View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
Old Feb 8, 2018
  #901
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Re: Running rich- Please help!
Originally Posted by ezone
How about a spring loaded momentary switch, so you can't inadvertently forget to turn it off
Label it "EJECTOR SEAT"
LOL, that would be a good idea.
Old Feb 8, 2018
  #902
Why VTEC and non VTEC pistons?
I have searched for this out of curiosity and I haven’t found anything. But why would Honda go through the expense of designing 9.9:1 compression pistons for the D17A and D17A2, but use 9.5:1 compression pistons in the D17A1 and D17A6? It’s not like there is any measurable difference in performance or gas mileage between the two, so why would they bother? If they could get away with 9.9:1 pistons on the D17A2 with no problems, why wouldn’t they do it on all the D17 engines? I just don’t get it.
Old Feb 8, 2018
  #903
Re: Why VTEC and non VTEC pistons?
https://en.wikipedia.org/wiki/Honda_D_engine
Old Feb 8, 2018
  #904
I meant no real difference in performance between 9.5 and 9.9 compression.
Old Feb 8, 2018
  #905
Colin42's Avatar
The change in compression is a good chunk of what makes the difference in power. Basic engine math
Old Feb 8, 2018
  #906
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
Re: Bigger throttle body?
Boom 4 turbos!!!!
Old Feb 8, 2018
  #907
So maybe I could get 1 or 2 extra HP from putting in VTEC pistons?
Old Feb 8, 2018
  #908
piano55man's Avatar
Re: Lightweight valve adjuster screws
Originally Posted by D17VTECPOWER
You’re mean lol. I am saving for a K swap, but it may be a couple of years lol.
I have a K24W1 sitting in my garage. Missing some parts, but i'll make you a heck of a deal on it. PM me if your interested.
Old Feb 8, 2018
  #909
Thanks so much man. I sent you a PM. I’m quite interested.
Old Feb 8, 2018
  #910
Today I learned 10 horsepower is not a measureable difference.
Old Feb 8, 2018
  #911
Even if the relation between compression ratio and horsepower were linear, which it isn’t, you’d still only gain 4% power. The 10 HP difference is also caused by VTEC, different exhaust, different header, different cam, and probably other things that I’m not thinking of also. Compression isn’t the only difference.
Old Feb 8, 2018
  #912
Boom 4 turbos!!!!
LOL! Stop right there, dude!!!!
Old Feb 8, 2018
  #913
you have a D17A2 engine, why are you even looking into that.
get a D17A2 ECU and fix what you screwed up first!
Old Feb 8, 2018
  #914
piano55man's Avatar
http://noriyaro.com/2015/01/quad-tur...gs-2jz-silvia/
just saying...
Old Feb 8, 2018
  #915
I'm just curious why Honda made 2 different totally interchangeable pistons with such slight differences.
Old Feb 8, 2018
  #916
dsm482's Avatar
dsm482 has a spectacular aura aboutdsm482 has a spectacular aura about
who knows, they use different algorithm for the ecu, fuel trims, its tied with emissions mpg ,.. diffrent valves , cam it all affects the end result... I am sure there was a reason...
Old Feb 8, 2018
  #917
if you have that much spare time, go fix what is wrong in your car, the correct way
did you ever tow the car you were planning on towing with your civic?
Old Feb 8, 2018
  #918
GolNat's Avatar
Prelude Owner
Because they have a bunch of wacky engineers that work for them that just like creating extra parts for no reason except to confuse us.
Old Feb 8, 2018
  #919
Bull. Butter.
You've been making threads about wanting to blow big balla dollas on insane tweeking for minuscule, nearly immeasurable gains in either RPM or HP.......and now here you are totally dismissing the absolute most basic fundamental time honored method of increasing power.....?
Have another blast, son.
Some spend a lot of money for even smaller gains.
Old Feb 9, 2018
  #920
Could carbon on pistons INCREASE performance?
I know that carbon in the combustion chamber of an engine increases its compression, possibly enough to cause knocking and pinging. But if an engine has enough carbon on the pistons to increase compression, but not enough to make it detonate, could the carbon theoretically improve the engine’s performance by raising compression? I understand that the carbon can effect the engine’s performance by restricting flow, preventing valves from sealing and things like that, but presuming that the carbon is only on the piston tops and cylinder head, could performance possibly be improved?
Old Feb 9, 2018
  #921
Wankenstein's Avatar
Re: Could carbon on pistons INCREASE performance?
Where's the cutoff point of risk vs benefit and how do you control the amount of carbon buildup?
Old Feb 9, 2018
  #922
I am NOT going to change my pistons, I’m just curious. I don’t have the time or desire to tear my engine out and disassemble it again. And no, I didn’t tow the Civic home yet. I am going to tow the Civic home when the weather warms up.
Old Feb 9, 2018
  #923
Bull. Butter.
I am not saying that increasing compression won’t increase power, it obviously will. I am simply saying that a 4 percent increase in compression won’t produce any significant power improvements. The relationship between compression ratio and power is far from linear, so a 4 percent increase in compression would create much less than a 4 percent difference in power.
Old Feb 9, 2018
  #924
Not sure, and you don’t. I am just asking a hypothetical question.
Old Feb 9, 2018
  #925
and I returned the favor..so what's your answer?
Old Feb 9, 2018
  #926
[QUOTE]I don’t know. Could carbon buildup hypothetically improve performance under the right conditions?
Old Feb 9, 2018
  #927
Go put in the time and work yourself on your car's engine to find the answer. When/if you get the answer then post it here.
Old Feb 9, 2018
  #928
Originally Posted by Slumpertcivic
When my cam sensor went bad, it would shut down the engine but also instantly trigger the MIL.
Huh. Mine never set a code when the cam sensor was loose. I confirmed that the cam sensor was moving and causing the engine to die. I started the engine, set the handbrake, put it in D and wiggled the cam sensor with the engine idling. I could consistently kill the engine my moving it since it is loose, but it never set a code. Go figure. Maybe it never set a code because the sensor was electrically fine, but physically broken and moving around.
Old Feb 9, 2018
  #929
Apparently it isn't after I read up on it. I took a guess because 5th and 6th gens are. Anyway, if you ever have an ECU issue just purchase a used Honda OE or OEM one.
I tried to replace the ECU. I bought a used one, but the Honda dealer apparently couldn’t get the immobilizer to flash. What would cause the immobilizer to not flash?
Old Feb 9, 2018
  #930
If the dealership service techs couldn't answer that then I can't. Hopefully, someone else here can.
How did you narrow it down to the ECU as the issue?
