MONTREAL area: General Discussion
Old Jan 29, 2006
  #1561
Karumba's Avatar
Boredom causes changes ;)
No real problems connecting here Hans.. so I don't know what to tell you.
Do you have a drill Pat - or have access to me? It is really a matter of just taking off a few bolts, drilling one hole on the RSX brackets a bit larger, and then installing everything. Probably be better these days to do it inside - except maybe if the weather goes back to what it was on Saturday.
Old Jan 29, 2006
  #1562
Redviking's Avatar
Redviking is on a distinguished road
Quote from another tread on RSX seat:
1. drill motor
2. pick it up.
3. put ina bit
4. look at seat
5. grab driver
6. look at back and right side rail
7. drill hole down to right of hole
8. put in car
9. attach wires
10. look again..
11. line up holes
12. put bolt in
13. tighten bolt
14. tighten fronts
15. wipe sweat off head
16.pull up falling pants
17.walk around car
18. look at other seat
19. from back left hole
20. drill down to left
21. put seat in car
22. line up holes
23. connect wires
24. put in bolt
25. tighten bolt.
26. do front bolts
27. wipe sweat.
28. go to mcdonalds.
29. bring riley doublecheeseburger no onion
30. go back home.
31. lookl at guages
32. notice SRS light
33. scratch head
34. look at computer.
35. search for reset SRS.
36. notice riley told you and gave you link
37. clikc link
38. http://www.7thgencivic.com/forums/sh...d.php?t=155251
39. read
40. grab paper clip.
41. open under dash
42. look for yellow thing
43. bend paper clip.
44. go inside print page
45. read page.
46. do whats on page
47. SRS light off.
48. look in back seat
49 notice they dont match.
50. get mad
51. call katzkin
52. ask for 2001 civic rear seats
53. dark charcoal (NOT BLACK)
54. 470$+shipping
55. ask about door inserts
56. 40$
57. pay
58. answr door
59. sign for package
60. remove oem rears.
61. bitch and moan and complain in the 6 hours it takes to do this..
62. make sure to have some zip ties for the brackettes in seat.. instead of buying install kit for 50$
63. pull tight all corners make it look nice
64. install in car
65. take off door panels.
66. cover in epoxy
67. put leather on
68. cut edges.
69. put doors back on.
70.. whew ur done..
71. hopefully it looks good
72. ur welcome
Riley's 72 step diy to having a nice RSX interior
Old Jan 29, 2006
  #1563
Karumba's Avatar
Link in that copy/paste is off - as it shortens links.. should be: http://www.7thgencivic.com/forums/sh...d.php?t=155251
Or here's another one: http://forums.clubrsx.com/showthread.php?t=308198
Though I've tried it.. and well I can't seem to pass the sixth step as well my hands are too big
Old Jan 30, 2006
  #1564
Redviking's Avatar
04-05 Front lip
which lip do you prefer on a 04-05?
Type-R:
or Mugen:
Or Jun:
Old Jan 30, 2006
  #1565
Simpaty's Avatar
Simpaty is an unknown quantity at this point
Typer-R all the way!
Why would i have to reset the airbag after i instal the seats?
Old Jan 30, 2006
  #1566
Karumba's Avatar
Not the Mugen - doesn't flow with the current lines of the car in my opinion. The JUN would probably flow better with sideskirts that stick out as well, so I'd lean on Type-R unless you are lipping the rest of the car.
In case you trick a sensor Pat - as others have done. Though if you do everything and ensure it is done, while the chairs are off (and possibly the battery undone), then you shouldn't trip a sensor.
Old Jan 30, 2006
  #1567
Redviking's Avatar
I guess it's when the computer detect that you disconnected your SRS connector under your seat... The SRS light on your dash will go on. I remember reading that if you do it correctly you won't have a SRS light... search, you may find it.
I guess if you disconnect your battery during installation, you won't have problem
You should download the file here: http://www.megaupload.com/?d=KKDZZ12V
It's the repair manual of 2001+ civic!!! It's huge but it's a must for DIY! They explain how to remove seat, SRS, etc... They say to disconnect the battery for at least 3 minutes before removing these connectors...
Old Jan 30, 2006
  #1568
Redviking's Avatar
I'll look for a Type-R then... (this summer...)
I prefered that one too, but I was not sure if it was a huge change from the OEM bumper... but from your comments:
This is a OEM 04-05 bumber (mine )...
It will add just a small touch!
Old Jan 30, 2006
  #1569
Simpaty's Avatar
Your OEM 04-05 bumber
Type-R
I think it does a big difference!!! But it's your choice!
Old Jan 30, 2006
  #1570
Redviking's Avatar
I found one for 110$ (new, tx included!) in montreal.
Are you guy looking for a lip also? They are the same price for 01-03.
If we buy 3 lips, it's 100$ each.... come on... I know you want one !!!
They have different models also.
Old Jan 30, 2006
  #1571
Simpaty's Avatar
Ok, do they have rear TypeR lips?
Old Jan 30, 2006
  #1572
Redviking's Avatar
He just answered me that he do not... In fact, it's a guy from the CCQ that has good deal on lips....
But you may find it at around 120-130$ in other shop.
Old Jan 30, 2006
  #1573
Redviking's Avatar
I just found one brand new 01-03 TypeR lip for 95$ tx incl!
They have a 99-00 one but is 120$... but in urethane which is more flexible: better for a 04-05!
I might go pick it up... do you want the front 01-03 one?
Old Jan 30, 2006
  #1574
Simpaty's Avatar
Cool, after taking time to think... ill keep my money to buy the new suspension... ill need that $100.00
Old Jan 30, 2006
  #1575
Redviking's Avatar
Yeah... you spent a lot on the civic during these last weeks...
