Engine building Post information/questions about Engine Building here!
Ktuner and the D17
Old Jul 12, 2019
  #301
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
Re: Ktuner and the D17
Pop Rivet the braces in
Bottom View
Fiberglass over rivets to help keep them from leaking.
Old Jul 12, 2019
  #302
piano55man's Avatar
The tabs should get welded tonight.
Welding upside down sounds fun.....
Old Jul 15, 2019
  #303
piano55man's Avatar
It's not really that pretty but it'll work.
Just needs to be cleaned up a bit.
Old Jul 15, 2019
  #304
piano55man's Avatar
Time to work on a new manifold.
This is just a simple mock up.
Going to use mild steel since that's what i can weld.
I'll be utilizing a header built for the A-1 and going from there...
Old Jul 18, 2019
  #305
piano55man's Avatar
Here are some better pics of the mockup
Old Jul 18, 2019
  #306
mac25's Avatar
Dr Krieger of Modification
Looking good man 😁
Old Jul 22, 2019
  #307
piano55man's Avatar
I had to do some extra welding on top of the welds....for pin holes.
It's mounted with the turbo in the car.
Started it up and man it sounds smooth...wayyyyy different tone.
I'll be mounting the waste gate and a couple of support brackets this week.
My welding sucks but it'll work!
Old Jul 22, 2019
  #308
piano55man's Avatar
I had to move the mount way out due to the turbo size.
My biggest issue was it hitting the alternator.
Old Jul 22, 2019
  #309
GolNat's Avatar
Prelude Owner
Hey it’s functional and doesn’t leak
A grinder and paint make me the welder I ain’t
Old Jul 22, 2019
  #310
piano55man's Avatar
Thanks
Exhaust wrap will definitely be used...
Old Jul 24, 2019
  #311
piano55man's Avatar
Some more pics.
I'll be adding the waste gate tonight/tomorrow.
Old Jul 25, 2019
  #312
piano55man's Avatar
Waste Gate pics...
What crappy welds....
Old Jul 25, 2019
  #313
stick weld or flux core gasless? lol
Wait a damn minute. lol. You're gonna act like you didn't purposefully frame that Ferrari emblem perfectly so it's just visible and not mention it?
Old Jul 25, 2019
  #314
piano55man's Avatar
flux core gaseless... i'm finding out that this = uuuuuuuuselesssss
Yeah, the Ferrari is next on my project list!
I need to find out why i'm not getting power to the rear wheels.
It could be a few sensors or the battery.
I could always just put a kart engine on it....
Old Jul 25, 2019
  #315
Lol, flux core works.. ish.. For small things. Then again, that's the only welding I've done thus far. Just kinda borrowed my dad's flux core gasless and taught myself how to weld. Some pretty welds, some pretty ugly welds. Lots of splatter. It gets the job done. In fact, my racing seat turned desk chair is still holding up after welding up the bracket for it
Grinder and paint make me the welder I ain't
I know fully understand this quote
So.. not an actual ferrari, but a kit car?
Old Jul 25, 2019
  #316
piano55man's Avatar
Grinder, paint, and heat wrap makes me an awesome welder!!!!
Old Jul 26, 2019
  #317
Nelrodjr's Avatar
Nelrodjr is an unknown quantity at this point
What kind of power were you making on your last setup?
Old Jul 29, 2019
  #318
piano55man's Avatar
250hp.
The reason why i built the new exhaust manifold was due to the amount of restriction.
Old Jul 29, 2019
  #319
Nelrodjr's Avatar
What kind of internals?
Old Jul 29, 2019
  #320
piano55man's Avatar
stage 1 crower cam
upgraded springs and retainers
wisco pistons 75.5
k1 rods
king race bearings
port and polish
d16 intake
70mm TB
fid 1000 injectors
E85
10lbs flywheel
Old Jul 29, 2019
  #321
piano55man's Avatar
currently have a stage 3 cam
and going to install new bearings in the next month.
I don't like the idea of rod bearings lasting till they break.
Old Jul 29, 2019
  #322
Nelrodjr's Avatar
How many pounds of boost?
Old Jul 29, 2019
  #323
piano55man's Avatar
18lbs
Forgot to add i'm utilizing ARP head studs and Cometic stock thickness headgasket.
Old Jul 29, 2019
  #324
Nelrodjr's Avatar
What kind of turbo
Old Jul 29, 2019
  #325
Random thought on that catch pan. What if you can up some mounting points to the subframe and put some structural reinforcement on it? It'd double as a subframe brace, no? It'd also be heavy as **** though. Lol
Old Jul 29, 2019
  #326
piano55man's Avatar
GT3582 ebay special...
Old Jul 29, 2019
  #327
piano55man's Avatar
4 points is all i want to add to it.
the pan itself is aluminum/fiberglass. I don't think it will help with reinforcement that much...
Old Sep 26, 2019
  #328
piano55man's Avatar
Good news...the engine should be getting back from the shop with a fresh set of bearings either tomorrow or early next week!!!!
Old Oct 30, 2019
  #329
piano55man's Avatar
Finally getting the engine back together!!!
Old Oct 30, 2019
  #330
Nelrodjr's Avatar
Looks good, I will send you pics of my setup later today, working on the head for the pas few weeks.
