UPDATE: Dual-groove pulley INSTALLED!!!
Old Apr 7, 2004
  #661
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Dober I can just keep going: Does this ring a bell also?
“ Originally posted by C2i0v0i1c
im actually gettting a code from this damn thing, barometric pressure code, still working on fixing that ”
a ha....i think im getting a code for that too!
So you had a AIT problem?
Damn it seems we had alot of the same problems.
So I guess I am not the only retarded one.
Old Apr 7, 2004
  #662
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
I was explaining what was going through my head initially and the reason why I installed it that way in my previous post. There was an INITIAL REASON for why I did that and that is what I posted. Osoboosted posted that after my install and after I had already thought about the best way to install it. Notice I said "supposed to fit". I had no reference to install it with so I used my head and came up with a leak-proof way to install it. You can find things to use at a local hardware store for oil fittings it's really not that big of a deal. But if it's all you have on me I guess you have to use it right?
I never said I didn't have any problems I said I installed it myself. My surging idle was quickly fixed by an adjustment of the throttle cable.
Where are you getting this turbo god ****? I never claimed to a turbo god? Frankly I'm flattered you would even think so! Thanks Guns.
Old Apr 7, 2004
  #663
guns's Avatar
Skyline R33
Originally posted by dober
Nope, running 8 psi daily now thanks to my ACT Streetlite flywheel and HDSS clutch. BTW guns I installed everything myself without the aid of the local speedshop. My car will be tuned in the weeks following the release of the AEM EMS.
Why are you so bitter? Could it be the public humiliation I've throw your way? Do a search on how I was the first to call out DH and then do a search on how Guns blindly followed the bandwagon pack. How's that magic intake manifold treating you?
BTW things were peaceful Guns but you brought this back, remember that. Your choice to come back and start this up shows that you truly are what I called you before.
So you publicaly humiliated me for making mistakes.
You are a coward and an idiot who did the same excact mistakes that I did.
Go figue.
Like I said a thousand times:
Put up some proof or STFU
Old Apr 7, 2004
  #664
Your Parts Guy
Of course, it's the stupid IAT sensor code because SF doesn't provide a way to connect the IAT sensor to the charge pipe.
You are missing the point junior. You retreated to your local speed shop to fix your problems. I researched and fixed mine on MY OWN.
Old Apr 7, 2004
  #665
Your Parts Guy
Go figue.
Guns, my car ran and boosted fine after I fixed my surging idle. Hell it boosted fine even with the surging idle. My mistakes were not fixed by someone else.
Old Apr 7, 2004
  #666
reytito's Avatar
um...mods....do yer thing.
Old Apr 7, 2004
  #667
C2i0v0i1C's Avatar
SuperMODrizd
are u trying to tell me something, bc that was fixed along time ago,
and another thing........hit 1 bar and then come talk to me
Old Apr 7, 2004
  #668
Project2k2's Avatar
besides the fact you all went way off topic. Don't tell me I haven't read the posts. I've read every last one of them.
I know that Prod got a dirty block and a messed up head. I know that one other person complained about their head being all messed up with metal chips inside of it and such.
What I don't see is the other 100 customers who ordered something from them on this site complaining about their product.
Old Apr 7, 2004
  #669
Your Parts Guy
One of DH's biggest supporters, Gearbox, admitted he uses the pulley as a paperweight. How many people don't have their spacers?
Any topic with DH has turned into a flame war and I'm done with it. I've more than said what I needed to say about them and whoever listened ended up saving money. That's it I'm done talking about or replying about DH.
Old Apr 7, 2004
  #670
Project2k2's Avatar
^^ Good, then it's my turn to get my point across without someone trying to bash DH.
DH racing sent out the pulleys with no problems. Later on he discovered there MIGHT be a problem with the belts rubbing against a sensor. (kind of one of those necessary percautions....just incase) My pulley is just sitting on my work bench waiting for the spacer to come in. No doubt it's been a while....but what's the hurry....do you need to put it on NOW? How much would it kill you to take another step of safety.
Old Apr 7, 2004
  #671
Your Parts Guy
Why don't you keep your stock pulley and get a lightened flywheel? If you are staying n/a get the ACT Prolite you notice a big difference. Honestly it is the same principle, you are decreasing rotational mass and decreasing the amount of work the engine needs to do.
EDIT: this is not about DH it's about Project2k2's setup
Old Apr 7, 2004
  #672
guns's Avatar
Skyline R33
Originally posted by C2i0v0i1C
i hope that dyno is not an 11 psi dyno otherwise, u just wasted money. i made 215 on 11 psi no alcohol, and no timin taken out.
u can go look at my dynos and have a smart remark about the 10psi dyno only making 194, well my friend thats with alot of timing taken out. and my car is alot more involved with the parts and the way things are running, so u will not win a battle with me, and rightn ow ur not winning on as it is
You started in the same place as me with problems. I dont knwo everything and you didnt either when you started. Just like you I will one day be at 1 bar.
