View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
Old Oct 30, 2018
  #2161
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Re: How much faster with a 5 speed?
Originally Posted by sdaidoji
nope, wrong
Actually it’s factually correct. Peak HP is where you would want the engine RPM to be held at because the more aggressive gearing to hold the engine at the higher RPM where peak HP is produced more than compensates for the reduced engine torque. So even though engine torque would be less, wheel torque would be higher, and that’s what matters.
Old Oct 30, 2018
  #2162
Originally Posted by ezone
Es macht nichts
Should be asking 'Which one is less slow?'
You're probably around 17-18ish seconds for a quarter mile with either trans. May as well time it with a calendar.
I bet I could outrun my neighbor’s 1996 Mustang V6 if I had a manual trans. For that matter, I may be able to outrun it with my auto.
Old Oct 30, 2018
  #2163
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
^^^ i love comments like that
i beat one with two fat chicks driving it in my pt cruiser. i did not feel fast, but it made me smile. i felt like i won the special olympics.
check it out.. $200 car. bone stock. only "upgrade" is i threw the air filter/air box in the garbage
think you could beat my 267,000 mile pt cruiser if you had a manual trans? lol..
Old Oct 30, 2018
  #2164
Is your PT Cruiser the turbo version? If it’s the 2.0 NA, I think I could beat it with my auto. If it’s the 2.4, maybe not. I have A 2.4 in my Stratus, and that’s a good engine. It has good power throughout the RPM range, and it is durable AF.
Old Oct 30, 2018
  #2165
Just think how fast your bench race could have been if you drove a reliable 2008 Civic SI
Old Oct 30, 2018
  #2166
RobertD's Avatar
No turbo. Base model. They're all 2.4's in the USA though.
Old Oct 30, 2018
  #2167
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
But if he drove a 08 civic SI he would have to find something else to ask questions about. And then he would start tampering with it and ruin it much like most Si's, ludes, and s2000s were ruined.
Old Oct 30, 2018
  #2168
I could have sworn I saw a PT Cruiser with a 2.0, I guess not though. You’d probably outrun my Civic with an auto though. Like I said, those 2.4 engines are very good IMO.
Old Oct 30, 2018
  #2169
mcnoople's Avatar
US market all PT's were 2.4L engines. I don't consider the 2.4 to be very good. The first 6 years of production had bad head gasket issues. Ever change a water pump, t-belt, or head gasket in 1? It wasn't the best Chrysler ever made but it certainly wasn't the worst even in that same time period. 150 hp from a 2.4L is far from high output and is on par with the honda F engines which were vastly superior in durability. The 2.4 has a large potential for improvement but stock form it is an absolute dog of an engine. I think the nopi teams were getting 1200+ hp from a stroked 2.7L version of the 2.4
On a more interesting note originally the 2.0 twin cam engine that is directly related to the 2.4 was intended to be a 200 hp 8K redline monster. It would have been an engine that was designed to compete with the b18 Honda/Acura engines. But the accounting department specified that the 2.0 dual had to be available with an automatic and have a 100K service interval on the t-belt service. These 2 changes required lighter valve springs and less aggressive cam profiles, so 150ish HP instead of the easy 180-200 that was possible with proper setup.
Old Oct 30, 2018
  #2170
Interesting, thanks for the info. I didn’t think that changing the timing belt and water pump on mine was that hard. Maybe there’s more room to work on it when it’s in a Stratus. Also, I think that the engine has more than adequate power throughout the whole RPM range.
But IMO, the best thing about the 2.4 is it’s durability. The engine in my Stratus took YEARS of abuse and neglect from the previous owner, but came back to life and ran like new after a tune up, timing belt kit, some new wiring that was melted, a new coil and a few other minor parts. The previous owner literally ran it so hot that it melted wiring and plastic parts, and it had almost no oil or coolant in it because it had a leaking lower rad hose and a bad oil pan gasket. When I got on the highway to take it home after I bought it, The oil light came on and it pegged the temp gauge. But it made it home just fine after filling the oil and putting water in the radiator. When I pulled the oil pan to change the gasket, there was about 1 inch of sludge at the bottom of the pan from lack of maintenance. But despite all that abuse, it had 180 PSI of compression on all cylinders when I tested it, and it ran great until a careless friend severely overheated it and completely ruined the engine.
I don’t think very many engines (including the Honda F series that you say is so much more durable) would tolerate that much abuse and still keep going.
Old Oct 30, 2018
  #2171
mcnoople's Avatar
Sounds like it had a lot of issues...……
List the problems an engine may have in a simple column. Start checking off things if it is a common issue on that engine. examples would be
1 sludge prone
2 head gaskets
3 timing chain issues
4 ring issues
5 oil consumption
6 electronics issues
7 etc....
Make a list of everything you can think of that a engine can have go wrong with an engine. How many of those issues affect that series of engine. If none are common on the engine series then it is a good engine. Just from my quick and dirty list the Chrysler 2.4 suffers from both electronics and head gasket issues. I don't recall it being prone to sludging or burning oil. My list would rule out D series honda engines due to head gaskets and K series engines due to timing chain issues and oil consumption issues in some generations of the engines. None of the issues on my list are common on the F engines. Main issue they have is they start to leak oil when they get a LOT of miles or age.
