Ask Me About DIY Stuff V2!
Okay since my first epic thread was deleted, we are gonna start fresh again here. This is for the newbies and anyone else who has a question about do-it-yourself mods and general civic info. I will do my best to try and answer, and other members are also welcome to post their input.
I hope the last few peeps who posted in the old thread will repost in this one. I did not get a chance to read all the questions before the thread went down. Lets get this thing rolling again!
Here is the original V1 thread archives if anyone wants to see it:
http://web.archive.org/web/200804062...diy-stuff.html
Re: Ask Me About DIY Stuff V2!
very funny theres a thread about that. and you already know how to do it
https://www.civicforums.com/forums/7...-retrofit.html
https://www.civicforums.com/forums/4...cs-inside.html
Hey Gearbox, for the 01 to 03 cluster swap, I don't need new blue & green connectors right? I just simply re-pin the ones I already have?
I just want to double check because a lot of the clusters on ebay don't include the blue & green connectors.
Thanks for your help.
yeah just repin. the plugs are the same for both clusters. just make sure and disconnect the battery before doing the wire swaps lol
Okay, I have an 01 EX, and the actuator for the power locks in the driver door has gone bad.
I have received a qouted price of $56 for this part at the dealership, and was wondering if anyone could point to an online retailer that has it cheaper.
Also, one last request if someone could post pics of what it looks like inside the door, and possibly some directions for replacing it.
Thanks.
Thanks.
hmm, i never replaced mine, but from what i hear its easy if you have skinny hands lol. its simple to remove the panel, then the plastic cover and you can reach in to change the part. hold the window from falling too. check www.hondaautomotiveparts.com for a cheaper price. alot of times they are 1/2 cheaper than local dealer.
dealer, and actually it was only the temp dial insert. i kept the stock ****. to most people it blends right in, its a tad more silvery tho than the stock piece. but it looks way better at night.
Do you happen to remember how much the dial insert cost you?
hmmm if its a little more silvery I may have to switch all three inserts. Little things like that tend to annoy me. haha
Thanks for the quick reply. I was wondering if someone could help me in ordering the correct part. I posted the link to the page of the site you listed that corresponds to door locks below.
The actuator is listed as parts #32 and #56. If I had to guess one of those parts is the drivers door and the other the passenger but I am unsure. Could some one tell me if I need to order #32 from the illustration (part # 375100) or #56 (part # 492185).
http://www.hondaautomotiveparts.com/...KS&vinsrch=yes
Also one last question, if I order the wrong part, what is the return policy like on that site.
Thanks.
Thanks.
Last edited by 04CivicLX; Aug 10, 2008 at 07:47 PM. Reason: fat-fingering the keyboard.
hmm not sure, you may want to ask the dealer to look it up for you first to get the number. it seems there is no distinction in the description. usually they put L or R for side specific apps.
for the heater dial, it was kinda expensive, like $20 i think but i cant remember. i thought about getting the others to match but they wouldnt work at all. the icons are in different spots and the AUTO is on them too since hybrid has different climate controls.
heres what i found, basically used 5 leds for each dial, behind each icon, and then two leds per button. it was a very tight fit but theres no other way. i used epoxy to hold them, altho i shouldve went with something better like silicone for a better bond. epoxy tends to crack easily but i guess its holding up okay.
Hello Gearbox.
Wondering if you could tell me how to adjust my door. I would like to be able to tilt the top of the door inwards if thats possible, to help it seal better. My door was messed up after having a towing company open my car after locking keys in there.
https://www.civicforums.com/forums/3...eaky-door.html
yeah thats gonna have to be body shop work if at all possible. i tried to do the same to my rear door to get it flush with the body panel, but couldnt do it. my front door is similar to yours too, i had to get it opened by locksmith and he pried it open, now the window squeaks when it goes up.
How do I mount an RSX rear bar to my 01 LX? If I am not mistaken the only thing that comes in the progress adapter kit are brackets to attached bar to lower arm. How do I go about attaching the bar to my chassis?
from what i just looked up, the lx has the same sway as the ex. I just mounted an rsx sway onto my ex a few weeks ago and it just bolted right up. I used the rsx sway bar and the rsx endlinks. I am not sure if you have to use the rsx endlinks though.