Does that make you a turbo god?
Stop swinging on Dobers nuts and let him put up or STFU!
Old Apr 7, 2004
  #673
guns's Avatar
Skyline R33
Originally posted by mootlif3
I still don't think the space is needed. I havn't had any problems yet and it's been about a month since it's been on the car.
Can you post of a picture of your pulley installed.
Maybe then all the haters on here will believe that it works and DH-racing did fabricate a good part.
Old Apr 7, 2004
  #674
runner1738's Avatar
even with reading all the other posts on stuff with Dh going wrong if we ever do get the spacers im going to have it installed and if it messed up my car ill drive to Las Vegas and demand they fix it
Old Apr 7, 2004
  #675
runner1738's Avatar
Old Apr 7, 2004
  #676
runner1738's Avatar
Old Apr 7, 2004
  #677
Ershall's Avatar
Ershall is an unknown quantity at this point
Hey, don't let me stop you....Just trying to make sure that you were worned if you weren't allready aware. When DH bends you over, you can't say you didn't know it would happen to you as well.
What matters is the fact that DH f*cked up and is unwilling to fix their mistake.
Good luck with that one Project2k2
Old Apr 7, 2004
  #678
YS's Avatar
YS
YS is an unknown quantity at this point
JMO called, got the spacer ... BUT they said there's no 'KEY GROOVE' for the pulley or the spacer. so how do you install it?? probably it's already mention, BUT i really don't want to read all 678 replies ... can ne1 explain it to me again????
thank you kindly
EDIT: ... My Bad ... still no Spacer
Old Apr 7, 2004
  #679
runner1738's Avatar
there is no key way for this pulley its just supposed to stay on or something like that, hope mine is there as well, and hope the spacer is right
Old Apr 7, 2004
  #680
czechcivic's Avatar
czechcivic is an unknown quantity at this point
Does anyone have apic of what a keyway looks like like.I have no idea...
Old Apr 7, 2004
  #681
DistinctiveBP's Avatar
Shows No Remorse
DistinctiveBP is an unknown quantity at this point
Old Apr 7, 2004
  #682
mootlif3's Avatar
mootlif3 is an unknown quantity at this point
A friend and I couldn't get the pulley to come off. There is a special tool to keep the pulley from giving and we couldn't find it anywhere so I took it to a friend of mine's shop and he put it on for $20. I'll take a picture when it clears up, it's kinda dark now and it's been cloudy all day.
Old Apr 7, 2004
  #683
guns's Avatar
Skyline R33
No leaks here boss. It's not in backwards I installed it a different way for a reason. The return line connects directly to the fitting and has a straight shot into the oil pan on my setup. On your setup the oil line connects directly to the fitting but has a chance to leak where the fitting meets the pan. Mine has no chance of leaking because the fitting isnt pushed up against the side of the pan in goes through the pan. Sorry man I don't call that a mistake I call it working with what you are given and making the best of it. During installation I thought about what COULD happen and decided against conventional usage.
Ya I remember that problem you had that you couldnt rev past 5k rpm. I also remember that I was the one that told you how to fix it. I can find the post if you like?
I did not get a fitting at all from SF I had to make do without. I made my own weldless fitting. All parts from autozone and no leaks. Here is a picture of the parts.
Old Apr 7, 2004
  #684
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
a keyway is a slot for a key- which is a little chunk of metal.
Old Apr 7, 2004
  #685
The stock pulley has a keyway to hold it in place. I guess the DH pulley is No keyway, so it just presses on flush against the crank. Josh said it was designed like that to be balanced.
Old Apr 7, 2004
  #686
YS's Avatar
YS
so there's not gonna be a problem installing without keyway?
i wonder where's my spacer
Old Apr 7, 2004
  #687
Your Parts Guy
Who cares both of our ways work flawlessly proving my point that there is not a CORRECT way as long as it works.
Old Apr 7, 2004
  #688
kileryoyo's Avatar
kileryoyo is an unknown quantity at this point
Ok here is sarcastic tone. Hmm the oem part and every other aftermarket pulley I have seen or used had a key what makes this one so special. Hmmm and the no key way is the first thing places around here look at before telling me they wont install it.
Old Apr 7, 2004
  #689
Someone got the spacer already. YS, I thought it was you? Josh says the pulley will go on fine, and the spacer doesn't make it fit any better. Just keeps the sensor from damage.
Old Apr 8, 2004
  #690
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
YS said JMO got it
