Engine building Post information/questions about Engine Building here!
Ktuner and the D17
Old Jul 20, 2017
  #31
5.0Thunder's Avatar
5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough
Re: Ktuner and the D17
if it helps, there was a guy here in houston selling a small lot of new b-stock turbos extra cheap. might have had one in the correct size. his prices were like $40-$60 per turbo if I remember, all new.
Old Jul 20, 2017
  #32
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
Thunder...PM sent.
Old Jul 24, 2017
  #33
5.0Thunder's Avatar
Whassss thedeaalll?
Old Jul 24, 2017
  #34
piano55man's Avatar
Thunder, thanks for the info.
I'm currently out of pocket for the remainder of the week.
I'll follow up next week.
Thanks again.
Old Aug 1, 2017
  #35
piano55man's Avatar
Finally back from vacation!!!
Looks like i drilled the pan about 1/2" to far to the left for the oil return line...
so, on to the exhaust shop to get some custom work done.
Old Aug 1, 2017
  #36
piano55man's Avatar
oh yeah...new t3/t4 turbo and shorter waste gate to be delivered Thursday.
Old Aug 2, 2017
  #37
piano55man's Avatar
Added the 660 cc injectors last night.
Since the new injectors are a bit taller, I added an extra black plastic washer traditionally used for the fuel rail along with a longer bolt.
Old Aug 2, 2017
  #38
piano55man's Avatar
added these fun quick releases last night as well...
Old Aug 2, 2017
  #39
upgrade those hood pins to some flush-mount aerocatch ones
Old Aug 3, 2017
  #40
piano55man's Avatar
because the front wing and stock car plastic help out soooooo much with the aero package i have....
Old Aug 9, 2017
  #41
piano55man's Avatar
another lesson learned....
Make sure your oil line to the turbo is not kinked...you will burn up a turbo or two.
At least i was able to combine parts from each of the two turbos along with a rebuild kit to make one that works....
Old Aug 9, 2017
  #42
piano55man's Avatar
New oil line and heat wrap for the exhaust go on tonight.
Next thing will be getting the final exhaust hooked up along with a revised tune from HA Motorsports.
Old Aug 10, 2017
  #43
piano55man's Avatar
Last night, i changed out the oil distribution block that the turbo oil feed and oil sensors come out of. I had a small oil leak coming from that area. Sure enough, the original brass block had a crack in it. I guess i don't know my own strength...
Took the rice rat out for a test drive last night....
These things come alive when the boost kicks in.
I took my last tune and added 25% fuel to the whole fuel map so i wouldn't be too lean.
BTW i switched back to the stock injectors for the time being. I couldn't get the car to start with the 660cc's. That will be for another day.
Anyways, car came alive on WOT!!!!
Engine ran way lean on idle and way rich on WOT. No biggie, got home and made my fuel adjustments.
Now i have an oil leak coming from the oil drain line.... I'm sure this is an easy fix.
So tonight's plan is to fix the new oil leak and try out the new tune.
Old Aug 10, 2017
  #44
Erf_Em2's Avatar
Erf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of light
Those oil leaks are a PITA.
Old Aug 10, 2017
  #45
piano55man's Avatar
So all the connections where good...the line actually had a small tear in the middle of it.
fixed it and now no leaks!!!!
its so much more fun to drive with a turbo and an open down pipe.....
BTW it's hot under the hood after a 10 min drive. I'm thinking for putting a scoop similar to a WRX. I have the header and the down pipe wrapped and it's still freekin hot. Any suggestions besides a turbo shield?
Old Aug 14, 2017
  #46
piano55man's Avatar
Header connected to the exhaust.
time to add more wrap to it...
Old Aug 16, 2017
  #47
piano55man's Avatar
FYI....i ran 7.9 lbs of boost on stock injectors and stock fuel pump.
110% of duty cycle.
i'm sure that's all she got's captain!
Old Aug 22, 2017
  #48
piano55man's Avatar
Anyone have a suggestion for gauges?
Looking for Oil Temp, Oil Pressure, and of course Boost.
I'm thinking of using the piller.
