Ask Me About DIY Stuff V2!
Old Dec 16, 2008
  #241
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
Re: Ask Me About DIY Stuff V2!
I just finished installing my remote starter and I never appreciated the sheer amount of wires in a car until I finished it. I love electrical work and I have a good idea on water proofing. Are circuit boards my only option without being a complete pain? I'm unemployed right now so I'm looking for led diys right now. If it takes me 2 days a tube, I'm fine with it I just want to know if there is anyway easier then soldering and shrink tubing the connections. The pvc tube I'm getting, I'm drilling holes where the leds would go, using silicone to water proof it, and putting clips in the side. I just wat to do something, keep the price down, and learn some things along the way. All input is greatly appreciated and I know you love leds in your car and I am actually using a lot of your diys for my 6th gen. If I like the work I did I'm going to write a diy for it and cost is already down so yeah.
Old Dec 16, 2008
  #242
lordhelmet's Avatar
I picked up a rear disc conversion and I have a sneaking suspicion that the calipers have been sitting for a while. I can't get the left caliper piston to push in so I can install new pads. It seems to be frozen in place. Is there any chance that when I put them on and hit the brakes the piston will unfreeze so it can be pushed in or should I just pick up new calipers?
Old Dec 16, 2008
  #243
um wishful thinking lol. you may be able to just replace the piston but imo, its easier and more cost effective to just get a new caliper.
about the leds, i would check led section of hidplanet.com forums for diys and also the sale forums if you need a bunch of those superflux leds for pretty cheap. usually you can get a tube of 60 for $20, but they only have red, red-orange, blue, and amber for the oem approved bright ones.
Old Dec 16, 2008
  #244
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Question: Did you get your service manual from handa-accessories? or is it atleast the same one?
Thanks for the...(insert high number here) time!
Old Dec 16, 2008
  #245
i got the service book from h-and-a. the electrical one (also oem honda) i found from ebay somewhere. its about 1/4 the size and has all the electrical wire descriptions, colors, and locations of harness and such.
Old Dec 17, 2008
  #246
lordhelmet's Avatar
Yep, going to have to get new calipers. Broke the ****ing vise trying to break the damn things loose.
Old Dec 29, 2008
  #247
Kalanicook's Avatar
Kalanicook is an unknown quantity at this point
hey gearbox and everyone else. I posted my problem in electrical forum.
https://www.civicforums.com/forums/1...c-si-02-a.html
check it and please help!
Old Feb 15, 2009
  #248
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
hey gearbox what did you use to seal up your headlights when you did your retro?
Old Feb 16, 2009
  #249
dannylortie's Avatar
dannylortie is an unknown quantity at this point
hey gearbox i was wondering if you have a DIY for ebay oem replica foglights? thanks
Old Feb 16, 2009
  #250
drunkenmagnum's Avatar
Dear Gearbox,
Please post a DIY on adjusting valves. I need pics too.
Your friend,
Drunkenmagnum
Old Feb 16, 2009
  #251
sealing headlights-use 3M windoweld butyl ribbon sealer comes in a roll at auto parts store.
ebay fogs-sorry thats a mess i dont deal with. instructions for oem fogs can be found here at www.handaaccessories.com and for the ebay fogs i recommend just making your own wire harness from a relay, fuse, and some wiring. use the harness trigger to control what turns em on or wire to a separate switch.
valve adjustment, you better be really good with a feeler gauge to want to diy this. have fun
https://www.civicforums.com/forums/1...djustment.html
Old Feb 23, 2009
  #252
Vinnie's Avatar
Hey Gearbox, so I ended up buying my ballast from yourhid and then the relay wiring harness from retrofit-source. Does my wiring picture below look right? And then the second picture with the spade connectors, do those spades just plug into my original H4 plug?
Thanks again for your help as always
Old Feb 24, 2009
  #253
well the short red wire coming from the fuse goes to the + battery terminal, the other black wire coming out from the relay is prolly a ground. and the spades are power and ground i believe that go to the h4 plug. but im not exactly sure, thats a weird wire harness. i guess the red spade goes to the +12v headlight wire (red or red/yel) and the black spade goes to the LO wire (red/wht). but i cant see how everything is connected to the relay so im not exactly sure.
Old Feb 24, 2009
  #254
sl33pyriceboi's Avatar
looks right. make sure u get the +/- from the origional bulb socket right.
