My EM2 - EX SE Build
Old May 12, 2012
  #61
sl33pyriceboi's Avatar
Re: My EM2 - EX SE Build
i think ur rims would look better if they were ALL black...
something about that silver outlining kills it....reminds me of kia rims.
Old May 12, 2012
  #62
krudmuphin's Avatar
Ehh, I'm having second thoughts, but I'll leave them the way they are. The problem is that I couldn't decide between silver and black wheels, so I found a mix. These wheels look particularly cool in the evening when the black is too dark to see and it's just the projected silver rings you see. Reminds me of the new Opel / Vauxhall rims, which I like. In the future though, I'll probably get some all silver or white rims, and hopefully ones that are less than 20 lbs,
Old May 12, 2012
  #63
rjones7755's Avatar
Originally Posted by krudmuphin
Thanks man! I found an '06 Type S part out and the guy's willing to give me a rear sway assembly for $75
The 06' type S rear sway is either 21 or 22mm (cant remember)....dont you need a brace for anything over 19mm?
Old May 12, 2012
  #64
krudmuphin's Avatar
I dunno, do I? lol
And just to be clear, I shouldn't need an alignment after installing this, right?
Old May 13, 2012
  #65
MindBomber's Avatar
Live for the Twisties
05-06 Type-S is 21mm, 02-06 Type-R is 22mm
Many people have been using the 21mm rear quite some time without no issues.
I dunno, do I? lol
No, you won't need one.
Old May 14, 2012
  #66
krudmuphin's Avatar
Finally installed fogs and front lip today!
Coilovers go in Friday!
Old May 14, 2012
  #67
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
Check this out..... that lip is coming RIGHT OFF.
https://www.civicforums.com/forums/1...ml#post4601983
Old May 14, 2012
  #68
krudmuphin's Avatar
Thanks! I actually took the lip off already because I want to paint it darker. Also I don't like how it looks when my car isn't lowered yet...
Old May 14, 2012
  #69
TFMEX's Avatar
CO&CA
I can't wait to get mine back on.... It looks naked without it. I don't like it at all. Finished painting the clear coat about an hour ago. Waiting 48 jours before I reinstall to let it cure
Old May 19, 2012
  #70
krudmuphin's Avatar
Installed my coilovers!
Read my overview if you're interested:
https://www.civicforums.com/forums/2...mpression.html
ID:	83359   Click image for larger version
ID:	83360   Click image for larger version
ID:	83361   Click image for larger version
ID:	83362   Click image for larger version
Old May 19, 2012
  #71
TFMEX's Avatar
CO&CA
Lower lower lower!!!!!!!! Tuck that ****!
Old May 19, 2012
  #72
krudmuphin's Avatar
Have to do some other work first before that can happen. I want to roll the fenders, run -1 camber all around, install a bigger sway bar, and re-bend my exhaust mid section.
Old May 20, 2012
  #73
e-teckk's Avatar
e-teckk will become famous soon enough
yayyy
Old May 28, 2012
  #74
krudmuphin's Avatar
Threw on the DC5 rear sway bar this morning.
That is easily the best money I've ever spent on my car. Insane improvement from just a thicker bar, who knew?
If anyone wants to find a good one cheap, got to clubrsx.com and contact people who're parting out 05-06 Type-S RSXs. I got mine for $75, but a week later, there was a guy selling one for $50
Old May 29, 2012
  #75
tipnitty's Avatar
tipnitty is on a distinguished road
I am sooooo jealous of the Teins!!!!!! Looking good man.
Old May 30, 2012
  #76
TFMEX's Avatar
CO&CA
I agree. I saw an IMMEDIATE and obvious improvement. I went with the 19mm 04 RSX instead mainly because I didnt want to by a support bar as some recommend the brace for anything over 19mm AND I got it for 40$ shipped.
one of the most worthwhile enhancements to our rides.
Old Jun 26, 2012
  #77
krudmuphin's Avatar
Had some exhaust work done today! Got my new Magnaflow muffler and 4" tip welded on. (The muffler guy didn't weld the tip exactly where I wanted it and claims it's permanent, but whatever...)
