View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
Old Jan 22, 2018
  #691
Re: Help! Strut bolt broke off!
Oxy-Acetylene torch set, cutoff wheel, sawzall?
Old Jan 22, 2018
  #692
Wankenstein's Avatar
Re: K24 vs. K20?
Originally Posted by D17VTECPOWER
I guess what I was asking is if the K24 could accelerate the car any faster since it has more torque.
K20a2
Bore: 86mm
Stroke: 86mm
Deck height: 212mm
Rod length: 139mm
Intake Valve: 35.15mm
Exhaust Valve: 30.15mm
Compression Ratio: 11:1
Displacement: 1998cc
Power (bhp@rpm): 200@7000
Torque (ft/lbs@rpm): 142@6000
K24
Bore: 87mm
Stroke: 99mm
Compression Ratio: 9.6:1
Displacement: 2354cc
Power (bhp@rpm): 160@6000
Torque (ft/lbs@rpm): 162@3600
Yes..the K24 will accelerate faster. 20 more ft/lbs at almost half the rpms.
IMO the K24 will be more fun to drive..quicker acceleration without the need for high revs. Better for cornering, slaloming, off the line in short distances.
Old Jan 23, 2018
  #693
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Re: K24 vs. K20?
Originally Posted by Megalodong
K20a2
Bore: 86mm
Stroke: 86mm
Deck height: 212mm
Rod length: 139mm
K24
Bore: 87mm
Stroke: 99mm
Ok thanks, that’s what I thought. The K24 CRV or Accord motor also is much easier to find in a junkyard than an RSX or SI K20 motor, and parts are probably cheaper. However, the engine is also probably larger, so it would be harder to work on. Fuel consumption would probably also be higher on the K24, so I am not sure which one would be better.
Old Jan 23, 2018
  #694
dsm482's Avatar
dsm482 has a spectacular aura aboutdsm482 has a spectacular aura about
I never had a problem taking them off)
Old Jan 24, 2018
  #695
This car also lived in Chicago for the first 9 years of its life.
Old Jan 24, 2018
  #696
Re: RSX sway bars?
Moog are effectively OEM replacements. EDIT: I stand corrected. I guess the moog ones are a hair beefier than stock, but not as beefy as the ones pictured above.
I agree that they are not as beefy as the ones you had, but they look very solid to me. Here is a side by side comparison of the OEM sway bar link compared to the $25 Moog. If you know of better ones, especially for less than $25 each, please let me know.
Old Jan 24, 2018
  #697
that will do a number down there...
a year and half in Quebec sure did on mine...
Old Jan 24, 2018
  #698
Re: RSX sway bars?
moog are the best stock replacement.
the greasing zerk are great
Old Jan 25, 2018
  #699
Do you solder or use crimp connectors?
So I am just wondering if you usually solder wires together or use crimp connectors. I always solder wires on other people’s cars, but sometimes I use crimp connectors on my cars. In my opinion, soldering wires together is far superior to crimp connections, both in reliability and performance. I believe that a soldered connection will have less voltage drop and will be more reliable. However, I sometimes use crimp connectors on my cars as a temporary fix, but I solder the wires when I have time. What do you do?
Old Jan 25, 2018
  #700
2001-2005 Civic BMXA automatic transmission
I am going to be changing my 2005 Civic transmission with a JDM SLXA transmission, so I won’t need the BMXA. It is perfectly functional, and it has always had its fluid changed on time. It has never been rebuilt and all the parts are original. The transmission will include the torque converter, starter and all sensors and solenoids. The transmission has 231K miles on it, but I am only changing it as a preventative measure because the mileage is so high, but it works perfectly fine and has never gave me any trouble. I am listing it for $225, but I may lower the price if it doesn’t sell or if shipping costs are high. I am located around Memphis, so if you are this area, you can come over and see it working while it is still in the car if you would like. Let me know if you are interested!
Old Jan 25, 2018
  #701
Colin42's Avatar
Re: 2001-2005 Civic BMXA automatic transmission
I'll let this stay for now but:
Welcome to the CivicForums.com Market Place Buy, Sell & Trade Forums!!
