lumens. 85122+ is 4300k and 3400 lumens. alot of people dont like the + bulb because the color looks too much like halogen. the regular bulb starts out yellow too but after they get "broken-in" they look whiter.
for example, this is a stock new bulb
and this is after 100+hrs of use where it colorshifted
Old Nov 20, 2008
  #190
sl33pyriceboi's Avatar
hey steve, have you ever used or have any knowledge of stuff called "hondabond" ???? i was thinking bout using it to seal my headlights...
btw, where did u get that 3m window sealer thing u used on ur headlights...and is it polyurethane?
Old Nov 20, 2008
  #191
its butyl based, similar to the nissan stuff. its constantly in a state of softness lol. got it from auto store in adhesive section. it comes as a roll. i didnt use it in the channels tho, i mushed it around the outside lol. its waterproof and sticks, but you can also peel it off slowly for later changes. but then you have to redo it with new ribbon.
Old Nov 21, 2008
  #192
its a roll?!?!??!?!?
wth? do u think homedepot or lowes will have them? i will check tomrow. i though it came in a tube and you had to use a gun to extract it...
let me google an image:
did you get this one or did it look simular?:
http://www.partsamerica.com/product_.../mmm/08612.jpg
Old Nov 21, 2008
  #193
yeah thats it
Old Nov 21, 2008
  #194
You VTEC...I-VTEC
i am curious about this...im not really sure what you all are talking about
Old Nov 21, 2008
  #195
01_EM2's Avatar
01_EM2 can only hope to improve
hmm...
1.2k vs. 5k...
x2 if not i guess i can do one once i find my tranny but ive never done a d.i.y. and i think id be lazy to do it
Old Nov 21, 2008
  #196
tranny swap is a ton of work and you cant just do it unless you have the right tools.
sniperscout its just headlight sealer.
Old Nov 21, 2008
  #197
You VTEC...I-VTEC
i understand but i do headlights a lot and am just curious as to your technique
Old Nov 21, 2008
  #198
well silicone around the outside didnt work for me cause it only bonds to the clear lens not the black housing. so i used the windoweld on the outside and just pressed it around the seams. its sticky and stays put, but you can always peel it off later. it can get a bit messy around the turn signal corner, and some of the goo is showing once the light is installed. but not too noticable.
Old Nov 22, 2008
  #199
^well, origionally ur suppose to apply it inbetween the crack where the origional sealer went.....then you close up the headlight and heat it up in the oven a bit so it can mold to the crack/holes
the reason why regular silicone is a bad choice is because when ur car when ur car is driven, it creats vibration and the vibration can cause the silicone glue to detach itself from the surface and cracks of ur headlight....and it doesnt reseal itself because it has harden, and therefore it creates lil holes and stuff...where ALOT of air and moisture developes and therefore it fogs ur inside of ur headlights...
also, its a very very good idea to put lil silica packs in ur headlight (or big packages)
many new HID OEM headlight manufacture puts silica packages in their headlights (the TSX and TL have BIG silica package in their headlight, i know because ive taken em out to get the projector)
wow wt a long post
Old Nov 22, 2008
  #200
i didnt put any silica gels and my headlights havent fogged once in 6 months, even when i was in humid illinois. i have that one vent hole in the back of the ebay lights that i enlarged and that seems to be all thats needed. since there is goo already in the channels, i guess you could just add windoweld to the spots that need a lil more. dont put too much or the headlamp wont go back together. i prolly shouldve done mine in the channels but i was in a hurry. maybe next time.
Old Nov 22, 2008
  #201
mine fogged =[
its pretty warm here in soCal and it started fogging when i went up to the mountains to snowboard =[
Old Nov 22, 2008
  #202
does it have vent hole? you cant have them totally sealed i had major fogging when i did that. it needs at least one good vent if not more. altho with tycs, i had lots of issues too. even with several vent holes they would fog when it got cold. i eventually ended up leaving the rear boot off.
Old Nov 23, 2008
  #203
^i have vent holes in mine. the rear has plenty. i got those gay projector ones on ebay made by sonar... i never did like sonar =[ TYC have always been awesome for me.... but im retroing OEM next....
Old Nov 23, 2008
  #204
i like your chrome sonars. but yeah i had the black ones and had constant fog problems. you could try just leaving one vent hole near the turn signal spot and close the rest. that way you set up a circulation where hot air from the headlamp moves to the vent hole and forces out colder air. too many vents isnt good either it will just let all the outside moist air in.
Old Nov 23, 2008
  #205
hey steve just wondering, how is ur "oem" style clear headlights holding up?
Old Nov 23, 2008
  #206
they are still good, sometime i wanna buy new ones and swap the lenses cause when i cleaned the grease off the back, it scratched them. not bad enough to matter, but still. i would prolly get the oem style ones for $110 with the amber and swap the whole trim and lens together. the old headlights tho are pretty much holding together with silicone cause the stock adjusters both broke lol. but as long as it doesnt fall apart ill be fine. its not something i wanna redo.
Old Nov 23, 2008
  #207
^i hear you...
anyways i just bought some BOSCH ICON wipers... i personally only intend to use them for 3-6 months and then imma try to swap the blade with some PIAA silicone blade... i just love how the ICON looks so much....
its mount is cleanest/low profile mount for its kinda "flex" wipers...
wt do u think steve? you think they're swappable?
Old Nov 23, 2008
  #208
i tried all those and to be honest the one i like the best by far is the bosch micro-edge. i hated the icons and a bunch of other brands. the micros gave the smoothest wipe without chatter and lasted the longest for me several months before the rubber warped. they also look the best imo.
Old Nov 23, 2008
  #209
saylorboy's Avatar
saylorboy is an unknown quantity at this point
Just installed a Pioneer BT700 NAV/CD stereo in my 2000 Civic. After getting it installed, I checked to make sure all worked EXCEPT the turn signals. I didn't think to check since I did not touch the turn signal wiring, I don't think. The wiring for the radio required 2 modifications beyond the standard wiring harness: a splice into the rear light for the GPS (spliced into the green and black wiring going into the harness at the rear light in the trunk), and a splice into the red and green wire for the parking brake (spliced about an inch from the parking brake itself, inside the console). Like I said, everything works, as far as I can tell, except the turn signals. I read elsewhere that a similar problem happened and it was the backup fuse. I checked the turn signal fuse as weall as the backup lights fuse, and all was normal. I disconnected the parking brake splice, per someone's suggestion, and it made no difference either. I reattached the splice for now. Any help? Also, can you tell me a cheap place to get clean sunvisors to match my stock ones? Locally they are crazy expensive.
Old Nov 23, 2008
  #210
speedfoos's Avatar
Hey Steve, I've got a set of mint lenses left over from my accident. They're yours for the price of shipping if you want them.
