Ask Me About DIY Stuff V2!
Old Apr 4, 2011
  #871
EM2 Rookie's Avatar
EM2 Rookie is an unknown quantity at this point
Re: Ask Me About DIY Stuff V2!
hey i got a question
i got a 2002 civic ex
and im planning to put in a sparco steering wheel with NRG quick release n short hub
but since i have an airbag in the OEM steering wheel
ho do i disable the steering wheel air bag, n still have the passenger air bag work??
( also getting 4 point harnness with aftermarket seats)
i know to disable the srs light on the dash u sauter a resister inbetween the wire
idk still thinking of what to do
Old Apr 4, 2011
  #872
the srs system will detect that no driver airbag is present, which will disable the whole system. i dont know of a way around this. just deleting the dash light icon will not do anything. The srs unit controls and is connected to all the airbags and seatbelt tensioners. im looking at the wire diagram but the problem is i cant make any sense out of it. wires just go from the airbag to th srs unit. and i dont know the specifics of how the actual airbag works to figure out a solution (i dont know whats in the airbag as far as electronics).
Old Apr 11, 2011
  #873
HG-2003Civvy's Avatar
HG-2003Civvy is an unknown quantity at this point
I installed my rear speakers (which was a long process which included drilling new holes to fit grrr lol) and put in a new deck last weekend. This weekend I'm going to tackle the fronts finally. I tried to pull the door off but the window handle (manual roll ups) won't pop off no matter what I do, all the screws are out on the door. What am I doing wrong?
Thanks
Old Apr 11, 2011
  #874
usually there is a c-clamp you have to pop off with a screwdriver by pushing it parallel to the door panel. once that is out, the roller will fall out.
https://www.civicforums.com/forums/2...dow-crank.html
Old Apr 17, 2011
  #875
irich25's Avatar
irich25 is an unknown quantity at this point
I was wondering if this is the right wire (blue wire sticking out???) where i connect the tachometer input wire for my remote start, also how do i test it with my DMM
Old Apr 17, 2011
  #876
gives me a chance to figure out what that is lol. i always see that wire and connector dangling in the fender lol.
yeah you were right, honda electrical manual says its the "test tachometer connector"
Old Apr 17, 2011
  #877
Maverickmonk's Avatar
Maverickmonk is an unknown quantity at this point
Dear Gearbox: I've read somewhere that the metra hybrid dash headunit kit (http://www.amazon.com/Metra-997897-H.../dp/B0002BESEQ) can be made to work with the standard consol, allowing me to keep the door pocket. Is this the case? If so, that would be wonderful, as I find the standard mount kit with the open pocket to be quite unsightly.
Old Apr 17, 2011
  #878
yeah the link you posted works just fine. alot of people have it. when you take the dash apart, only unscrew the stock radio from the bracket. the pocket is separate and has its own screws. then use the new trim piece on top with the aftermarket radio.
Old Apr 17, 2011
  #879
example from member rides. the two reasons i dont like it are the color is different than the dash and you cannot use the stereo trim plate.
Old Apr 17, 2011
  #880
Exactly the info I was looking for! Thanks!
I...must have missed that photo...
I think I'll go for it, since I personally think no trim-ring looks better than the other trim ring and having it sit uneven with the surface. I could always try to fiberglass and bondo some sort of trim ring up as well, I'm game for a challenge
Old Apr 25, 2011
  #881
irich25's Avatar
What color is the defog wire in the center console or close to it?
Old Apr 25, 2011
  #882
for the rear defogger, what exactly are you looking for? there are alot of wires that go to the different hvac control pieces and nothing specific for each button. its all internalized in the modules.
Old Apr 26, 2011
  #883
sl33pyriceboi's Avatar
dear gearbox,
how many stickers on my windshield do i have to put inorder to only gain 1/2 a hp?
