MONTREAL area: General Discussion
Originally Posted by nindoo
Black veloz kit for the coupe. Where to get one for a reasonable price?
Anybody swap SIR rear brakes?
Sorry no luck in that department for you from my end Why is my vagina bleeding?
Originally Posted by janlop
I was going to say ask FaZe where he picked his up.. but I do believe he got the OEM kit - not the veloz .. but in any way, I doubt you'd find it in black nicely - probably need to have it painted.
A friend .. oh wait, he got them stock on his EL
Sorry no luck in that department for you from my endI seen three cars with the Veloz kit downtown yesterday. So many people have si coupes since this summer. When I bought my car there wasn't nothing available I got one the few remaining ones.
I like the neuspeed sports cause the car drops 1.75 in the front and 1.5 in the rear. The eibach sporlines drop 1.5 rear and front. I'm also afradi that the tokicos hps can't handle drop very well. So maybe 1.75 can be pushing it. Does anyone here know abou the tokico hps? ideal is konis, but $$
Do you have an idea of the cost (part+installation)?
You can install lowering springs on OEM shocks however the eibach and neuspeed lowering springs are stiffer than your stock springs causing your shocks to work harder (rebound). So even if you don't blow your OEM struts you definately will waer them out a lot quicker. If you want better handling the best investment for suspension is Koni shocks. They are the best best. However if your like me and don't need the best Tokico HPs are much better than stock.
In terms of cost I've seen tokico for around 300-350 USD dollars
and eibachs for 200-260USD dollars
and Neuspeeds for 160-200 USD dollars.
You will also need a rear camber kit if you drop 1.5 inches
+ customs if your buying stuff from the states.
In terms of Installation RMR said 3 hour job 65$ and hour plus tax.
I know RMR had some neuspeed sports forsale for the sedan. The springs were less than 200 Canadian. They weren't good for the coupe though. Thats a really good price.
If your going to lower your car and don't want headaches its best to do it right the first time to save yourself money and trouble.
http://www.tuning-maniacs.com/
It might be far for you guys, but I heard good things from them.
My car is currently there (for one day) for parts installation.
It will take him overnight for the car to cool down for him to install my header, cold air intake and readjust my catback exhaust to stop the vibrations.
His $/hr rate beats RMR by a long shot, and he knows what he's doing.
I saw some cars that were there, widebody Miatas, engine swaps, good stuff!
Hey guys I had a few questions
Hey guys in terms of lifting the car and doing oil changes. Do you guys use jack stands or ramps? which do you reccomend? I was thinking of getting a jack and two 3 ton jack stands.
Is it best o buy oil directly from honda as well as the oil filter or there is penzol and some aftermarket oil filter just as good?
Anybody here upgrade there front brakes with brembo blanks and hawk brake pads?
03AzNsIlvaSeDaN were you at the gym today @ around 6:30pm Sunday February 13?
Originally Posted by 03AzNsIlvaSeDaN
HAHA...nope! Did u see an azn?? Theres several azns that go there... Im prolly heading there today tho!
Yeah I saw an Asian guy with glasses and Nike Jersey. Nindoo's Azn profiling yo!
I was thinking of getting these
http://www.canadiantire.ca/assortmen...romSearch=true
http://www.canadiantire.ca/assortmen...=1108404903785
http://www.canadiantire.ca/assortmen...=1108404758644
I'm a lazy/inept **** so I just go mainly to the same garage I've been going to forever now (lifetime of owning a car => summer 98 till present) .. I don't use Honda oil - nor filters .. so I couldn't tell you yes or no on that part - I'd say use what majority of 7thgen techies use.
I've changed my front brakes... but mainly from oem pads to aftermarket ceramics pads.. but still not as expensive as mentioned above, but mainly because they *should* last me longer .. then again, my driving style usually made me go through pads like butter
I suggest to use a Honda oil filter, keeps the oil pressure stable and where it should be, especially good for VTEC engines. I love working on my car and don't even do my own oil changes, they are so cheap at the dealer why bother?
