Ask Me About DIY Stuff V2!
Old Mar 6, 2009
  #301
KcRidin09's Avatar
KcRidin09 is an unknown quantity at this point
Re: Ask Me About DIY Stuff V2!
Yea I tried searchin the site for this DIY. But could someone tell me or give me a link on how to remove all of my interior trim peices so I can paint them. Thanx for any help guys.
Old Mar 6, 2009
  #302
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
As far as I know there is no real diy for it but you should look into finding a helms manual for your specific year. Thats the easiest way. Other wise you can look for diys on each part of the interior. But if you don't feel like looking for either of them, you can always start pulling the panels off one at a time. Just be very careful and if you feel resistance look for screws or bolts first. Some just need a little bit of force to pull the clips off. Good luck.
Old Mar 6, 2009
  #303
yeah you can prolly figure it out on your own. like in the rear, the cushion comes out first, then the side pieces around the fold down seats, then the upper plastic pillars, and then rear deck. front panels pretty much just pull off. almost everythings held in by clips.
for the fuse box, i wouldnt know where to start. the power wires are easy to extend, but its the big loomed one thats gonna be a pain cause im guessing theres 20+ wires all wrapped together.
Old Mar 7, 2009
  #304
Linked's Avatar
Linked is an unknown quantity at this point
Hey guys, I recently bought some side mirrors that have leds for turn signals.
I have a white, black, and blue wire leads coming from the led's (black most likely ground).
i dont know where i could be able to wire the turn signals up at. i attempted to try the turn signal going to the hazard switch but no go (i assume i need to get a power source first and ground it as well)
could anyone with any knowledge on it help me out? thanks
ALSO, im assuming i can simply wire them up to the turn signal bulbs but would have to run them to the under dash fuse box
Old Mar 8, 2009
  #305
first test what the wires do by using the battery. then once you know, run them to the proper power sources. you can tap each power wire to the factory turn or park wire. im guessing you have the dual color ones and white and blue wires are power, one for each color. so you can wire one color to turn signal and one to park light if you want.
Old Mar 8, 2009
  #306
sl33pyriceboi's Avatar
two ways you can do this.
get the signal power from ur turn signal, run them into and under ur dash out to ur engine bay...
or
you can take out ur center guages (speedo) and the left/right turn signal wires are there.... you can tap their power.
check this thread, the diagram is on there somewhere
https://www.civicforums.com/forums/4...faq-video.html
as for the white and blue wire, i dont know. only 1 of them is the power. check it with a 12v source to see which turns on.
Old Mar 8, 2009
  #307
Originally Posted by Polo2k4
the only thing i have beside diagrams is this, which was previously posted..
;GREEN Connector:
Blue: From ECM/PCM, Tach input signal
White/Red: Constant 12 v +
Yellow: Switched 12V+
Blue/White: From ECM/PCM And VSS input signal
Yellow/Black: From fuel level sending unit
White/Green: From multiplex control unit
Black: Ground
Pink: (Canada Vehicles only) Washer fluid level switch
White/Blue: (Canada Vehicles only) DRL Control unit
Black/Yellow: Security control unit
Blue/Yellow: Cruise control unit
Pink/Blue: OPDS unit (Side airbags)
BLUE Connector:
Black: Ground
green/orange: From ECM/PCM
Blue/Red: From ABS Control unit
Pink: From SRS unit
Red/Black: Supplies 12V+ for dash backlights
Red: Supplies switched ground for dash lights
Green/Red: Left turn signal indicator
Green/Yellow: Right turn signal indicator
Red/Blue: Combination light switch
Blue/Orange: Immobilizer control unit
Red/Yellow: From no 15 fuse under hood
White/Red: From no 9 fuse under hood
Yellow/Red: From oil pres switch
here is the diagram if you have a 03+ civic
if u have a 01-02 its still the same
just it might be on the green connector instead.
Old Mar 11, 2009
  #308
dc5_dy's Avatar
dc5_dy is an unknown quantity at this point
do you know hwo to remove the climate control panel...? i need to replace some bulbs on the fan switch... thanks.
Old Mar 11, 2009
  #309
jimmezero's Avatar
jimmezero can only hope to improve
hey im swaping my 96 civic ex auto to a manual. im putting the same year motor in it. i need to know what do i do with the two sensers on top of the clutch pedal? any info will help thanks
Old Mar 11, 2009
  #310
its basically the same method u would have with a radio install...
https://www.civicforums.com/forums/2...t-install.html
once u have done that, take a FLAT screw driver and pry around ur centerconsole and pop it right off.
Old Mar 11, 2009
  #311
ur not gonna get much help here. i suggggest going on http://www.honda-tech.com/ and asking
Old Mar 12, 2009
  #312
KcRidin09's Avatar
Hey guys, Ive got a few scratches and what not that I would like to get touched up on the car, My question is would it be best to use touch up paint w a brush or get some touch up in my paint color in some rattle can. and if I want it to look decent should I get some automotive clear coat too???? Thanx for any help fellas.!
Old Mar 12, 2009
  #313
if they are very small size touchups like a chip or something, the brush will be fine. you cant really just spray away with a rattle can and expect it to blend in the surrounding panels. best left to a body shop.
Old Mar 12, 2009
  #314
strider1's Avatar
strider1 is an unknown quantity at this point
Saw that you posted in my thread here regarding these types of clusters....https://www.civicforums.com/forums/1...th-sedans.html
but figure I might as well post here.