I hope Miss Sympaty is not jealous... usually you have to spend equal or more money on the GF than on the car!!!
Old Jan 31, 2006
  #1576
Simpaty's Avatar
i know.... but miss Simpaty(aka Angeluna on Hondaground) is going to england and france in may, so mister Simpaty can put a little more on the car this years.... But i wont go crazy, ill try to keep it low budget
Old Jan 31, 2006
  #1577
Redviking's Avatar
Oh I see... when the GF also likes car and modified car you are blessed...
For my wife, a car is made to go from A to B... that's it!
Old Jan 31, 2006
  #1578
Simpaty's Avatar
Yes, i'm bless... Every guy would need a girl like her
Plus her dad is Parts Director at Honda, so don't wonder why she likes Honda and TUNNED car
Old Feb 1, 2006
  #1579
Simpaty's Avatar
No.... i've killed the topics!!!
Old Feb 1, 2006
  #1580
Redviking's Avatar
we were quiet today....
What do you think of that: http://www.7thgencivic.com/forums/sh...d.php?t=245345
A useless performance rod on EP3 typeR?
Old Feb 2, 2006
  #1581
Redviking's Avatar
Sympaty you should start looking for other parts again... this tread is dying without you!!!
Old Feb 2, 2006
  #1582
Simpaty's Avatar
LOL.... Too much pressure on me...
What do you think make more difference in handling
1. coil ( must be for ride height / 50% confort )
2. shock (must be for you wheel to stay on the road / 50% confort )
The question is because if i try cannuk coil with either koni or kyb.... could the cannuk srew all the setup if i wahnt some thing a little sporty?
Old Feb 2, 2006
  #1583
Redviking's Avatar
These 2 components work in synergy... both of them should be good.
you are taking some risk with the cannuck... they may be super good or they can be ... According to some searches on the web, people are happy with them. But nobody here or on the CCQ recommand them... you will be the first to test them!
If you want to be 110% sure on your purchase go with the flow! Go with a set-up that people are using (here or on the CCQ). YOu should take Steve springs... eibach pro-kit! You can't go wrong! 1" drop = perfect for a 4 seasons car! He is selling them for not that much more than the cannuck...
My 2 cents!!!
Old Feb 2, 2006
  #1584
Simpaty's Avatar
I understood that point....
What is the worst that could happen with no good coil if i do take the guess of buying cannuk? Buncy ride?
Old Feb 3, 2006
  #1585
Redviking's Avatar
Sagging...
Buncy ride...
Uneven drop...
No more "quicky" on the back seat without nausea...
But, I don't think they are bad. In vancouver a lot of Car club use them. I think is just that there name is not made yet over here.
Old Feb 3, 2006
  #1586
Simpaty's Avatar
Ill try them anyway.... Anyway, even eibach do sag....
I just need to find the right shock...for a seddan
Plus that 19mm front sway bar you've said ill need with the progress bar....
I feel cheap doing a cool setup with bars and cheap suspension with cannuk and koni/kyb shock.... hope it will be good...
Old Feb 3, 2006
  #1587
Karumba's Avatar
stupid car stupid car stupid car
Enough of that .. but still fed up with it. Finally went and got my brakes checked - as I knew they were done. Figured it was my pads for sure and disks. Turns out it was my calipers on top of those
Oh well, its all fixed now and I feel happy with the upgraded disks Though that my caliper painting of the summer is wasted. Perhaps I'll paint them again.
Took off my hubcaps - as I was getting sick of them. Wow does it make a darker appearance for my car Then again, maybe it is my tiredness plus the dark rain
Oh, and I think I've decided not to go with the lip kit nor cf hood.. just too pricey if i want to work on I.C.E. this summer.
Old Feb 3, 2006
  #1588
Redviking's Avatar
Finally, I don't think you will need to change your sway bar... your set-up will be good. Like I said before, drive it first and if you want more understeer, then upgrade the front bar. (BTW, 19mm is a rear RSX bar, you have a 22mm right now, you may want to upgrade to 25.4mm )
The guy who gave me a price for the front grill also have KYB and/or Koni. I will give you his e-mail so you can ask him a quote... the website is working: http://www.directautoimport.com/index.php?&from=home He's working for a distributor of DAI products...
Old Feb 3, 2006
  #1589
Redviking's Avatar
from your first sentence I was thinking you were in a "car crisis" like gearbox!!!!
You upgraded your brake with what? Brembo?
Removing hubcaps... That's the first thing I done on my car when I got it... Maybe I'm ghetto, but I prefer the winter steely style than "Normal-family-car" hubcaps present on all Honda!!!
I.C.E. can be pricey too... do you have an idea of what you will be looking for?
Old Feb 3, 2006
  #1590
Karumba's Avatar
No, I had gearbox's situation to the extreme in the summer. I do not exactly want a repeat of that until hopefully after this summer.
KVR slotted (and black plated, but that was useless as the plating was already rubbing off in the bed-in period)
I just put the hubcaps on instinctively for the winter.. than I thought about removing them .. but I was too lazy to jack the car for those things so waited till I went back to the garage - ie today
Yes and no for what I will be looking for in ICE. Leaning on a Pioneer Premier headunit - either a P8MP or a P860MP. As for sub and amp, Probably a 12" - as I like the bassier musics Was leaning on JL stuff but I know one seller that is getting rid of his JL stuff for a reasonable price.. Though at the same time, I have a friend getting rid of his audio set-up (Pioneer P8MP, 2 X 12" JBL 1000 watt sub in box, Pioneer 800watt amp) for 750$ .. Going to try and talk with him about part-out perhaps, as I'm not thrilled with the sub or amps.. But I'll probably grab his upgraded speakers for cheap..
