View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
#2221
The legs in the public bathroom stall
Re: Trans slow to upshift
There is an available analog throttle modulator that can help your car not bounce the rev limiter. Does your car have one installed. Do you need a link to such a unit or maybe a picture?
#2222
Received 1,442 Likes
Rep Power: 338 Re: Trans slow to upshift
my long gone 01 LX auto did the same when going uphill at the mountains between TN/GA. normal
#2223
Install new trans that is correct for the car
Install new PCM that is correct for the car
profit
profit
#2224
Install an on/off switch for your transmission right next to the Vtec switch you installed. Also, change the jandy valve you installed for the water (heater) outlet valve from a manual to electronic...lol.
#2228
what was the problem with the ECU anyway? You told us it would not work to program the keys, have not seem since then any feedback about what the problem was.
#2231
Another wiring issue hidden below?
#2232
#2233
#2234
I think D17 is contemplating his next power upgrade, which is cutting a hole in the driver's side floorboard so he can use his feet Fred Flintstone style.
#2235
Wheels spin while engine is running
Something I noticed a long time ago is that my car spins the tires if the front of the car is lifted off the ground and the engine is running, no matter where the shifter is. It spins the tires in neutral or park. The speedometer reads about 20 at idle, and if engine RPM is increased, the wheels spin faster. No one I asked has had an answer to why it does this. The dealer told me that this is normal. This is clearly NOT normal since the engine is not supposed to be connected to the wheels when the trans is not in gear. Anyone know why it does this? Thanks.
#2236
Rep Power: 338 Re: Wheels spin while engine is running
it's normal. in manual trans as well
#2238
Re: Why do D17’s perform so poorly?
I don’t understand why the D17A2 performs so poorly compared to older D16’s. Can you help me understand? They have a similar compression ratio, slightly larger displacement, and they don’t have major design differences that I am aware of. Even with a cam, header, intake, intake manifold, and exhaust upgrade, they still perform poorly compared to older D series engines. My best guess is that maybe the stock ECU is holding it back. Any ideas? Thanks.
Many have mentioned that even parts places and dealers are confused.
Sometimes they seem to list the same parts for vtec and vtec-e for example. Sure, some parts are going to be the same...most, in fact. But there still seems to be confusion about the vtec engines and so my opinion is that performance on many of these vehicles suffers because there is the potential for there to be vtec-e engines in civics that are supposed to be vtec and vice-versa....
are we getting the correct parts?
Anyway....I have had several Hondas and one was a factory EX vtec bought new by my father, passed on to me...came factory with 1.7 vtec....but when I tore the engine down I found that, instead of being vtec it was the vtec-e.....a big difference.
He complained for years that his honda didn't run as strong as my brother's ex...both were ex...and now i know why.
Brother's vehicle had the 5 lobe per cylinder camshaft (2 exhaust, 2 regular intake, 1 vtec high lift and duration lobe) and my fathers car, even though even the vin says its the same exact engine, same exact car, same year, has a vtec-e arrangement, which has 2 exhaust, 2 intake arrangement.
1 of these intake lobes is barely even a lobe, and if you look at it, it appears to be round until you really examine it. This intake lobe lifts the valves during normal operation and hooks up to a larger valve during hi rpm.
This is the designed-for-fuel efficiency-engine. This is not what we purchased.
This engine essentially operates as a 3 valve per cylinder engine most of the time and the very small camshaft lobe is for fuel economy.
My point:::: some of us are running around on vtec-e engines instead of real vtec.....a travesty of justice??!! Not really...just something to think about if your (especially 2001 to 2005) civic isn't running like you think it should.
My other 2003 ex runs like a bat out of he'll...it has a 5 speed and my other one doesn't, but that's not it...it just runs better, by far! I've had the valve cover off...it has the real vtec camshaft and rocker arrangement...(5 lobes per cylinder and 2 exhaust, 2 regular intake, and 1 vtec hi lift and duration lobe). Im just sayin'.......
Last edited by sdaidoji; 12-02-2018 at 04:16 PM. Reason: separatesd senteces for easier reading...
#2239
Rep Power: 338 Re: Why do D17’s perform so poorly?
what country are you in?
All US EX and Canada Si (majority of members are from US/Canada) are VTEC-E - D17A2 engine - for the 7th gen (01-05 cars), except for the Si (SiR in Canada) that uses the K20A3 engines.
The K-series have the actual original concept VTEC. VTEC-E is the economy version, more torque in Low-Mid RPM with 3 valves instead of 4
sadly, the original pictures were lost due to photobucket, but there are some explanations here:
https://www.civicforums.com/forums/1...-e-system.html
https://www.civicforums.com/forums/1...on-inside.html
Ccol19,
on separate note, just check how old the thread is before replying
If you are actually adding info to the thread, we don't mind, but sometimes the thread could be very old
Ccol19,
#2240
#2241
not completely familiar, was the A6 then actual original VTEC? I remember that Max Tierney dropped one in his civic.
That was one made for high mileage, if i remember correctly?
#2242
D17A6 is vtec-E lean burn
Also camshaft is different from A1 and A2
https://en.wikipedia.org/wiki/Honda_D_engine#D17A6
#2243
thanks! I did not look much into the HX model
#2244
Wheel bearing replacement
So after 240K, the OEM front wheel bearings need to be replaced. I am wondering if I can replace just the bearings, or if I need to replace the whole wheel hub assembly. Also, what brand is good for bearings? I remember hearing that NSK made the OEM wheel bearings, Is that correct? Thanks.
#2245
Rep Power: 338 Re: Wheel bearing replacement
you will need a press to push the hub and then the bearings out of the hub.
use correct spacers
there were some threads around about it.
#2247
Bearings only unless there's a reason it needs more parts.
Maybe the snap rings depending on corrosion.
Axle nuts? Cotter pins? Alignment
I use a whizz wheel to slice and then crack the stuck race off of the hub.
#2249
#2250