I'll run KVR cross-drilled rotors with HP+ hawks this summer, KVR's pads suck big time, I had them last summer. Read this...
http://www.7thgencivic.com/forums/sh...d.php?t=192773
Hey guys, I am trying to sell that:
- Hood deflector for civic 2004-2005, used 3 month, Sold and Installed by Honda, Brand: Perfect fit. Like new: 60$ or best offer (new = 120$)
- 10' of 4awg cable (power-pro, 1064 "brins") red, never used. Bought for a grounding kit, but I want another color... : 20$ or best offer!
Let me know if interested!
2 kits are available for Civic 01-03
1) Veloz Kit (Canada) = OEM Kit (US)
2) Factory Aero Kit
I just got the car back
Kamikaze Header
AEM Cold Air Intake
5Zigen Catback Exhaust /w Random Tech Hi-Flow Cat
Everything is finally installed.... wow... it pushes...
No loss in low-end
Mid-range is good
Hi RPM.. WOW
2) Factory Aero Kit
Kamikaze Header
AEM Cold Air Intake
No loss in low-end
Mid-range is good
Hi RPM.. WOW
2) Factory Aero Kit
Kamikaze Header
AEM Cold Air Intake
No loss in low-end
Mid-range is good
Hi RPM.. WOW
2) Factory Aero Kit
Kamikaze Header
AEM Cold Air Intake
No loss in low-end
Mid-range is good
Hi RPM.. WOW
NOICE!!!!!!!!!! Did you modify the sensor in the exhaust that monitors emmisions? Well I'm not sure you have have the same cat as the SI. The SI has a three way cat which can make the engine light come.
What is the exhaust made of. Maybe your new exhaust and headers are lighter than the stock parts also another plus.
your cold air intake where is the filter location? is it at the bottom?
Where is the Veloz kit?
Since Veloz = OEM if I understand that properly then
** Oh and if no one noticed, I just got my username changed -
haha! Im usually in gray sweats... What time r u usaully there ne wayz? Why is my vagina bleeding?
LMAO!! I actually do have glasses!
haha! Im usually in gray sweats... What time r u usaully there ne wayz?I have been lazy and only went Friday Saturday Sunday. I'll try and go this wednesday. Hey dude you wouldn't happen to be the other crazy azn that does mad cardio. Do you go balistic on the stair climber thing.
Originally Posted by Karumba
Since we chatted on MSN .. I know that his CEL came on. Though he said he was getting the MIL eliminator installed tomorrow.
where did you pick yours up from FaZe ?
**KARRRRRRRRRRRUUUUUUUUUUUUUUUUUUMBA!!!!!
I want to modfy everything but It always take me time to convince myself to spend the cash.
My priority is suspension. But after I saw the veloz kit, its looking so hott I got to put it on my car.Lightwheel, exhaust headers, got to get them all!!!! POKEMAN!
hey janlop...aka karumba! lol how did u get to change ur name?? I wanna change mine too!
Dude, you got me cracking the hell up here..
When i do cardio...im usually upstairs on the ellipticals
Ohh...so u sent him a PM, and he changed ur name? Thats all??
Just basically say hi and what you want to do - ie Hi - Karumba told me if I wanted to change my username I should ask you.. I'd like to change my username from ___ to ____ .. if you need to contact me, here's my e-mail: **@***.*** Don't be afraid.. Mike's a good guy/administrator <- notice not moderator
He posted at one time in this thread... as he used to live in Kirkland..
I got my OEM/Veloz Front/Side at the same place I got my rear bumper/lip
(A junkyard in Chambly, South Shore again... =P)
My CEL came on after my drive from Varenne to Downtown
MIL Eliminator should fix that...
My 5Zigen Exhaust is not made of SS... just the main can/tip is SS
The Cold Air Intake Filter is located in the bottom, behind the battery like all AEM CAI.... I prefer the Injen setup though =/
HAHA! Hell no...thats not me! That guy's korazy with the stairs!!
2006 civic si has a n article this morning in the Gazzette.
I got to go check out the Chambly junk yard some day.
Hey dudes I used Vingegar to clean my carpet mats, the salt stains came out but now my car smells like vinegar
To answer all the questions:
Please explain exactly what it is and where you got it, is it like a dummy O2 sensor? Do you need 1 or 2? I'll need to do the same on my car for the high-flow cat. Thanx.