To ensure this forum continues to be a useful and enjoyable area for all members there are a few rules strictly enforced by the mod staff. If for any reason you have a question or need clarification on these rules please message the moderators: MindBomber or tbohar. Exceptions may be made to some rules if prior permission is obtained.
All threads must include a price! Whether you’re looking to buy, sell or trade an item, a price must be listed. If you need a part, post a price range your willing to spend; If you’re selling a part, you must post a price. OBO (or best offer) is acceptable. For trades, include what you’re willing to trade for.
Pictures are Required! Very few people are willing to buy an item from a stranger off the internet without seeing a picture of it first, so to save people having to ask for pictures, one must be included in the first post of the thread. For your sales benefit: include in the picture a piece of paper with your username, the date and civicforums written on it.
If your location is not specified on your profile, it must be included in your thread Location effects shipping costs (unless the seller has specified a "shipped" price or a set shipping fee). Also allows for members to meet up so the potential local buyer may physically inspect the goods prior to purchase.
I understand it's still in the car but you could get a couple pictures from above and below and maybe a dipstick shot?
And throw in a zip code for shipping calculations
Good luck!
Old Jan 25, 2018
  #702
CraigW's Avatar
Re: Do you solder or use crimp connectors?
Solder is the absolute best & western union splice
Old Jan 25, 2018
  #703
Good luck!
Sorry, I didn’t know the rules. This is my first time selling something here. Thanks for telling me. I’ll upload a few pictures when I get home.
Old Jan 25, 2018
  #704
Depends®
I use either depending on the situation, and agree on 'western union splice' when possible. (sometimes I just don't have much wire length to work with LOL)
Recommend glue lined heat shrink tubing to seal it all up if it's outside the cabin
Old Jan 25, 2018
  #705
Have you studied all about the problems that begin with swapping one trans type to another?
Old Jan 26, 2018
  #706
Evergreen engine rebuild kit review
About 1 year ago, I replaced the engine in my Civic with a junkyard D17A2 that I rebuilt. I did not have a lot of money, so I bought this Evergreen rebuild kit:
Amazon Amazon
I also bought an Evergreen oil pump. I had no problems with the rebuild kit yet. All the parts seemed high quality, and the gaskets don't leak. The oil pump, however, did have a minor flaw. The minor flaw with the oil pump is that it did not have a timing mark. This wasn't a problem for me, because I just set cylinder 1 to TDC and used a chisel to mark the oil pump where the timing mark on the crank sprocket pointed to. I have had no problems with this engine for 7,000 miles since I rebuilt it a year ago, and I used it to pull a 2500 pound trailer for over 500 miles when I moved. I have also floored it many times, taking the RPM almost to the rev limiter. Nothing blew up yet, and it doesn't burn oil. So I would recommend this rebuild kit to anyone who needs to rebuild their engine and doesn't have a lot of money to spend, or anyone who wants a quality rebuild kit for a great price. I can't speak for how well these parts would hold up under boost, but at least NA, this rebuild kit works great. If you have any questions, feel free to ask.
Old Jan 26, 2018
  #707
Looking for disc brakes
I am looking for a rear disc brake setup off of a 2002 or 2003 EP3 Civic SI. I am looking for a rear disc brake setup with the wheel hubs, brake calipers and rotors. I am in the Memphis area, and how much I can pay for the setup depends on how much shipping is and what condition the parts are in. Thanks!
Old Jan 26, 2018
  #708
Re: Evergreen engine rebuild kit review
moved thread to Parts and Products review section (Nothing major, just to right place )
Old Jan 26, 2018
  #709
Re: Looking for disc brakes
any of them close? (Mursfreesboro is more to my side...)
