View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
Old Dec 21, 2018
  #2311
Colin42's Avatar
Re: How much faster with a 5 speed?
Originally Posted by mcnoople
The owners manual is flat out wrong. The car doesn't have a limited diff from the factory. I don't recall if 2006 SI had them the first year or not, but NO US market civics had it prior to the 06 generation of civics.
If you truly want limited slip google phrases such as "torsen limited slip" or "Quaife" which is a company that makes lifetime warranty torque biasing differentials. You do NOT have limited slip on a factory built 1.7 civic. Regardless of anything else you may or may not find on the internet the underlined sentence is a true statement.
Once again if you want a faster car that is also reliable buy the 2.0 SI that hasn't been molested and then leave it alone.
Old Dec 21, 2018
  #2312
Re: Alternator vs. no alternator MPG test
What was the point in all this?
You may have gained a smidgen by running without a charging system, but the battery now has to be recharged and that requires not only energy from somewhere, but extra additional effort.
Net=LOSS
Old Dec 21, 2018
  #2313
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Net=LOSS
The point of this was just as a test to see how much of of a difference the alternator makes.
Old Dec 21, 2018
  #2314
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
So I now change my suggestion from you should find and buy a used 2006-2011 civic SI that has never been molested. I now suggest that if you want more HP, better acceleration, better brakes, better pretty much everything a car should do the answer is simple. Buy this https://automobiles.honda.com/tools/...tcolorcode=EXT
You will have to plug it in at night, but it sounds like you are already doing that with your civic anyways. If that doesn't tickle your fancy you can get the accord hybrid or insight hybrid instead. They both (but especially the accord) will absolutely walk all over the performance of the 1.7 civics.
Old Dec 21, 2018
  #2315
I reconnected the alternator. As I said, I have no intention of daily driving my car with no alternator, it was only a test.
Old Dec 21, 2018
  #2316
mcnoople's Avatar
The problem isn't the fact that you tried/tested. The problem is that you are dicking with every thing on your car trying to achieve some pie in the sky fantasy of what you think your car can achieve. All the things you have changed or want to change or just ask about changing. These are all things that have already been designed.
If MPG is your goal you are very limited by your choice of cars.
If performance is your goal you are very limited by your choice of cars
If maximum rally race handling is your goal you are very limited by your choice of cars.
If driving comfort is your goal you are very limited by your choice of cars.
At what point will you be happy? What is the end goal? What are you trying to achieve?
If you want a car that handles better, uses less fuel, brakes better, more reliable, etc...…...the answer is simple buy a car that already has all of the those features by design.
Personally I rarely question the starting point of peoples car hobbies. But people should have realistic expectations OR be willing to go to extreme efforts to reach unrealistic expectations.
Old Dec 21, 2018
  #2317
That's reasonable, thanks for clarifying. To answer your question, I was not really trying to achieve anything by performing this test other than gaining knowledge. I have no intention of daily driving with no alternator, I just wanted to know how significant the load of the alternator is, and apparently it's pretty significant.
Old Dec 21, 2018
  #2318
mcnoople's Avatar
That can NOT be answered. It varies greatly. Having increased electrical loads will affect it. Headlights? Heater? Radio? Wipers? Those require the charging system to work. And another thing that adds a huge amount of load on the alternator is having to charge a discharged battery.
If you want to do random testing I think a much more useful and valid test would be to see how much parasitic energy usage your car has when running with a total loss charging system. This would require a remote display ammeter that you could view and record from the passenger compartment. How many amps does it take to drive under normal conditions with no alternator output? I would expect a number around 10 amps with absolute NO nonessential loads, meaning no heater or lights. How long would a 10 amp load take to drain your battery below the minimum voltage required to keep the PCM awake. Personally I would consider that info to be much more useful. I suspect the PCM can stay alive down to around 8 volts, but at that point the fuel pump likely won't be able to generate enough pressure to run the engine loaded.
