First post! And.. issue. My 1995 Honda Civic..
Old Sep 27, 2015
  #241
Wild Cranker's Avatar
Wild Cranker is an unknown quantity at this point
Re: First post! And.. issue. My 1995 Honda Civic..
Question: Should Red Loc-Tite be going on threads that have been remedied to reliable service? (Damn I sound like I know what I'm talking about ther)
Old Sep 27, 2015
  #242
Originally Posted by ezone
If it has the correct size tap, why not use it?
I am still kind of an idiot. I thought there was a difference between screwing in a bolt I am about to cut (in 4 places? One on each side?) vs actually taping a bolt hole...
I'm about to videodocument in a second after I clean this one up a bit..
Old Sep 27, 2015
  #243
Hell no, not on head bolts.
Old Sep 27, 2015
  #244
If you have a correct tap, use it. It will chase threads.
Slicing up a bolt is for when you don't have the right tool.
Old Sep 27, 2015
  #245
So are you saying that I can put this file and saw away?
I thought we were gonna run it down each hole a few times.... not a tap..
Old Sep 27, 2015
  #246
Mad Dog Tannen's Avatar
The whole point of all of this is to get the threads straight, clean and smooth so that when you torque the bolts they do not catch on debre or imperfections and give a false torque value.
Tracing the threads with a tap straightens them better than a bolt can. Be gentle, you are using a hard steel bolt or tap up against soft aluminum. make sure all shavings and debree are clear before torquing.
Old Sep 27, 2015
  #247
Originally Posted by mad dog tannen
the whole point of all of this is to get the threads straight, clean and smooth so that when you torque the bolts they do not catch on debre or imperfections and give a false torque value.
Tracing the threads with a tap straightens them better than a bolt can. Be gentle, you are using a hard steel bolt or tap up against soft aluminum. Make sure all shavings and debree are clear before torquing.
^This.^
Old Sep 27, 2015
  #248
^This.^
I have very, very good information coming in just a couple of minutes.
Old Sep 27, 2015
  #249
Alright.. There are TWO videos here. And they aren't all "moving around," as some of mine were.
I urge you to watch this, as it may be a game-changer.. At least for me, I feel it is...
Video 1:
Old Sep 27, 2015
  #250
Video 1:
You guys are not going to believe this.. - YouTube
Are those stretch bolts?
Old Sep 27, 2015
  #251
Video 1:
Video 2:
Old Sep 27, 2015
  #252
Biff, From everything I hear.. No, they are not.
Old Sep 27, 2015
  #253
Is that a back to the future joke? My nick name is Marty, that is why I have that screen name.
I did a head on the same engine and thought they where stretch, maybe i can't remember so good. But if they are, make sure you get new ones, or you may get improper torque values as well.
Props for attacking such a large project, that car looks like it has seem some miles.
Old Sep 27, 2015
  #254
It is. And I LOVED the movie! 30 years.... this week....
Yes, I am uploading "play by play."
I have a Heli-Coil coming in the mail, and that tap/die set. ARE there advantages to using that vs cutting a bolt?
Old Sep 27, 2015
  #255
Old Sep 27, 2015
  #256
Old Sep 27, 2015
  #257
Old Sep 27, 2015
  #258
Old Sep 28, 2015
  #259
To anyone followjng... I want to get those holes ready for the screws today. Because, then, I SHOULD be able to put the head on.. TODAY.
I have a ton of MMO to substitute for transmission fluid and can run down and clean "mostly those two" .. The other holes really do seem fit.
Any tips?
Old Sep 28, 2015
  #260
Post 256 the bolt you show first appears to have a wad of aluminum stuck in the threads.....
Looks like galling of the threads...Was it tight to turn most of the way out as you were removing it?
Is this the bolt that was removed from the center front hole?
And the other bolt came out of the hole in the corner at cyl. 4?
Old Sep 28, 2015
  #261
Old Sep 29, 2015
  #262
The engine turns.
Old Sep 29, 2015
  #263
Old Sep 29, 2015
  #264
Old Sep 29, 2015
  #265
Did I miss something? Why are you filing the side of the head bolt flat?
Harp? Cool.
Old Sep 29, 2015
  #266
Harp? Cool.
It turns out I may not need that Heli-Coil. By filing the threads on one side, I can get the bolt to turn in the hole...
I am still copiously cleaning those two holes, I know that most of the funky color is the cleaners I sprayed in, but, they are getting super clean. Im letting those two holes soak in MMO overnight.
The head is very close to getting back on, and the idiot helper DESTROYED the BRAND NEW Head Gasket I bought.. Starting to think these acts were intientional (he cost me $90 on a hard to find good conditin part by setting it on fire in the engine on the other one) so he is gone.
Old Oct 2, 2015
  #267
I submit this for a guide I would be following for reinstallation of the head. HE USES THE SPRAY...
Old Oct 2, 2015
  #268
This may be a dumb question, but do you have a manual? It seems like most of the things we have mentioned, should be in the manual.
Old Oct 3, 2015
  #269
I just realized that we are the same age.
Question: If it were you, would YOU put this on the Head Gasket before putting it on?
Old Oct 3, 2015
  #270
Does the service manual direct you to spray goo all over the head gasket?
