MONTREAL area: General Discussion
Originally Posted by Redviking
I think the price is good and it will be nice on your car.... a lip and OEM fog lights!
You are selling your header? Did you put back the OEM manifold? why?
Problem with cops again???
(no cat = a ticket of 300$ or more!).
(no cat = a ticket of 300$ or more!).After a long delay in getting the item back, over two months, its back in my hands and well useless to me because I'm not going to be installing it over the system I'm currently running.
Currently running a HP shorty header and a Random Tech hi-flow cat - with O2 wire extended for the rear bung versus the HP H26 full header and downpipe plus O2 simulator ; though I imagine since I had the wiring extended that I could get around not using the simulator but still.. I am not going to change it again. Though I do believe that the H26 system gets a lot more responsive in the higher rpm range than the current one.
I,m not sure if i follow you...It's just a header right? Is it legal to have that or it just when you don't have a catalitic... that your illegal?How much does it cost that H26?
Unless you are making to much noise! The problem with DX/LX is that the cat is in the exhaust manifold, so if you put a header you remove the cat... you need to custom fit one to stay legal or do as Karumba.The header Karumba will (eventually) sell is made for the Si (EX in US). So it's the header + a downpipe (without cat) to replace the OEM one that have the cat on it (#4 on the 2nd pic).
So for your car, you will need then to buy a aftermarket (or OEM) exhaust for a SI to make it fit (you could also cut your OEM system and custom fit it!). Keep in mind that if you increase the size of the piping in front it's good to increase it all the way, for maximal gain...
I was planning to buy a similar set-up for myself and install a high-flow cat in the downpipe (to stay legal)... But I finally bought Jamie's header, so I'll need to custom fit a high-flow cat between the header and the RSX-S exhaust I want to install. The end result is the same anyway!
For the DX/LX trim, there is some HPs waiting to be released when removing the OEM manifold/cat combo! I guess Karumba can confirm that
It's illegal to remove the cat. If you have a header and still have a cat it's okay. Unless you are making to much noise! The problem with DX/LX is that the cat is in the exhaust manifold, so if you put a header you remove the cat... you need to custom fit one to stay legal or do as Karumba.
The differences between EX and DX/LX is the fact that the catalytic converter is changed locations (as well as the length of wiring for the O2 sensors) and how the piping connects through completely. In the DX/LX applications, you can see with the image below that the catalytic converter is in the header portion:
Whereas in the EX application, it is located in the downpipe.
The H26 set-up is everything pictured below before the sway bar. As Redviking stated, it is made for an EX model.
It technically removes the catalytic converter as the "cat" on this header is moreso a resonator than anything else.
Well the header sells for 280$ US + shipping + duties .. all said and told, I think I'd be happy with to get back 350$ CAD for my troubles. Troubles being the initial shipment and duty charges plus the return shipment and the small return duty cost, but we'll see how things go and all..
Just by curiosity, what is the outlet size of the header you have? And what is the size of your High-flow cat?
My Kamikaze header is 2.25" so I was looking for a 2.25" high-flow cat, but I was suggested to go to 2.5"...
Redviking with is rsx exaust could cost less and would do the same...Right?
So expect to pay a little bit more. Would it do the same? Depends on what you are looking for! Me I was looking for some gains but with an OEM sound and OEM look (or at least not too flashy) and with minimal $$$. But it still look really sexy on a sedan! It has a 2.5" tips. The piping is between near 2" to 2.25", so way better than the civic 1 5/8". But as pointed by Karumba, it's the cat that is doing the restriction. So I think the size is perfect.
If you can find a 2005 RSX-S exhaust it will be even better, the exhaust is the same as the RSX typeR, it has a special valve inside that opens at higher rpms to increase exhaust flow. But expect to pay more for it, and it's difficult to find locally!
It's not a direct bolt-on, you will need to add a few inches at the back to reach your rear bumper, use longer hangers, and since the RSX is shorter, you need to add some lenght up front. But any good shop will do it easily!
Though I can tell you that the piping of the WS2 is 2.5" if that matters
yikes... how much could it cost to do the full line... Redviking with is rsx exaust could cost less and would do the same...Right?
Or ill buy some lips for my car. Lip for tunk too
I am starting to have some issues with my manual transmission.
I sometime have difficulty to shift in first or second gear when the car is cold and when the weather is cold outside.