Old Oct 30, 2018
  #2172
As expected from rubber gaskets and seals sooner or later, regardless of the engine manufacturer
Old Oct 30, 2018
  #2173
I don’t have a switch anymore, I now have a VTEC ECU, which controls VTEC automatically.
so, what was wrong then?
Old Oct 30, 2018
  #2174
He lost the race against 2 fat chicks in a PT Cruiser
Old Oct 31, 2018
  #2175
1 sludge prone
2 head gaskets
4 ring issues
5 oil consumption
7 etc....
I agree that the D series engines are junk. IMO the B and F series engines were pretty reliable though. I have heard about head gasket issues with the 2.4, but I have not personally experienced that problem. Not to say it can’t happen. And the only electrical problems mine had was caused by a melted cam sensor, as well as some melted engine wiring and plastic parts. All caused by the previous owner overheating it.
Old Oct 31, 2018
  #2176
mcnoople's Avatar
I didn't say the D engine is junk. Just that it has issues which keep me from calling it great.
The Honda B engine also has very common important problems as well. They were prone to valve issues. Either the valves stretched or the seat recessed. The end result is that if the valves are not adjusted properly and regularly they end up with burnt valves and misfire problems. That is a common thing on the B20 CRV engine which is by far the most common of the B engines.
Engine electrical wiring on Chrysler engines that melt is not limited to overheated engines. The insulation they used on the wiring doesn't survive normal engine bay temperatures. It has been an on going issue on their engines for 20+ years and was still a problem at least as recently as 2013. I had to change out an valley wire harness on a 2013 jeep G Cherokee for this issue, all the insulation had turned flaky and crumbled off allowing wires to short together. That style of short can potentially destroy an engine computer. I would call that a serious problem.
The Chrysler 2.0/2.4 head gasket issues applied to ALL engines made from the start of production in 1994 to around 2000/01. Some owners had to have their head gaskets replaced multiple times in that time period. That is a long time to continue making a flawed head gasket.
Honestly any time the cylinder head has to come off of an engine it makes me question the quality of the engine. If it is common for those engines to need a head pulled, then I don't consider that engine to be a great engine.
Old Oct 31, 2018
  #2177
I never meant to say that every single 2.4 ever made was problem free, I can only speak from my experience, which is that the engine is powerful, reliable, and durable. Just my experience with that engine.
Old Nov 1, 2018
  #2178
Wankenstein's Avatar
I'm pretty sure most all-aluminum engines built in the 90's and early 2000's had head gasket issues compared to prior-to steel engines. The D-series was most likely one of the better four cylinder engines compared to American and European engines in the same era. Still see a lot of 6th and 7th gens on the road today.
Old Nov 5, 2018
  #2179
Any problems with an ELD bypass?
So I am wondering if there would be any problems with an ELD bypass. I don’t like the operation of the ELD because it drains my battery since it’s an AGM. I also don’t like that the performance of my accessories noticeably suffers from the lower voltage. So I am wondering if it would be bad for anything to just unplug the ELD so the alternator stays in high output mode all the time. As far as I know, besides maybe losing a fraction of a percent on gas mileage, it’s not harmful to keep the alternator in high output mode constantly. Am I correct? Thanks.
Old Nov 5, 2018
  #2180
Re: EPS conversion pro’s and con’s?
How much power would EPS free up?
Old Nov 5, 2018
  #2181
Colin42's Avatar
not enough to make it worthwhile
Old Nov 5, 2018
  #2182
I heard that it’s like a 5 HP gain from idle to redline.
Old Nov 5, 2018
  #2183
5hp? I doubt that while traveling in a straight line. The pump more or less freewheels when there's no hydraulic load, it simply circulates the fluid in a loop.
It might take 5hp when you have the steering cranked and held at full lock forcing the pump to build maximum pressure, but that's pretty damn brief.
I'll suggest you first cut your power steering belt off and find out exactly how much performance you gain before making any real decisions about converting
Old Nov 5, 2018
  #2184
So the pump doesn’t build any pressure while cruising? I thought it was always creating pressure. If it’s not building any pressure unless the wheel is turned it’s probably not even using 1 HP.
Old Nov 5, 2018
  #2185
RobertD's Avatar
i was working on these turds. they about eight cars on the team at any given time, they all have power steering. if they could get an extra 5hp deleting it, they would.
Old Nov 5, 2018
  #2186
Study up on how power steering works
Old Nov 5, 2018
  #2187
Hell, study up on any simple hydraulic system.
Most will be designed so the pump doesn't generate pressure until there's a demand for it. Hydraulic control valves bypass fluid flow at rest.
Old Nov 5, 2018
  #2188
If that’s the case I would think it wouldn’t even take 1 HP to run the pump.
Old Nov 5, 2018
  #2189
Are you catching on yet?
Old Nov 5, 2018
  #2190
Re: Any problems with an ELD bypass?
Fault code for ELD will set.
