Engine building Post information/questions about Engine Building here!
Ktuner and the D17
Old Oct 30, 2019
  #331
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
Re: Ktuner and the D17
sweet!
Old Oct 31, 2019
  #332
Marcelo Souza's Avatar
Marcelo Souza is an unknown quantity at this point
Originally Posted by piano55man
I'm going to start logging my progress as a beta tester for HA Motorsports.
Here is the low down:
AEM cam gear
ECU (not a D17 ecu) with the Ktuner board installed
Direct conversion wiring harness
My D17A1 w/260,000 miles currently has the following little mods:
Cold Air intake (cheap *** one from ebay)
2.5" exhaust with 4" Coffee can (again cheap *** one from ebay)
Full header with no cat...(yup ebay)
ARP headstuds...(non-ebay!!!)
Innovate LC-2 wideband
Battery is relocated to the trunk
I recently took the engine out and wiped it clean.
Since the engine was out....i installed a new water pump, oil pump, all new gaskets, Gates racing timing belt, fx racing stage 3 clutch w/8.6lbs flywheel, drilled the oil pan for a turbo oil line return and capped it.
The plan is to help get this new alternative ecu running efficiently then slap on an ebay turbo. i have a new fuel pump and 660 cc injectors ready to play with the turbo...
If you need help just ask I have build one and messed and tweeted it for 2 years
Old Oct 31, 2019
  #333
Yay I thought I was the only one that went off meta nice to hav e a buddy
Old Nov 6, 2019
  #334
piano55man's Avatar
And it's back in!!!!
Old Nov 6, 2019
  #335
piano55man's Avatar
Time to detail the engine bay a little bit.
New fuel pump comes in tomorrow and then it'll be ready to start up!
Old Nov 6, 2019
  #336
Nelrodjr's Avatar
Nelrodjr is an unknown quantity at this point
Looks good, what kind of pump you running?
Old Nov 6, 2019
  #337
Nelrodjr's Avatar
Who is gonna do your tuning? I might know someone that can do remote tuning. Very reputable and tunes safe.
Old Nov 6, 2019
  #338
just to let you know your going to want to get an oil cooler and install it so where in between before the oil gets to the turbo the oil get heated by the engine then supper heated by the turbo marking the oil super thin thank me later when you oil light isn’t blinking while your ideling
Old Nov 6, 2019
  #339
Nelrodjr's Avatar
Ok, will look at that. Right now I run 20w50 competition diesel oil Amsoil. I was having that problem before. Also on my new setup, I have a ported and shimmed oil pump.
Old Nov 6, 2019
  #340
piano55man's Avatar
I've thought about running an oil cooler in the past.
This might have led to the rod bearing letting go...
I may still add that to a later date, but for now, i don't plan on running this on the street...
Old Nov 6, 2019
  #341
piano55man's Avatar
Oasis 340lph in tank and a 340 inline pump.
Old Nov 6, 2019
  #342
piano55man's Avatar
I have Chad Berryhill tune it once i get it close.
He is the man here in South Texas.
Old Nov 6, 2019
  #343
piano55man's Avatar
I don't have the oil light hooked up anymore.
I have an actual oil pressure and oil temp gauge in the car.
The oil pressure is just off the block. I installed a brass tee to handle the pressure gauge and the turbo oil feed line.
I have the oil temp gauge located near the half way point of my turbo oil feed line.
Oil Temp on the turbo oil feed line
brass 4-way block handling the oil pressure and the turbo feed line.
Old Nov 7, 2019
  #344
all hijacking posts moved to here.
https://www.civicforums.com/forums/3...ance-chat.html
feel free to chat there, don't hijack other people's threads.
Old Dec 3, 2019
  #345
Nelrodjr's Avatar
I wanted to send you pics of a manifold I'm going to use. Whats the best way to send you pics without messing up your build page?
Old Dec 4, 2019
  #346
piano55man's Avatar
start a thread and call it Nelrodjr manifold build.
Old Dec 4, 2019
  #347
You can also tag other users to get their attention using @ in front of their username. Typing an @ sign then starting to type a username (no space in between -- like this @Nelrodjr ) prompts the system to autopopulate usernames. Just click piano55man's username as it pops up and he'll get a notification of when you post up
Old Dec 4, 2019
  #348
piano55man's Avatar
riceboy don't be jacking my thread....lol
Old Dec 4, 2019
  #349
My bad. Carry on. haha
Old Jan 20, 2020
  #350
piano55man's Avatar
Been waiting for a month to test at the track but do to my daughters all star cheer practices and rehearsals, things have been a bit crazy around the house.
In the meantime, i have learned the basics to anodizing aluminum!!!!
Old Jan 20, 2020
  #351
Colin42's Avatar
Very cool, wife was ok with you doing science experiments on the stove?
Old Jan 20, 2020
  #352
piano55man's Avatar
Yeah, about that...she wasn't home for the first round of "cooking"....
The only stove work is heating up the dye to about 150 degrees, putting the piece in the dye for 8 minutes, then placing the dyed piece into boiling water for 15 minutes to seal everything.
It does have a "breaking bad" feel to everything....
Old Jan 20, 2020
  #353
Colin42's Avatar
Right on dude, how durable does it seem? Didn't know you could anodize at home
Old Jan 20, 2020
  #354
piano55man's Avatar
Seems to be durable enough...
I used the following videos:
Old Jan 20, 2020
  #355
Dude. I legit watched that first video yesterday. Didn't even have to watch it because I recognized the thumbnail. haha. The anodization looks great! Is it really as easy as it seems in the video? Also, what kinda dye did you use.
Old Jan 20, 2020
  #356
piano55man's Avatar
I used RIT fabric dye!!!!
I used a bottle of the dye to 2/3 gallon of distilled water...I didn't know how much to use so i started with that amount.
I didn't keep the aluminum in the dye for the full 15 min. Instead, i kept it in till i liked the coloration.
For the blue i used Aquamarine
Red i used fuchsia
Purple is used purple
Old Jan 20, 2020
  #357
Damn it man. You've just opened a door to so many more projects.
Old Jan 20, 2020
  #358
piano55man's Avatar
I'm going to need a portable dual burner for the garage.
Wife wasn't too happy when she came home and saw the dye and boiling water....the second time...lol
An old friend suggested to install a stove. This way i can work on powder coating as well....
Old Jan 21, 2020
  #359
mac25's Avatar
Dr Krieger of Modification
What kind of black magic is this!?😁
Old Jan 23, 2020
  #360
piano55man's Avatar
Making my own turbo leak tester..(just because i can)
Cut it on my lathe last week, tapped, counter sunk, and anodized it last night.
I think the color blotches was caused by using tap water instead of distilled...