Looks better than the ol' can in my opinion. Sounds good too. There's a lot less of that "droning" noise when I'm cruising along.
I also had the mid-pipe section re-bent for more clearance and had a flange flattened out to prevent vibration on the floor pan.
All in all, the shop did excellent work for only $120. I'm going to ask the welding guys at my school if they can break those tack welds on the tip and slide it onto the muffler a bit closer though. It sticks out too far IMO
Old Jun 27, 2012
  #78
TFMEX's Avatar
CO&CA
Looks great man! I see you went with the same muffler I went with but a slightly different style tip. Worth it huh!!!!
My newest project is side skirts. got some type A's and have painted them with REAL auto paint this time not Dupicolor.
I have some "orange peel" in the finish and am going to so dome wet sanding to finish it up. Ill post pics in my build thread when its done!
Old Jun 28, 2012
  #79
krudmuphin's Avatar
Totally worth it. It's quieter, but not too quiet... and it has more of a growl to it now. Mostly I'm happy with thw way it looks compared to the can.
Can't wait to see your side skirts! I don't think I'd like side skirts on mine, I can't even decide if I like how it looks with my front lip on.
Old Jun 28, 2012
  #80
TFMEX's Avatar
CO&CA
I posted the pics with my side skirts on. =-)
Old Jul 6, 2012
  #81
Rejin267's Avatar
Rejin267 is an unknown quantity at this point
im a noob when it comes to cars but trying my best to learn all and apply it to my ride when the time comes, so my question is when you lower your vehicle and the tires are so close to the fenders and the wall of the wheel well how exactly does your tires not rub against any of that when you hit a bump or even when you turn your wheel?
Old Jul 6, 2012
  #82
TFMEX's Avatar
CO&CA
Depends on the suspension and camber. if you have a VERY stiff suspension then they wont move enough to rub but its its soft it will rub unless you have enough camber that the angle exceeds the rubbing point.
I do know that Krud is running 225/45's and had issues initially with rubbing. You can also Roll the fenders which is what I had to do with my 215/45's. Even with the rolling of fenders I was rubbing cause I was so low so I went to 205/40's and am slammed with no issues.
There are people who run +0 offset with stretched tires and dont rub and some that do. Depends how extreme you want your setup.
Old Jul 10, 2012
  #83
krudmuphin's Avatar
New exhaust clip!
Does anyone know what causes that little back-pressure vibrating noise when you let off the gas? I never had that noise in the old can muffler.
http://www.youtube.com/watch?v=gtWE7r2UuiI
And no worries, I didn't even reach the speed limit in 3rd gear, lol slow
Old Jul 11, 2012
  #84
do u have the link to the guy who is selling it for 50?
Old Jul 11, 2012
  #85
krudmuphin's Avatar
It's gone already
It sold 5 days after I found it.
Old Jul 12, 2012
  #86
TFMEX's Avatar
CO&CA
New exhaust clip!
Sounds good man!
Old Jul 29, 2012
  #87
krudmuphin's Avatar
Got bored. Washed and waxed. Took some rather bland photos with my sister's new Canon Rebel.
ID:	83783   Click image for larger version
ID:	83784   Click image for larger version
ID:	83785   Click image for larger version
Old Jul 29, 2012
  #88
Max91's Avatar
Max91 is an unknown quantity at this point
Hell yeah! I'd be seen in that!
Old Jul 30, 2012
  #89
TFMEX's Avatar
CO&CA
I like it man..... needs MOAR LOW IMO.... also some skirts would do those side some justice.
Not sure what it it but the sharp drop off of the rocker panels of the 04/05 bothers me...
Ride looks clean and dope tho
Old Jul 30, 2012
  #90
krudmuphin's Avatar
I totally agree. I'm experimenting with lips right now and I have one that may be quite shocking to EM2 owners, it's my secret lttle project And i'll get hooked up with the same sides you have.
Today I bought a $600 mountain bike so I have to do a bit of recuperating before that can happen.
