PDA
View Full Version : Transmission swap
  1. Manual transmission search
  2. Tranny swap [solved]
  3. K series 6 speed on d17
  4. Auto tranny swap es1 to ek3
  5. Transmission Swap
  6. EM2 k series auto swap?
  7. bought 5 spd from picknpull
  8. EX Auto to LX Manual Swap
  9. 2002 trans swap
  10. Need help figuring out this dash harness
  11. Transmission problem
  12. 2003 D17A2 / BMXA Removal from top
  13. Trans swap with auto harness
  14. JDM trans help.
  15. Can I use a 01 transmission in my 04 civic
  16. will not rev past 4k engine/trans swap
  17. K series AWD in DC5/EM2/EP3/ES1
  18. D17a1 transmission swap
  19. Auto vs manual sub frame?
  20. Manual to Auto
  21. Compatible Transmissions?
  22. Need some conformation on k20a transmission options
  23. Jdm & rpm higher than normal
  24. What manual transmission do I have in my 2001 LX coupe?
  25. Original to JDM trans swap issue
  26. Automatic to manual transmission swap 2003 honda civic
  27. AWD Swap
  28. Jdm swap
  29. Transmission solenoid modification?
  30. Passing CA smog with SLXA
  31. 2004 civic auto to manual swap wiring problem [solved]
  32. 2001 Civic EX Transmission Replacement / Vibration
  33. Car Won't Go into Gear
  34. CVT swap?
  35. SLXA swap information
  36. 2001 Civic lx bmxa to slxa swap info needed
  37. 05 EX Tranny Swap
  38. 2005 Honda civic lx transmission going out. Can i replace it with a z6 or zc tranny?
  39. Auto to manual transmission swap. Help!!!
  40. Auto to manual ECU
  41. auto transmission
  42. D17 Xmission Compatibility
  43. Mismatched car transmission help
  44. D17a1 mt. vs at. Engine compatibility
  45. Difference Between Vtec and Non-Vetec Manual Trans
  46. 02 civic hybrid RS auto to manual swap???
  47. 02 civic auto tranny getting bad can get a 04 si motor and tranny
  48. Is it possible to put a 6 speed transmission into a 2003 Honda Civic EX?
  49. What series Transmissions fit a D17 engine?
  50. auto to manual conversion
  51. type s swap with automatic?
  52. auto to manual car wont start help
  53. Help with Swapping Auto Transmission
  54. auto to manual