Old Feb 24, 2009
  #255
cornd0g's Avatar
cornd0g is an unknown quantity at this point
so gear, what ever happened with those retrofitted lights ya got? =)
Old Feb 24, 2009
  #256
Vinnie's Avatar
awesome, thanks for the help guys
hey sleepy wanna help me with my retro? Im in the irvine area. haha
Old Feb 25, 2009
  #257
^what kind of help do u need?
i just finished my temporary retro last night....cant wait to put it on. i hate stock headlights =[
Old Feb 25, 2009
  #258
Vinnie's Avatar
haha I don't need help yet. I just started my retro cuz I finally got all the parts but its going slowly cuz I gotta wait to get the correct bulbs sent to me.
Actually, what did you use to reseal your headlights? I know gearbox recommended the 3M windoweld stuff but I can't seem to find it in this area.
Old Feb 25, 2009
  #259
^yea you cant. i searched everywhere.
go to autozone and look for "permatex BLACK SILICONE ADHESIVE SEALANT"
that stuff works great because:
1. silicone is organic, it wont corrode
2. its very very flexable
3. waterproof
4. (most important) its a BONDING+SEALING ADHESIVE, means that it'll glue ur lens/housing together. the regular "silicone II" stuff you find at homedepot seals, but donesnt bond to the plastic very well. and with alot of vibration while driving, it will start peeling and thus making room for water, and alot of moisture to go in.
note: yes you can reopen ur headlights later if you ever needa redo ur retro. just heat it up, and pry it open.
Old Feb 25, 2009
  #260
oh yea, make sure you buy 2 tubes (they are 3oz each tube)
for best results when in use:
1. fill a pot with water
2. put the two tubes in the water, turn the stove on.
3. let the water boil and heat up the silicone in there for 15mins
4. take the first tube out and use it on ur first headlight
NOTE: one tube = one headlight. it is more than enough, make sure you put it on GENEROUSLY.... when you close it up, it should come out just a lil:
5. tape ur headlights up with painters tape, to pressure hold the lens to the housing
let the silicone dry. takes 24hrs. then take the tape off and u are rdy for the install!
here is a sneak peak to my "temporary retrofit" ill post it up later
btw, these use to be my sonars
Old Feb 25, 2009
  #261
Vinnie's Avatar
Nice, thanks alot for the suggestion and pictures.
Any suggestions on how should I clean the projector lenses?
Old Feb 25, 2009
  #262
wear some latex gloves.
take out the lens and spray them with windex.
then use dish washer soap (excellent degreaser) and wash the lens well, and rise them off with DISTILLED water. if u dont hav distilled water, DRINKING water or filter water is ok...but they have minerals in them, but it wont hurt the lens. but distilled water is highly suggested.
(make sure u wash ur hands with dish washer soap and then put on latex gloves (ur hands ALWAYS have oils on it that will stain the lens)
Old Feb 26, 2009
  #263
ross3093's Avatar
ross3093 is an unknown quantity at this point
is there a DIY for swaping ground wires for copper ones? I guess making your own?.....
Old Feb 28, 2009
  #264
i sold the retro already, felt bad for blinding everyone all the time. but they were nice. too bad it looks like usps lost em tho im back to ebay replica oem lights which actually have decent output when aimed properly and using philips XP bulbs.
ground wires are easy, just replace the stock ones with 4 gauge stereo ground wire you can get from best buy or other stereo shops.
Old Mar 1, 2009
  #265
2000civicsohc's Avatar
2000civicsohc is an unknown quantity at this point
I just got some Omni front lower control arms, how hard is it to install, and how do you do it???
Old Mar 2, 2009
  #266
Vinnie's Avatar
Hey Gearbox how do I paint the tsx projector shields? Just any ol spray paint? Do I need primer too?
Old Mar 2, 2009
  #267
lower control arms i havent done, but seems like it shouldnt be too hard. you need alignment after youre done tho.
tsx shields, use hi temp black paint and sand the shields a bit first. dont forget to let them dry for a bit and then bake them before assembling. otherwise the heat from the hid bulb will cause the paint to cure and you will get haze on the inside of the lens.
Old Mar 3, 2009
  #268
i would paint them back side of the shield a blue color. that way, when people look at ur headlights, its actually has a hint of blue, but the output isnt affected.
make sure you buy some "exhaust ceramic paint" (autozone has them) because they can stand high temps. and yes, he does get hot as hell near the bulb.
Old Mar 3, 2009
  #269
lordhelmet's Avatar
This is a weird request and I am in no hurry to get it but can someone give me some measurements of where the holes for the rear sway brackets are? I need to know how far apart they are and how far up or down the holes need to be drilled.
Old Mar 3, 2009
  #270
check bellz DX-R site. i think he has a diy. i can look for the web address.
