My EM2 - EX SE Build
Old Jan 21, 2013
  #211
Kennykid2002's Avatar
Kenny the Ricer
Re: My EM2 - EX SE Build
When I installed them, startups were noticeably better.
Wiring is the same for our cars.
will provide them for ya, pretty simple to do.
Old Jan 25, 2013
  #212
Kenny the Ricer
DIY: Big 3 Ground Wire Upgrade
Here are the wires that are done for me. (Black is new, red is my old kit)
Since the first few ones are the ones where you make the most mistakes, I made mine first to get the hang of it first
I made all the cables the same length, saving me some extra time from measuring.
There should be enough length for all 3 connections.
I soldered all the terminals on, to ensure connection and that it wont come loose.
Yours will be finished probably tomorrow and sent out Monday.
The battery Neg terminal hasn't arrived yet.
The wires were semi-decent quality (They didn't send me the exact ones I bought), but the terminals are good quality.
Heres the DIY for you to follow, I don't know where my stock wiring went, so you should be able to figure it out from the pix, pretty simple.
Note:
If you have stock radio, make sure to have radio code before removing any battery cables.
If you have aftermarket radio, you're going to have to reset all EQ and station settings.
1. Remove the two bolts holding down the stock engine to chassis wire, replace the wire, and bolt it back down in place.
2. Remove the stock Neg battery terminal, then remove these two bolts holding the battery Neg to chassis and tranny to chassis cable. (Stock is one piece of wire)
This connection is under the fuse box, you may have to remove the stock/aftermarket air filter to access it.
Optional Step:
Then, you're going to want to sand down the connection points to the metal, to ensure the best connection.
3. Put the new wires in place of the old ones, and bolt up the tranny, and chassis bolts.
4. Attach the Neg terminal back on the battery, and tighten it up.
5. Make sure all your electronics work. Enjoy
Old Jan 26, 2013
  #213
Kenny the Ricer
Terminal finally showed up today, your set is all ready.
Will be sent out priority mail Monday, probably expect it Wednesday/Thursday.
Old Jan 26, 2013
  #214
krudmuphin's Avatar
Nice. Thanks man!
So 2 of the 3 wires are used in the battery terminal / fender-tranny connections? They share the connection point on the fender well?
Old Jan 26, 2013
  #215
Kenny the Ricer
Originally Posted by krudmuphin
Nice. Thanks man!
No problem.
It isn't really the fender, but yes, they share the same connection point.
Once you remove the old wiring, you should be able to figure it out.
Or just take a look in your engine bay, should be pretty straight forward.
Old Jan 31, 2013
  #216
s4boost's Avatar
s4boost should not be trusted
i really like those wheels. look good on that color
Old Feb 5, 2013
  #217
Kenny the Ricer
Wheres the updates? :P
Old Feb 5, 2013
  #218
krudmuphin's Avatar
such a narcissist, aren't you... lol
Old Feb 5, 2013
  #219
Kenny the Ricer
lol
Old Feb 6, 2013
  #220
Tragedy's Avatar
skate or die
those things are huge! Pics after install.
Old Feb 7, 2013
  #221
Kenny the Ricer
See, im not the only one :P
Old Feb 12, 2013
  #222
krudmuphin's Avatar
So Kenny can get his self-gratification....
Desperately need to clean the engine bay...
BTW, my positive terminal lead was so corroded, I had to shear the end off to make the connection. Good thing I got these cables when I did.
ID:	84677   Click image for larger version
Old Feb 12, 2013
  #223
Kenny the Ricer
Lol. Sweet.
I was slightly worried the engine to chassis was the slightest bit short.
Old Feb 13, 2013
  #224
Tragedy's Avatar
skate or die
Good stuff
Old Feb 14, 2013
  #225
Kenny the Ricer
Notice any better startups?
Old Feb 14, 2013
  #226
krudmuphin's Avatar
Not really, no, but it hasn't been very cold out lately.
Old Feb 22, 2013
  #227
krudmuphin's Avatar
Opinions on O.Z. Ultraleggera?
I'm thinking about getting these next summer when my wallet is feeling generous enough...
Leaning towards gunmetal or bronze at the moment, but silver is also nice.
Old Feb 22, 2013
  #228
enigmatic jc's Avatar
enigmatic jc is an unknown quantity at this point
i like the silver
Old Feb 22, 2013
  #229
Kenny the Ricer
I like em all, but im leaning more towards gunmetal or silver
Old Feb 25, 2013
  #230
Max91's Avatar
Max91 is an unknown quantity at this point
Yeah silver on that blue would really set it off (looker). Gunmetal would look like a sleeper (low profile).
Not to change the subject...@Kenny, I did my 4k Royal Purple change and I could not believe how clean that engine was. Ready to run this change up to 10k!
Old Feb 25, 2013
  #231
Kenny the Ricer
Nice,
Why did you only run it 4k?
I ran it up to 12k and it was still pretty clean.
Old Mar 4, 2013
  #232
krudmuphin's Avatar
OK, i decided I really really really want to get factory HFP SS-7 (Split 7-spoke 16") rims but I haven't the slightest clue where to find them.
I've searched online at accessory dealers, checked craigslist and ebay, and dug though page after page on forums to find some. But to no avail.
I guess we can't all have what we want :P
Do you guys know where I can find a set of these?
I posted in the WTB section hoping someone would be my savior.
Old Mar 5, 2013
  #233
Maayhemm's Avatar
Maayhemm is an unknown quantity at this point
http://montreal.kijiji.ca/c-cars-veh...AdIdZ461890785
are these what you wanted
Old Mar 5, 2013
  #234
Kenny the Ricer
Aren't those the Honda Fit stock wheels?
Honda Part No. 42700TK6A91
A few links to get you started
They come in Chrome and silver, the chrome costs twice as much.
http://www.finishlinewheels.com/HOND...09/A-63990U20/
http://www.hubcaphaven.com/mm5/merch...egory_Code=820
Old Mar 5, 2013
  #235
Kenny the Ricer
Sorry, did more digging, those aren't the ones you wanted.
Here you go:
http://www.finishlinewheels.com/HOND...05/A-63881U20/
http://oemwheels4less.com/store.php?...EY-ALY63881U20
Old Mar 5, 2013
  #236
krudmuphin's Avatar
God!!! How did you find that so easily?!
I spent hours searching for those yesterday
Those things are kinda pricey, huh...
Old Mar 5, 2013
  #237
Kenny the Ricer
Not too hard once you know which car they come from.
They aren't terribly expensive for OEM rims.
$700 or so for a set...New remember that.
Old Mar 5, 2013
  #238
foedoemoehoe's Avatar
foedoemoehoe is an unknown quantity at this point
Been reading the thread , its lookin real good and i think the HFP SS-7 would look really good with what you have got going on.
doing some practice with photoshop tuning cars and stuff so i gave yours a shot
Old Mar 5, 2013
  #239
krudmuphin's Avatar
Awesome, i did the same thing earlier using paint, lol
And this was the result.
(I also lowered the body another 1/2" to simulate how low I can go on 16x6.5 rims and different tires, mwahahaha!!)
Old Mar 5, 2013
  #240
Kenny the Ricer
I'm still for white feathers. Just my opinion.