Old Aug 22, 2017
  #49
I'm a fan of the way Defi Racer gauges look at operate, but could never bring myself to spend the money they want for those ($134 on amazon for a damn voltage gauge O_o)
edit: no AFR gauge? That's kind of a staple for boost builds.
Old Aug 23, 2017
  #50
Erf_Em2's Avatar
I suggest AEM Uego afr. I currently run autometer sport comp digital gauges but the oil temp and water temp both **** on me the first year it shows a partial final digit. I had issues with partial digits first month oil temp. Sent in got replacement then that **** on me a month later. Oil pressure works great if i could redo it id get glowshift gauges brand digital oil temp, oil press, and water temperature. I own glowshift gauges tripod console pillar which fits good and the speedometer pillar which replaces the factory speedo cover and adds two gaugd spotz. I currently have mounted an aem afr and autometer digital boost gauge. Havent turbo yet so havent hooked them for feedback for afr and boost
Old Aug 23, 2017
  #51
Only gauges I had when I was boosted was an AEM UEGO AFR and an AC Autotechnic boost gauge (both of which are still installed, but the boost gauge not hooked up to anything other than illumination power)
Ill try and find pics when I get to my laptop
Old Aug 23, 2017
  #52
Here you go, night time illumination pics. I'm pretty sure the boost gauge was hooked up when I took this pic, hence the indicated vacuum. As it sits right now, it reads right at 0
edit: only daytime pic I could find showing the gauges. On the AC Autotechnic gauge, when the car is off, it's kinda smoked so you can't really see it, but when the car is on, the meter portion illuminates and you can see it just fine. The AEM gauge comes with 4 interchangeable faces, 1 black and 1 white of each AFR and Lambda reading. I have mine to read AFR with the black face.
ID:	111608   Click image for larger version
Old Aug 24, 2017
  #53
piano55man's Avatar
With the Ktuner program running the ecu and my laptop being hooked up to it quite a bit, i just read the afr from that.
My tune is very conservative at this point so i'm not too worried about it.
BTW, since we are going to have an epic rainstorm down here in south Texas, I'm going to be detailing everything up in the engine department since i wont be going anywhere
Old Aug 24, 2017
  #54
Always something you wanna keep an eye on regardless. I'm not boosted anymore, but it still gives valuable info when I feel like something's wrong. At least you have something to monitor it at least.
Since you're gonna be detailing it, wire tuck while you're there. Haha
Old Sep 12, 2017
  #55
piano55man's Avatar
glow shift gauge pod delivered.
went with oil pressure, oil temp, and boost.
Old Sep 20, 2017
  #56
5.0Thunder's Avatar
I know I'm late here but I have great success with autometer pro-comp ultralite wideband and boost gauges on two of my boosted cars. I like the AEM stuff as well.
My 01 civic has an aftermarket head unit with a small tray under it so I'm wondering if I can delete the tray and use a blanking plate there for gauge mounting rather than pillar mounting.
Hope your stuff survived Harvey! Luckily my house and other cars all survived.
Just to reiterate, which platform are you tuning with here?
Old Sep 20, 2017
  #57
piano55man's Avatar
Thunder,
I'm went with the piller mount and glowshift gauges.
Everything survived the wind and rain...
I'm using a non-civic ECU which is utilizing the Ktuner platform.
Old Sep 20, 2017
  #58
piano55man's Avatar
pics of the guages
ID:	111661   Click image for larger version
Old Sep 20, 2017
  #59
5.0Thunder's Avatar
Okay cool, I'm guessing this requires an ECU used with K-series engines? Similar to Kpro for our cars?
I've been tossing around the idea of adding boost to mine with an FIC but I really just haven't read up on too many 100% success stories with that platform. I'd like to see consistent boost AFR's, consistent Idle and Cruise AFR's, small fuel trim corrections, easy cold and hot starts, and no idle surging/floating while rolling in neutral. These are things that make a reliable daily driver in my opinion.
I need to catch up with you somewhere down here one day so I can see your car and get hooked.
Old Sep 20, 2017
  #60
piano55man's Avatar
Thunder...PM sent.
