View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
Old Jan 11, 2018
  #541
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
Re: Why do D17’s perform so poorly?
forgot to mention i had 265k miles on mine...
Old Jan 11, 2018
  #542
Re: My baby gets new shoes!
in my signature
https://www.civicforums.com/forums/4...questions.html
Old Jan 11, 2018
  #543
Originally Posted by piano55man
4) cams are easy to pull for tech
lol!
Old Jan 12, 2018
  #544
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Originally Posted by sdaidoji
Oh I see. My KYB struts may not be happy about this. Also, do I need a camber kit? I did a 1.5 inch drop on the front and back and there seems to be no significant camber.
Old Jan 12, 2018
  #545
camber correction required is usually rear - too much negative camber in rear means low front grip in the corners. Car will push.
therefore, if you really like cornering, recommend reducing rear camber.
if you really like cornering, then add front camber bolts to increase front negative camber.
before all that, recommend finding a RSX rear anti-roll bar and slapping it in (very easy).
RSX-S is even beefier. better
Heck, i removed my front anti-roll bar even.
Today is a good day to go under the car to swap it, right? (I guess youn already have the snow there )
Old Jan 12, 2018
  #546
Isn't the RSX rear sway bar 19MM instead of the stock 12MM? Couldn't I use an EP3 sway bar too? Would I notice any improvement in handling? Also, why would I take off the front sway bar instead of upgrading it? As for the camber, what reasonably priced front and rear camber kit would you recommend? As I understand it, the front camber kit is just cam bolts for the front struts, but the rear camber kit is a different upper control arm. Am I correct? Thanks for your help.
Old Jan 12, 2018
  #547
don't know what bar is in EP3. RSX is 19 or 21 (s-type)
FWD cars problem is understeer (push). even with smaller rear camber, progress rear anti-roll bar (24mm) and higher front camber, no front anti-roll bar, my car still pushes.
I don't know what is around now, i put the ingalls front and skunk2 rear, but there are more suppliers now - shop around
just be careful with no-name stuff, you don't want suspension parts to suddenly go on you.
Old Jan 12, 2018
  #548
Thanks. Just curious- If the front sway bar makes handling worse, why does Honda spend the money putting it on? Thanks.
Old Jan 12, 2018
  #549
Drivers get anxious when car rolls more.
It's uncomfortable, sure, but faster without the bar in front.
When I softened front shocks all the way down, I thought I was slower at an autoX event, but clock said 1sec faster in 70sec course.
Old Jan 12, 2018
  #550
Thanks for explaining. What do you think of strut bars?
Old Jan 12, 2018
  #551
piano55man's Avatar
lol!
Let me rephrase myself....
Access to the cams are easily accessible.
check the lobes of the cam by setting a dial indicator on the rockers. when the valve is closed zero it in. then turn over the engine.
If the cam lobes are appear to be illegal, then you take the cam out/heads off for a second check.
You can pull the heads off...without taking off the lower timing belt cover...
of course you need to have ARP head studs.
Old Jan 12, 2018
  #552
they improve steering feel. you will know what the tires are doing. maybe will improve your confidence due to that effect. no performance improvements, except for knowing what the tires are really doing.
Old Jan 12, 2018
  #553
no need to explain yourself :P
Old Jan 12, 2018
  #554
Is upgrading the cam illegal? I just installed a Crower Stage 1.
Old Jan 12, 2018
  #555
I'm not racing it lol. I just want it to handle well.
Old Jan 12, 2018
  #556
What is the disadvantage to upgrading the rear sway bar?
Old Jan 12, 2018
  #557
what do you mean disadvantage?
Old Jan 12, 2018
  #558
he was talking about making a spec class.
Old Jan 12, 2018
  #559
What would potential negative effects could a bigger rear sway bar cause?
Old Jan 12, 2018
  #560
Slumpertcivic's Avatar
Pretty sure only spec class you could actually get started for the 7th gen would be a demolition derby..
Old Jan 12, 2018
  #561
piano55man's Avatar
lmao
Old Jan 12, 2018
  #562
lol, slumpert!
Old Jan 12, 2018
  #563
again, what disadvantages?
maybe the fact you will need new poly bushings
only thing comes to mind is if it gets to the 1" level, it could rip the chassis - that why it have reinforced frame for the progress bar - but again, what disadvantages?
Old Jan 12, 2018
  #564
Why did Honda not do it do it the factory besides increased cost? Does it increase NVH or something?
Old Jan 12, 2018
  #565
why so angry at honda?
most drivers would not like an oversteering car. most can only handle cars that go straight when overcooking a corner. oversteering cars will spin, getting out of control to average drivers. common knowledge about average cars.
a mustang is quite understeering also for the safety of average drivers.
Old Jan 12, 2018
  #566
So if I install a bigger rear sway bar, the car would be more likely to oversteer? I thought you said your car still understeers with the larger sway bar? Sorry, I'm confused.
Old Jan 12, 2018
  #567
I'm not angry at Honda, I was just wondering if cost was the only reason that they used such a small sway bar.
Old Jan 12, 2018
  #568
Colin42's Avatar
because its designed to be a grocery getter, not a performance car
Old Jan 12, 2018
  #569
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
That is what I was gonna say also, the rear sway from an rsx type s. Beefier for better cornering.
As for Honda putting such a small sway bar to begin with, lets just be glad that there IS one on there lol. Also grocery getters don't need to be sport tuned like colin said, honda didn't have a reason to put a bigger one on there.
Old Jan 12, 2018
  #570
dsm482's Avatar
dsm482 has a spectacular aura aboutdsm482 has a spectacular aura about
buy what standards poorer... more weight almost same hp and tq an performance..
by reliability , better if not the same.. i just clocked 320000 miles on original engine and tranny.. I got all records of all OEM parts lasted.. Still original tensioner TB, original water pump, original radioator, original tranny, .. besides the tranny loosing reverse, no other parts have given up.. Its all about how you maintane your vehicle.. this car could go another 100,000 k miles the way it is. not bad for a dx model and econo box..