Old Apr 26, 2011
  #884
irich25's Avatar
(-) 200 mA 2ND STATUS/REAR DEFOGGER OUTPUT
Old Apr 26, 2011
  #885
for the actual defogger circuit, the blk/yel wire comes from the fuse box (fuse 14, 10 amp) to the heater control switch and is hot when the ignition is ON. when you turn on the rear defog button, power goes from the heater control to the yel/blk wire, which connects to the rear window defogger relay. the relay opens, and power from another fuse box wire (fuse 11, 30 amp) activates the rear window antenna coil mounted in the trunk near the speakers, which then heats the window traces. the wire from the relay to the coil is black.
Old Apr 27, 2011
  #886
user 73802's Avatar
user 73802 is an unknown quantity at this point
Gearbox,
Is it easy to install a DC short shifter adapter?? (i was told the RSX adapter fits my civic)
and, can I install a DC short shifter adapter and a short shifter stick? (or do I have to install only one)
Thanks
Old Apr 27, 2011
  #887
sorry not familiar with that but i know there are a few diys floating around here.
Old May 9, 2011
  #888
civic0071's Avatar
civic0071 is an unknown quantity at this point
Hi Gearbox.
I ran over a big rubber cone in the middle of the hi-way and it broke part of my bumper and the plastic inner liner. I've searched this site and is having a tough time getting any info. Is it easy to replace the plastic inner liner or do I need to send it to a repair shop? If you do, can you give me a link or a step by step guide on how to replace it?
Thanks.
Old May 9, 2011
  #889
do you mean the black rubber strip on the bottom of the bumper? should be easy to replace with clips and bolts holding it. it is just an air dam and you dont really even need it under there. if you mean the large plastic lower engine covers, those arent too hard to change either. i think they are held on by those plastic clips. pics would be good.
Old May 9, 2011
  #890
wodie's Avatar
Innocent Bystander (For Now)
wodie is an unknown quantity at this point
hey GearBox, any specific air filter/spark plugs i should use? '05/LX/Auto
Old May 9, 2011
  #891
Kennykid2002's Avatar
Kenny the Ricer
Spark plugs, go with NGK Iridiums, or plats, if your a bit on budget
Old May 9, 2011
  #892
BlueEM2's Avatar
Whachya lookin at?
Every new member should read this thread from page 1-30. They will know more about their car than they care to lol
Old May 10, 2011
  #893
ngk or denso plugs are good, iridiums if you have the money but plain copper works fine too so long as you change it more often. air filter if its stock, napa gold (wix) paper filter is very good.
Old May 10, 2011
  #894
and the V1 thread from page 1-110 lol
Old May 11, 2011
  #895
wodie's Avatar
Thanks for the advice kenny and steve
Old May 16, 2011
  #896
civic0071's Avatar
Yes the large plastic lower engine covers, as well as the inner fender. Do I need to raise the car or not to replace them?
Thanks.
Old May 17, 2011
  #897
rasing car would be easier, but if you can slide under enough to see where the clips are, it should be doable. remember you need to also remove parts of the fender plastic above the wheel because it shares a few clips with the engine cover.
Old May 17, 2011
  #898
recojoe's Avatar
recojoe is an unknown quantity at this point
Alright folks.. I know that this is going to sound dumb.. But I need some help.. I am helping a friend clean out his brothers stuff.. ( Don't ask why ).. And he was really into Honda Civics... I think it was a 2003... As they have been cleaning out his stuff, there are boxes and boxes of stuff... Can anyone help us identify what some of this stuff is. I know what some of it is. Like a new hood, bumper and so on.. But there appears to be a couple engines and transmissions parts... Thanks a lot.. if you e-mail me at joepetri@hotmail.com or show me how to post the pictures here... Again thanks a lot
Old May 17, 2011
  #899
upload the pics to photobucket.com (free to sign up) and then post the pic links here.
Old May 27, 2011
  #900
c4zper's Avatar
c4zper is an unknown quantity at this point
Hey gearbox.
I seem to be having an issue with the odometer of my 01 civic odometer. I just realized that the backlight was not turning on while I was in the middle of testing / replacing a bulb for the speedometer. It still displays the meter readings, just not turning odometer backlight on at night. Know any idea? Thanks.
