View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
Old Jan 9, 2018
  #511
Wankenstein's Avatar
Re: Transmission differences
Here: http://www.7thgenhonda.com/forum/sho...d.php?t=125921
Here: https://www.google.com/search?num=50....0.oSAL4jnxbKw
Old Jan 9, 2018
  #512
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
What are the gear ratios?
Old Jan 9, 2018
  #513
Damn dude..you want me to hold your pee-pee too while you go wee-wee?
You can Google search just as well as I can.
Old Jan 9, 2018
  #514
Slumpertcivic's Avatar
Ohh. didn,t know this was a full service forum...
Old Jan 10, 2018
  #515
I tried searching and couldn't find anything.
Old Jan 10, 2018
  #516
USDM: Reply #4 in this thread: https://www.civicforums.com/forums/1...ar-ratios.html
JDM: Call or email this company and ask for gear ratios: https://www.jspecauto.com/jdm-engine...-Transmissions
Old Jan 10, 2018
  #517
I emailed them and asked. I will reply with what they say. Thank you for your help.
Old Jan 10, 2018
  #518
They responded. Here is what they said:
"Hi Avery,
Thank you for contacting us. I regret, we do not have that info. We sell JDM transmissions and apparently they don't have the over drive gear. So, it will rev a few hundred higher rpm than your current one.
Sam"
Any other ideas?
Old Jan 10, 2018
  #519
Are polyurethane bushings worth it?
This is something that I have searched for for hours and I couldn't find a general opinion on polyurethane bushings except that they last forever. I have heard opinions varying from they are terrible and will cause problems to people saying that they are a great upgrade for the money. What is true? My experience with polyurethane bushings is I installed polyurethane motor mount inserts, which I like a lot. The engine moves a lot less and I feel that torque steer and throttle response is better. However, to be fair, the factory mounts were worn out. I also installed polyurethane sway bar bushings in the front and back. I didn't notice much improvement, but, to be fair, the factory bushings were in reasonably good shape. The other bushings I changed are the front control arm bushings. The front control arm bushings needed to be changed anyway, so I used polyurethane ones. I noticed that the car quit clunking and squeaking over bumps, and the steering felt more precise and responsive. I am not sure if the handling improvement was from the bushings being new, or if it was from installing polyurethane bushings.I am considering converting the bushings on my back suspension to polyurethane too, but I won't convert to polyurethane until I need to change the bushings if it would be a waste of time and money. So what do you think of polyurethane bushings?
Old Jan 10, 2018
  #520
Thank you for contacting us. I regret, we do not have that info. We sell JDM transmissions and apparently they don't have the over drive gear. So, it will rev a few hundred higher rpm than your current one.Any other ideas?
Consider doing an auto to manual swap...but that can get pricey.
JDM sellers claim they import low mileage engines/transmission but there's no way to confirm either. Much debate about it online. Ultimately, it's your call and it's a tough one because it's hard to find a low mileage USDM transmission on a 13+ year old car so, obviously the fear of used replacement part is inherent.
Old Jan 10, 2018
  #521
I have a SLXA transmission sitting in the corner waiting to go in. I will lock the transmission in gears 2, 3 and 4 and see what the MPH reads at 5000 RPM in each gear with the car on jack stands to eliminate torque converter slip as a variable before and after swapping and post the results for anyone else wondering. That won't give me the exact gear ratios, but it will give me an idea of how different they are between the 2 transmissions.
Old Jan 10, 2018
  #522
Re: Are polyurethane bushings worth it?
BUSHINGS:
From what I've read (haven't owned any poly's) with poly bushings it seems that most complaints are about squeaking..which can usually be solved with lithium or graphite grease. They are supposed to last a (car's) lifetime where rubber wears. As far performance when poly and rubber is new it's probably negligible
MOTOR MOUNTS:
Increased Durometer equals increased NVH. I've installed a 70 durometer poly transmission (nearest firewall) mount (only) on a manual transmission '07 Mazda 3 (2.3L) and it reduced wheel hop very noticeably. For the first three months the dash and steering wheel would vibrate harshly but, from the forth month on it wasn't an issue.
For me the one poly mount was enough and I think more poly mounts would have made it unbearable as far as vibration and noise.
Old Jan 10, 2018
  #523
Hope it goes well. Might as well change the rear main seal while it's out.
Old Jan 10, 2018
  #524
Thanks. I would change the rear main seal, but I just rebuilt the engine less than a year ago, so all the gaskets are already pretty new. Great advice though.
Old Jan 10, 2018
  #525
you will need to grease them once a year at the least so that they will not squeak. Some greases every 6 months because of that.
they get firmer, but remember that the ones where they need to rotate, they will rotate. no binding to the sleeve, so they will move freely.
