View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
Old Feb 9, 2018
  #931
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Re: Running rich- Please help!
Originally Posted by Megalodong
If the dealership service techs couldn't answer that then I can't. Hopefully, someone else here can.
How did you narrow it down to the ECU as the issue?
I tried replacing the ECU with a VTEC ECU when I installed this engine, but the immobilizer wouldn’t flash, so I had to wire a switch for VTEC.
Old Feb 9, 2018
  #932
Colin42's Avatar
Re: Could carbon on pistons INCREASE performance?
carbon build up can create hot spots in the combustion chamber and cause issues, yet another pointless idea
Old Feb 9, 2018
  #933
Slumpertcivic's Avatar
Re: Why VTEC and non VTEC pistons?
If it costs Honda just one cent less to make the lower compression piston vs the higher compression one.
times 4 pistons a car.
times millions of cars.
= one fat piggy bank
Economics is often reason why on a mass produced item.
Old Feb 9, 2018
  #934
Makes sense, but why would it cost Honda less to make higher compression pistons? Do they take more material to make? My consperiacy theory is that car companies use their highest quality parts, even within the same part number, on more expensive cars. So maybe the D17A1 rods are the “rejects” from the D17A2 that wouldn’t perform as well in a higher power engine, like “binning” computer parts.
Old Feb 9, 2018
  #935
So your thinking the whole Honda line is nothing more than binned aka rejected Acura parts?
Conspiracy indeed.
Old Feb 9, 2018
  #936
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
I don't have an answer but I would like to point out that using a 'cheaper' part requires maintaining separate parts and assemblies as well as maintaining the correct part in manufacturing and the aftermarket. The savings have to offset the costs and that is more than a couple of grams of metal.
My guess would be that the different pistons or compression ratios may help make emissions or fuel economy standards. Either of these can have big consequences.
I would also point out that your idea about 'rejects' and grading parts would require testing that could double the cost of the parts not to mention keeping track of separate parts with no visible difference.
Old Feb 9, 2018
  #937
Wankenstein's Avatar
I don't think any of his questions are his theory or ideas. I'm pretty sure he reads something online: fact, fiction or otherwise and regurgitates it here.
If I'm wrong I apologize to him in advance.
Old Feb 9, 2018
  #938
So is the ECU you referred to in post #36 a Vtec or non-Vtec ECU ?
Old Feb 9, 2018
  #939
Its a VTEC ECU from a 2005 Civic EX with a D17A2 and BMXA trans.
Old Feb 9, 2018
  #940
dude...
one engine have the VTEC, the other don't. Because they wanted to call it the "sport" version. The VTEC system alone is way more complicated and costly. why are you enven saying that about the pistons?
There's the sun roof (so the chassis will have a cut on the roof), there's the seats with arm rests, etc, etc. Changing the pistons is just small change in comparison!!!!
small field of vision, really.
Old Feb 9, 2018
  #941
spray carbon over your pistons next time you tear the engine.
end of discussion.
Old Feb 9, 2018
  #942
The Dong is in limp-mode right now and has no answers. Good luck..hope you get it sorted out.
Old Feb 9, 2018
  #943
Lube the Dong, it might function again
Old Feb 9, 2018
  #944
LOL.
Will Jiffy Lube work?..
Old Feb 10, 2018
  #945
*JizzyLube
Old Feb 10, 2018
  #946
Lol, ezone!
Old Feb 11, 2018
  #947
Re: My brakes don't work right
Originally Posted by ezone
I'll guess:
Initial shoe adjustment wasn't done correctly, or the brakes weren't assembled correctly.
Did I win?
Yes, you won. Not sure what you won though. I adjusted the brakes way loose. I tightened the adjustment, and the pedal feels more firm. However, I think I still have a problem. When I was putting the wheel on, I had an assistant hold the brake pedal so I could tighten the lug nuts. However, I could still turn the back wheels with a breaker bar with someone pushing the brake pedal, although there was a bit of resistance. And yes, I assembled everything correctly, and I used OEM Honda wheel cylinders, brake shoes and hardware. Any ideas?
Old Feb 11, 2018
  #948
Weak pedal pusher combined with no power assist.
Also, use a torque wrench to tighten lugs, not a breaker bar. 80 ft-lb.
Pull the handbrake. Does it feel right now?
Can you skid the rear tires using the handbrake?
Old Feb 11, 2018
  #949
When my cam sensor went bad, it would shut down the engine but also instantly trigger the MIL.
I installed the new cam sensor, and the engine runs perfect again. However, the fuel trim is still way negative. Any ideas? I think I'm going to rent a gauge and check the fuel pressure next.
Old Feb 11, 2018
  #950
Any ideas?
No, because you haven't done anything about figuring out why yet?
Old Feb 12, 2018
  #951
What would you suggest I do about figuring out what's causing the problem?
Old Feb 12, 2018
  #952
Colin42's Avatar
tl;dr
Why wrong sensor? Which exhaust manifold are you using?
Which injectors are you using?
How long has this been a problem?
What fault code did it set? (no code? no problem.)
If it has NOT coded that means the ECM is still controlling fuel delivery within its programmed fuel trim ranges. No problem?
Take a reading of MAP voltage with the engine at fully warmed up idle, all electric loads turned off. What's the voltage reading?
That's one reason I asked about MAP voltage
Old Feb 13, 2018
  #953
I just checked the MAP sensor voltage with the engine fully warmed up and idling in neutral with all loads off like I was told to, and the MAP voltage is 1.1 volts at idle, which seems normal to me. With the engine off and key on, the MAP voltage is about 2.8, which also seems normal to me. Any other ideas?
Old Feb 13, 2018
  #954
Have you ruled out leaking injectors?
Old Feb 13, 2018
  #955
No. But I don’t think that the injectors are leaking. If I pull the fuel line off the rail after the car sits overnight, there is still a little pressure on the system, so I don’t think the injectors are leaking. High fuel pressure keeps coming to mind, but I haven’t tested the fuel pressure yet.
Old Feb 13, 2018
  #956
What's your altitude?
1.1v is too high.
Ideally, I like to see 0.80-0.90v....
Adjust valves , tight valves can cause it
Have you checked cam timing?
Check EGR position, if it is slightly open or leaking that can cause it
Old Feb 13, 2018
  #957
1.1v is too high.
My altitude is 350 feet above sea level, so pretty low. I just adjusted my valves before taking the reading, so the valve adjustment is correct. The EGR is blocked off for now, so it can't be leaking. Any other ideas?
Old Feb 13, 2018
  #958
Cam timing?
Cam gear indexing off?
false read of MAP value, for some reason?
I'm at around 600-700 ft above sea level
Old Feb 13, 2018
  #959
Cam timing?
Maybe my multimeter is not accurate, I'll try a different multimeter. I don't suspect a cam timing issue because the engine runs so darn good, but I guess it's possible.
Old Feb 13, 2018
  #960
If the cam becomes advanced by a tooth it may not be real noticeable.
OTOH if the cam becomes retarded by a tooth it's usually real noticeable.
jumping 2 teeth or more can cause some PCMs to shut the engine down due to cam-crank signals too far out of sync...