I was first affraid that this problem was due to my short shifter adaptor
But, from what I read on the forum it seems to be a common problem with 2001+ tranny. I am afraid that if I go to the dealer they will say it's because of my short shifter... if I remove it before going, it's still apparent that I had used one... I just hope that it's just a lubrification problem (transmission oil + shifter cable bushing), like some members noticed.
Anybody else with a manual had/have this problem?
I sometime have difficulty to shift in first or second gear when the car is cold and when the weather is cold outside.I was first affraid that this problem was due to my short shifter adaptor
But, from what I read on the forum it seems to be a common problem with 2001+ tranny. I am afraid that if I go to the dealer they will say it's because of my short shifter... if I remove it before going, it's still apparent that I had used one... I just hope that it's just a lubrification problem (transmission oil + shifter cable bushing), like some members noticed. Anybody else with a manual had/have this problem?
Ok, couple of $$$ i'd probably start working the exaust after my damn suspension is the right hight...
I'm trying to have more info on this compagny... we never know.
looks cool, at least, they got spec for a seddan, plus only 155$... made in canada!
Limited Time Offer: FREE Shipping. FREE shipping insurance, & we'll even pay all applicable taxes. This sale is available for all customers living in Canada and the US lower 48 states. (For additional costs to ship to other areas, email us at sales@canuckmotorsports.com . State the product you want, your vehicle and your shipping address. This sales campaign does not affect our eBay store.) All prices are in Canadian dollars. All car spring sets include 4 springs, unless otherwise noted.
Canuck Motorsports sounds like a knock-off seller from eBay that is trying to go "bigger".
Won't guarantee everything lasts, but
guess its cheap enough to try out..
From what I found on the net, people seems happy with them. Some said that they are doing the springs for other ie (like eibach...) ???
85$ +35$ shipping + 3$ insurance, if you take them here.... http://cgi.ebay.ca/CM-Lowering-Sprin...QQcmdZViewItem
150 coil
600 shock
100 camber ( won't forget this one this time )
150 install
1000$
What do you think
You stalking some more people Redviking?
Where's the alignment cost of 75$ in that picture Simpaty?
Though at the same time, wondering where you can get that install for that price....
Humm, i think i might try them with kyb agx.... Red and Silver... Concept with my car
But ill only try the 1.4 inch drop if i want to use them in winter...
150 coil
600 shock
150 install
1000$
What do you think
150 coil
600 shock
150 install
1000$
What do you think
People from car club on the west coast seems to like them...
Here some comments I found:
http://www.vcmc.ca/forum/archive/index.php/t-1441.html
http://jbodymontreal.com/forum/phpbb...fc9123e80bc6ea
http://www.msprotege.com/forum/printthread.php?t=85903
http://www.saturnfans.com/forums/showthread.php?t=65392
http://www.torontomaxima.com/forum/viewtopic.php?t=5233
http://64.70.45.29/forums/read.php?f=3&i=82263&t=82263
Euhhh..... My English is not that good... I am not sure of what you mean...
Stalker= qqun qui fait une filature, dans l'ombre, sans se faire voir....
At least, i was i front of you! As always.... i never saw your car and i could not reconnize it...Registered!!
Well, my car look very stock. A blue 4 doors with black steelies for winter!
I shaved my emblems (still have the "H
you can see my rear lower tie-bar (it's chrome); and I have black mesh grill in my front lower bumper... So good luck to recognize it!
Originally Posted by Xenin
that was some shitty freezing rain i was driving in on sunday night. made driving around point-claire fun.
Pat, tu peut le dire comme tu veut, mais Hans cherche toutes les temps pour des septieme generations.. ou peut etre c'est juste moi, mais en totalite je ne sais pas les chars que je vois.
Yeah I drive around the city spying on you guy....
But I prefer when it's a cute chiks driving...
Seriously when I see a 7thgen with some mods, I check to see if it's someone I know... Yesterday, when I saw a silver 4 doors with Altezzas and Hondaground stickers that was slowing down the traffic, I was begining to figure it out... and after seing the projector up front in my rear mirror... I realized who it was...
The tie-bar was to stiffen the chassis for my sway-bar. So it's not noticeable... however the sway bar made a huge difference! The tie-bar is recommanded for earlier 7thgen.
Monday morning it was ice everywhere where I live... I almost kill myself in my driveway!!! But now it's 12celcius... no more ice, no more snow...