Old Jan 10, 2018
  #526
https://www.civicforums.com/forums/2...fications.html
http://ecomodder.com/forum/showthrea...ios-26279.html
https://teamdelsol.com/honda-transmi...tios-d-series/
http://www.jbcarpages.com/honda/civic/2004/specs/
i did not look details, but you can find a lot of info in wikipedia as well.
https://en.wikipedia.org/wiki/List_o..._transmissions
Old Jan 10, 2018
  #527
BUSHINGS:
silicone grease or gtfo for poly
Old Jan 11, 2018
  #528
Fuel system upgrade before and after
My 2005 Civic has had a stock fuel system until now. I recently upgraded the fuel system on my slightly modified D17A2. The upgrades that I did included upgrading the wiring going to the fuel pump, as well as running a 3/8 inch fuel line to replace the factory one. I tested the fuel pressure and fuel pump voltage at idle At idle with a new Denso fuel pump and filter, the fuel pressure was 46 PSI. The fuel pump voltage was 13.2 volts, about 1 volt lower than battery voltage. When I snapped the throttle, fuel pressure dropped to about 41 PSI for a split second, a 5 PSI drop. But at a steady 4000 RPM, the pressure went back to 46 PSI. But after I upgraded the fuel pump wiring to 12 gauge, the fuel pump voltage was 14.1 volts, 0.9 volts higher. Fuel pressure readings were still 46 PSI at a steady RPM, but fuel pressure stayed 1 PSI higher at 42 PSI when I snap the throttle wide open. Not a huge difference, but it wasn’t worse. I then upgraded the fuel line to 3/8 inch. The fuel pressure was still 46 PSI at idle and a steady 4000 RPM, but when I snap the throttle wide open, the pressure only momentarily drops to 45 PSI, 3 PSI higher. So after upgrading the fuel line and fuel pump wiring, the fuel pressure stays 4 PSI higher when I quickly snap the throttle wide open. I would say that I saw a pretty good improvement for just upgrading wires and the fuel line. After I drove the car after the upgrade, it unsurprisingly didn’t feel any faster. However, when I quickly floor it, it does seem to respond a little quicker. Let me repeat: It did NOT make more power. I suspect that the improvement that I saw in the fuel pressure was mostly because the larger line that I installed stores more fuel for a more steady supply, not because it flows better. I suspect that a heavily modified engine, like one with a turbo, would see a bigger improvement. I think that it’s important to do these 2 upgrades together for the maximum benefit. But anyways, pretty cool results that I thought were worth sharing.
EDIT: I frogot to mention that the fuel pressure gauge seemed less bouncy and more consistent with these upgrades, which can’t be a bad thing.
Old Jan 11, 2018
  #529
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Re: My baby gets new shoes!
Did you get the rebate on them? They have good rebates on tires right now
Old Jan 11, 2018
  #530
Yup, I got a $70 rebate.
Old Jan 11, 2018
  #531
GusBuz's Avatar
Well I'm sure anything above Barum will be an improvement! What suspension mods do you have on your civic or what mods will you be doing to it?
Old Jan 11, 2018
  #532
Everything I did to it is under “About Me” in my profile. Not sure what other suspension mods to do. Any ideas?
Old Jan 11, 2018
  #533
Re: Fuel system upgrade before and after
"but dyno"
Good work...thanks for sharing that.
Old Jan 11, 2018
  #534
"but dyno"
I highly doubt that I would see any HP improvement, but like I said, the car seemed to respond slightly quicker to quickly flooring it. Not a huge difference, but noticeable. I didn’t notice any changes driving normally though.
Old Jan 11, 2018
  #535
"but dyno"
BUTT with two "t"s
Kaleco Auto has it! <--linkyclick
Old Jan 11, 2018
  #536
god speed springs?
think on tokiko blues (HP) shocks. you might need them soon
Old Jan 11, 2018
  #537
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
Re: Why do D17’s perform so poorly?
I personally think the gen 7 civics with the d17's would make a great spec racing class...
1) cars are inexpensive
2) d17 are reliable
3) nothing really adds hp to the d17 other than a turbo, super charger, or nos...so outlaw that stuff
4) cams are easy to pull for tech
5) with evenly matched hp setups, the racing would come down to the driver....
Old Jan 11, 2018
  #538
Originally Posted by sdaidoji
god speed springs?
What do you mean? These are the springs I used:
Amazon Amazon
Old Jan 11, 2018
  #539
2) d17 are reliable
Really? My experiences with them would suggest otherwise.
Old Jan 11, 2018
  #540
piano55man's Avatar
I've had no issues with mine...(besides losing a rod bearing due to 10lbs of boost...)or the one i built for a friend.
OEM gaskets, correct torque specs, and tolerances go a long way.