http://www.car-part.com/cgi-bin/search.cgi
Year
Part
Model Description Part
Grade Stock# US
Price Dealer Info
2003
Brake, Rear(Rotor/Drum)
Honda Civic 3-04,2.0 A 05037 $20 Highway 70 Auto Parts USA-TN(Kingston-Springs) Request_Quote 615-952-9370 Request_Insurance_Quote
2003
Honda Civic 4-03,DOHC SI A 05032 $Call Highway 70 Auto Parts USA-TN(Kingston-Springs) Request_Quote 615-952-9370 Request_Insurance_Quote
2003
2003
Honda Civic 2.0,MT5SP,Si 150224 $20 KW Cooks Auto Salvage USA-MS(Biloxi) Request_Quote 1-228-392-4995 / 1-800-726-0647 Request_Insurance_Quote
2003
2003
Honda Civic 2.0L (DOHC, disc)-0MI 16O04265 $Call Manus Road Auto Salvage USA-TN(Murfreesboro) Request_Quote 615-848-7000 / 615-848-7009 Request_Insurance_Quote
2003
2002
Honda Civic 05-02,2.0 MHN232 $Call G and S Import Automotive USA-MS(Jackson) E-mail 601-352-9118 / 800-300-9065
Year
Part
Grade Stock# US
Price Dealer Info
Old Jan 26, 2018
  #710
Thank you, and sorry for putting this thread in the wrong section.
Old Jan 26, 2018
  #711
like said, nothing major, no issues at all
Old Jan 28, 2018
  #712
GolNat's Avatar
Prelude Owner
I always solder (western union) and heat shrink. I like to follow the below guidelines when possible. I will splice though when soldering is not plausible.
https://workmanship.nasa.gov/lib/ins...20Splices.html
Old Jan 28, 2018
  #713
Hondabond or gasket?
I need to remove my cast aluminium oil pan to JB weld the crack because I ran over a coffee can on the highway and slightly cracked the side of it. So my question is if I should use Hondabond to make the gasket, or if I should use a gasket. IIRC, the aluminium oil pan uses Hondabond instead of a gasket from the factory, but please correct me if I am wrong. Thanks!
PS- Yes, I know Hondabond is overpriced, but I took advantage of an eBay pricing error and got 12 tubes of it for $0.97 each, so it's what I have.
Old Jan 28, 2018
  #714
Re: Hondabond or gasket?
D17a1 uses a gasket. D17a2 uses an rtv gasket. Every time I pulled the oil pan on my -a2, I bought some permatex grey rtv gasket stuff from AutoZone
Old Jan 29, 2018
  #715
[img]https://cimg4.ibsrv.net/gimg/www.civicforums.com-vbulletin/450x450/80-6925621e_a1bc_4591_b3e2_684be186cca9_1_e58ca6013e1 c5b1d2adca1d9bfd8176a_b8d816dc42b848f6ec21b3998267 90aaaaaea792.jpeg[/img
That's what I thought. Thanks.
Old Jan 29, 2018
  #716
So I can use Hondabond to make the gasket?
Old Jan 29, 2018
  #717
Steel vs cast aluminum oil pan- Poll
I am just curious if you guys prefer steel or aluminum oil pans, and why. I personally prefer aluminum for oil pans because it is lighter and it dissipates heat better, but what do you prefer, and why?
Old Jan 29, 2018
  #718
Re: K24 vs. K20?
2) inherently, yes
I heard that the K24 gets better mileage because it doesn’t have to rev as high. Is that true?
Old Jan 29, 2018
  #719
Where should I put my IAT?
I made my 2005 Civic a custom cold air intake when I put the Y8 intake manifold on it. I currently have the IAT about 1 inch from where the silicone connector attaches to the throttle body. I just cut a hole in the silicone adapter and sealed around the sensor with silicone. A friend pointed out that the sensor is being heated up by the throttle body, and that the IAT being hot causes the ECU to retard ignition timing and lean out the A/F ratio. He said that I should move the IAT sensor to the end of the intake pipe where the air filter connects so it reads the temp of the air instead of the throttle body. Does that make any sense? It makes sense to me, but I am not sure. What do you think?
Old Jan 29, 2018
  #720
Is coasting in neutral bad for the transmission?
Sometimes I coast in neutral when going down hills or when slowing down to save fuel. I have heard people say that coasting in neutral is harmful to the transmission, but some people say that coasting in neutral is okay as long as the engine is running. Who is correct? I know that coasting in neutral can be dangerous, but I only coast in neutral when doing so is safe. Thanks.
