Engine building Post information/questions about Engine Building here!
Ktuner and the D17
Old Feb 18, 2019
  #241
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
Re: Ktuner and the D17
Repainted
Ground some of the welds
Throttle Body Installed
Old Feb 18, 2019
  #242
piano55man's Avatar
I had to cut out the outer portion of the square D17 TB sensor clip to make it fit inside the round D16 TB sensor...nothing like making a square peg fit inside a round hole...
Old Feb 27, 2019
  #243
piano55man's Avatar
And just like that, one of my shifter cables broke.
I think my short shifter is the culprit behind the rubber/plastic housing breaking near the tranny.
So just like everything else on this car, i'm going to build my own.
I have a push/pull cable coming from Mcmaster-Carr along with some smaller hiem ends. I'll post up the fix this weekend.
Old Mar 1, 2019
  #244
piano55man's Avatar
Old Mar 1, 2019
  #245
piano55man's Avatar
The Cable is just a bit too long on the end.
I'll be making a metal mount this evening that will attached to the shifter selector arm and extend out to the new cable end. This mount will have either two bolt holes for the selector arm or be welded on to it.
Old Mar 4, 2019
  #246
piano55man's Avatar
I guess at the end of the day, i could have just cut off the end of the new cable threads and added some threads to allow everything to line up. It's hard not to break out the welder and have some fun...
shifter tab welded on and extended.
Old Apr 1, 2019
  #247
piano55man's Avatar
Talk about dodging a bullet...
The other day i shifted from 3rd trying to go to 4th...instead I went into 2nd.
This happened at about 19lbs of boost and 6800 rpms.
I sheared the key that held the harmonic balancer on, the crank bolt came off, and all 6 flywheel bolts came loose.
I have 180lbs of compression in all cylinders.
Pulled the engine, drained the oil, and dropped the pan.
No metal in oil!
Rods are all in place with some side play. I'll take a feeler gauge to it tonight. but all rod bearings seam to be in great shape!!!!
#learnhowtoshift
Old Apr 1, 2019
  #248
GolNat's Avatar
Prelude Owner
#moneyshift
That was one hell of bullet you dodged!! Get a loto ticket ASAP lol. Hopefully everything is still okay.
Old Apr 1, 2019
  #249
jesus.. I money shifted (same as yours, 3rd -> 2nd) my 2002 once, thankfully just bolt-ons with a stage 1 cam. RPMs peaked at about 9.5k. No damage luckily. Good thing your damage is (seemingly) minimal.
p.s. better not be some april fools bs
Old Apr 3, 2019
  #250
piano55man's Avatar
.007 to .008 side to side play on rod ends.
no, this is not an April fools joke.
I'm the only joke here...#learnhowtoshift
Old Apr 4, 2019
  #251
mac25's Avatar
Dr Krieger of Modification
Good to hear the block and internals are ok. 😁
Old Apr 4, 2019
  #252
piano55man's Avatar
Thanks me too!!!
I need to take apart the transmission and make sure all the gears are still there....
While i'm there, i'm going to weld up the differential.
Before all the haters start hating, this cars main function is to go down a straight track. Yes, I know parking may have it's issues....but i'm not worried about that.
Old Apr 4, 2019
  #253
BrotatoChip's Avatar
Super Moderator
LSD not meeting your needs?
Old Apr 4, 2019
  #254
piano55man's Avatar
Unfortunatly not.
When the boost ramps up past 8-10 lbs the car goes to the right every time.
Old Apr 4, 2019
  #255
Super Moderator
I guess you'll just have to limit boost to 8 psi then
Old Apr 6, 2019
  #256
mac25's Avatar
Are you using an LSD spring block or Helical LSD... or tabs of lsd? Lol
Old Apr 8, 2019
  #257
piano55man's Avatar
An LSD block welded into place!!!
Old Apr 16, 2019
  #258
piano55man's Avatar
Transmission is bolted back together and oiled up
New rear main seal is installed.
New oil pan gasket installed.
New Gates timing belt installed.
I'll be going to the store and get some red loctite for the flywheel bolts and the crank bolt this evening.
Going to be building a diaper pan to fit in between the "frame rails" this weekend.
Old Apr 16, 2019
  #259
mac25's Avatar
Dope bro! 😁
Old Apr 18, 2019
  #260
piano55man's Avatar
It's always a good idea to have little reminders....
Old Apr 19, 2019
  #261
piano55man's Avatar
Building the catch pan thingy....
anyways, i'm not sure this will work without putting the engine back in the car.
I have a feeling that the oil pan sticks a bit further down than the mid frame.
The good news is that the outline is made so all i would have to build is the sides and raise/lower the pan area...
I plan on making this out of fiberglass.
Last edited by piano55man; Apr 19, 2019 at 12:51 PM. Reason: need to finish sentence
Old Apr 19, 2019
  #262
yeh been really busy! Good going, as usual!
I really think I will move your thread from Engine management to engine building... It fits better there.
Old Apr 25, 2019
  #263
piano55man's Avatar
After getting the engine installed last night....the damn axles wont fit.
I guess the welding expanded and then shrunk the differential metal.
Game plan is to check the different diameters. The axles seem to have a few different diameters...the grooved area, and two solid areas.
More than likely I will have to grind a bit out of the differential. If the grooved areas are off then this differential is crap.
Old Apr 25, 2019
  #264
mac25's Avatar
Oh, ya I didn't think about that when you posted the pic of the diff.
If you have to do it again, perhaps grease the axles and leave them in the final drive gear, and use water to cool the material in between short welds.
(Had to do that for my intake manifold, because I warped the sh$$ out of the first one I tried)
Make sure your gloves don't get wet though... lol
Good luck
Old Apr 25, 2019
  #265
piano55man's Avatar
I have my eye on an OBX lsd....
Old Apr 26, 2019
  #266
piano55man's Avatar
Looks like the axles needed a bit more persuasion!
Might be a bitch getting them out later on....
Old Apr 29, 2019
  #267
piano55man's Avatar
Took the car around the block...with no power steering and a welded differential makes this car a bit hard to steer.....
Time to make this a track car only!
Old May 29, 2019
  #268
piano55man's Avatar
I found a used crower stage 3 cam last night.
Should be in the engine by next weekend!!!!!
Old May 29, 2019
  #269
mac25's Avatar
Nice 😁
Old Jun 4, 2019
  #270
piano55man's Avatar
The lobes on this cam are freaking HUGE!!!!
