Transmission swap post information/Questions about automatic to Manual Transmission swaps
2001 Civic EX Transmission Replacement / Vibration
Old Aug 27, 2019
Watauga Frost's Avatar
Watauga Frost is an unknown quantity at this point
I just recently had the transmission replaced in my 2001 Civic EX at 184,000 miles with a "used" transmission with 85,000 miles. It comes with a 27 month warranty and unlimited mileage during that time. This was done by the local Honda dealership which was pricey but I was willing to pay for some sort of guarantees.
When I tested it out initially, it seems fine but there is a slight vibration when approaching 60 mph and above when under a load. I thought at first it may be an out of balanced tire so I had the tires rotated and balanced. ( A separate tire store did the free rotation and balancing ) So, I took it out again and have a tad less vibration but it is still there. Maybe I am being a bit sensitive but when I put a load ( as in going up hill or accelerating ) above 55mph - 70mph I do have some vibration still.
What could be causing this vibration ( not very severe but noticeable, like an out of balance tire ) ? What should I say to the mechanic at the dealership to investigate when I take it back in?
thanks
Old Aug 27, 2019
Slumpertcivic's Avatar
Re: 2001 Civic EX Transmission Replacement / Vibration
My first though is a transmission mount allowing little more vibration past. Those are seldom put back in the exact position they were before.
Old Aug 28, 2019
Thank You.
greyzz
May 29, 2018 08:01 PM
west77
Wheels and Tires
Nov 17, 2011 10:18 PM
ZSKCivic01
Jan 30, 2006 03:58 PM
Pluto
Jan 21, 2005 06:19 PM
opto_isolator
Sep 12, 2003 06:34 PM