I was looking at the cluster taking it apart but I'm kinda unsure how to take it apart. I want to change some of the lighting and what not but I don't know how to take off the (faceplate, paper thing?)...because the needles are attached on. Am I just supposed to pull the needles off? Because thats the only thing thats holding it together. The other way I guess I could take it off is unsolder the joints on the back of the chipboard...
do you know how to dissemble this thing?
I was looking at PaCiFiKbAllA cluster in his avatar it he looks like he did it as well but im not sure how to do it. i pm'd him but he hasnt responded yet.
also, when im swapping clusters...do i have to resolder wires or can i just twist wires together or what?
Old Mar 12, 2009
  #315
ya ive taken them apart a bunch of times, usually it works fine afterwards but you gotta be careful. the needles need to be pulled out and put back in the same direction. you have to use thumb and first two fingers to grab the buttom and then push up slowly using the bottom of the gauge for leverage. once needles are out, rest is pretty easy. some faces are held to the plastic light guide with glue, others just pull off. there are also screws in the back once you pop the cover off and that will cause the whole thing to come apart.
Old Mar 12, 2009
  #316
strider1's Avatar
thank you so much.
i was afraid i was going to break it because i was trying to lightly pull them off and then kept trying and applying more and more force. I was trying pretty hard and i was like hmm maybe this isnt the way your supposed to take it off ha
glad to know though.
but yeah whenever swapping the clusters, do you have to do any soldering or anything like that?? or can i just twist the wires together or what not?
Old Mar 12, 2009
  #317
strider1's Avatar
thank you so much.
Old Mar 13, 2009
  #318
like swapping the circuitboards? or the whole clusters? as long as you swap with the same style, you just plug in the connectors. all 01-02 lx/ex and 01-05 dx/vp are compatible with the old style, while 03-05 lx/ex are compatible with new style. to swap old and new, rewiring is required.
Old Mar 13, 2009
  #319
02civicg5's Avatar
02civicg5 will become famous soon enough
hey is there a DIY for the rear LCAs??
Old Mar 13, 2009
  #320
fullgrown's Avatar
<---- I am really this short in person!
fullgrown is an unknown quantity at this point
Originally Posted by gearbox
sounds like the ebrake ground wire then. its prolly loose, it connects with a spade type terminal. but you gotta take the console off to be able to see it. its right next to the boot part at the bottom somewhere, the only single wire in that area.
well, it wasn't the ebrake ground wire. does the ebrake light come on on the console when the brake fluid is low?
well, i guess the car was trying to tell me to check the brake fluid. couple days ago i came down to urbana champaign from chicago (2 hour drive) to visit my brother. the next day i was trying to go and get something to eat, and i had to push the brake pedal to push all the way for the car to stop. almost got into an accident, came back to my brother's place and open the hood to check the brake fluid level...and..it's all gone...nothing in the reservoir. i think the body shop that changed my brake pads and rotors few weeks back, messed it up. they didn't tie a string to the caliper to not give stress to the brake line. they just let it hang by the brake line. maybe the hose is not joined tight to the caliper? hopefully the line didn't rip.
now i have to bleed the brakes. but the problem is that my brother doesn't have any tools here...no jacks, no wrenches...only few screwdrives, hammer, and a nose plier...
how many bottles of brake fluid do i need. yesterday i just bought one bottle (32 oz). and the way i bleed the brakes is from:
back passenger side
back driver side
driver side
then passenger side
right?
do i need any special tools?
Old Mar 13, 2009
  #321
KcRidin09's Avatar
Hey I was wondering if I could get some help, I've decided to get a front a rear PU Lip Kit. I was looking at the back of my stock bumper on how the rear lip would install, and I am wondering if it is going to fit right because my muffler tip is pretty close to the top of the stock bumper already.
Would I have to extend the hangers for the muffler??? if someone could help or maybe even show some pics I would appreciate it.. Thanx
Old Mar 13, 2009
  #322
yeah you may have to get new hangers (the longer rubber ones instead of short) or have a shop play with the bending. i had this problem with my aftermarket exhaust and lip and the shop just bent the hangers so it sits lower.
Old Mar 13, 2009
  #323
for the brakes:
supposedly the light is for brake fluid too, but i dont see a sensor in the brake fluid reservoir like other cars have. unless its a different system... the only way you could lose pedal pressure is if the master cylinder failed or you have a huge leak in one of the lines. you lose a bit of brake fluid everytime you brake if your pads are low, but that takes time and usually it will not drain the entire container. idk man, sounds more serious than you think. and yeah you need one bottle of fluid that should be enough unless you mess up. but i would find out how (or if) the fluid escaped, or if the master cylinder needs replacing. then youre really in for some fun.
Old Mar 13, 2009
  #324
KcRidin09's Avatar
Thanx for all your help gearbox!
Old Mar 13, 2009
  #325
rear LCA replacement i have no idea sorry.
Old Mar 13, 2009
  #326
jimmezero's Avatar
hey gearbox
im swapping my 96 civic ex auto to a manual. im putting the same motor in it and i got to the powersteering part. ok my old motor has a black and a green wire and my new motor just has the black wire and the plug is cut off of it. so what do i do now? do i have to cut and rewire them together? any info will help alot thanks
Old Mar 13, 2009
  #327
lordhelmet's Avatar
Gearbox, did you install your rear Poly bushings yourself or did you pay to have it done?
Old Mar 13, 2009
  #328
rears are just what came with the spc camber kit i guess. i think they are just rubber tho, maybe i should go check.
Old Mar 13, 2009
  #329
lordhelmet's Avatar
Not the camber kit. I should have specified. The trailing arm bushing in particular.
Old Mar 13, 2009
  #330
the SPC rear camber kit comes with (you can choose) either rubber or ploy
