Transmission swap post information/Questions about automatic to Manual Transmission swaps
auto to manual car wont start help
Old Jan 6, 2010
boosted2cam's Avatar
boosted2cam is an unknown quantity at this point
sup everyone
im done with tthe swap now the car wont start...im using k-tuned immoblizer bypass...
still using AT dash harness and engine harness... is there any wiring i need to do?
running a MT ECU with AT harnesses
Thanks!!@!
Old Jan 6, 2010
subworm07's Avatar
subworm07 is an unknown quantity at this point
Re: auto to manual car wont start help
check you mailbox.
Old Jan 9, 2010
help!the guy that has my car said he hot wire the starter and fuel pump...so it turns over but doesnt start...?
do i need to ground anything or any kind of wiring?
Old Jan 9, 2010
subworm07's Avatar
tell him to put the wires back the way it was.
the only wires you ground is the two from the fuse box under the steering wheel.
Do that and the car will start.
Thats all I had to do.
is the Green key light flashing when you try to start the car?
Old Jan 9, 2010
subworm07's Avatar
check you mail
Old Jan 9, 2010
subworm07's Avatar
the wires I told you is for the Clutch pedal without that the car thinks the clutch is not pushed in and will not start.
Old Jan 10, 2010
lilmandrny's Avatar
lilmandrny is an unknown quantity at this point
does it get any power...I think your better off just getting the manual engine harness and keep auto dash harness and ground out those 2 wires under the steering wheel
Old Jan 11, 2010
do what gets any power?
well people said i can use the auto harness and all i have to do it ground those 2..hopefully it works
Old Mar 21, 2010
2002civicrider's Avatar
2002civicrider will become famous soon enough
Any luck? And have you grounded out the 2 wires in the fuse box under the dash?
Old Nov 1, 2020
B16teggy's Avatar
B16teggy is an unknown quantity at this point
what 2 wires are you talking about?
Old Nov 1, 2020
FRSam's Avatar
Click Here
It’s been 10 years lol
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
C6GrandSport
Apr 25, 2015 09:41 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