So if you want to drive around with no alternator with an ammeter and voltmeter attached to see at what point the car turns off I would be interested in hearing the results of that. Having an ammeter would also give you good appreciation on how much energy is used by your car under which conditions. Here is an example of quality ammeter from a reputable vendor that usually has good prices. https://www.waytekwire.com/item/7803...LED-Meter-AMP/
Blue sea systems is a company that makes quality electrical components for boats/ships and have a solid rep for quality.
Old Dec 21, 2018
  #2319
Let's be clear- I have NO intention of driving around with no alternator on a daily basis. My idea of a good time is not getting stranded and quickly ruining my battery. With that out of the way...
I checked amp draw with the engine idling and no accessories on a while ago, it's around 9 amps. Not sure about when driving, but that would be easy enough to check. I know from when my alternator died in the middle of nowhere years ago that this car behaves normally down to around 10 volts, but at around 9.5 volts, it starts to become slightly unhappy. At around 9 volts, it becomes very unhappy. And at around 8.5 volts, it completely dies.
I am planning to check amp draw of each load individually when my amp clamp comes, and I will post the results. That could also be helpful for people to have a baseline of what each component should draw when functioning properly.
And since my battery is 55 amp hours, presuming a steady 10 amp draw, I could theoretically drive for 5.5 hours with no alternator.
Old Dec 22, 2018
  #2320
Re: Torque converter question
Here are the videos. But to address 2 things that I will probably hear about: First, the engine was actually warmed up during these pulls, the gauge is stuck. Second, those cigarettes are my mom's, not mine.
It seems that locked is actually quicker. Do you agree? I tried timing 60-70 locked vs unlocked. I couldn't really get consistent results, but locked seemed to be slightly quicker. You are welcome to try timing 60-70 in the videos if you want to though.
File Type: mov
File Type: mov
Old Dec 23, 2018
  #2321
I think that I should try the same test from a lower RPM, like a 40-50 2nd gear pull. Maybe at 4000 RPM torque multiplication would improve acceleration. I am thinking that at such a high RPM, the torque converter didn't have enough slippage to matter much. Maybe the torque converter didn't even have enough slippage to multiply torque at such a high RPM.
Old Dec 24, 2018
  #2322
Re: WTF is P1713?
So I think I figured this out. I had a parts store scan it to see if their scanner would give a definition, and it says "D3 Position Switch Circuit Malfunction". At first, I was confused since the range sensor was working correctly. So I decided to do some research on the Honda Stream transmission. I found that the pattern is P R N D D3 2, which is the same as mine. But then I realized a critical difference: To select D3, the shifter is moved to the left rather than being pulled down. I looked up a parts diagram on jp-carparts.com, and I found that rather than using the range sensor, the Honda Stream has a separate switch to detect when the shifter is in D3, which is actuated when the shifter is pushed to the left, as you can see from this picture.
So I am thinking that the PCM is detecting an issue with the D3 switch because it is not activated when the shifter is in 2, which is in the left position. That is the only explanation that makes sense to me.
Old Dec 24, 2018
  #2323
Slumpertcivic's Avatar
Re: WTF is P1713?
Sounds reasonable, maybe just need to figure which pin needs to be grounded before you go into D2.
A microswitch and some hot glue and you might be in business.
Old Dec 25, 2018
  #2324
Re: WTF is P1713?
Great idea, thanks! For that matter, I might even be able use the D3 position on the range sensor to ground those pins so D3 works. I have a question though- Is it possible that the pins that the D3 switch connects to are on the multiplex control unit of that car, or are they definitely on the PCM itself? Thank you and merry Christmas!
Old Dec 25, 2018
  #2325
Re: WTF is P1713?
[img]blob:https://www.civicforums.com/3aaf3583-425a-475b-af32-a0c8e59b957d[/img]
Old Dec 25, 2018
  #2326
Re: WTF is P1713?
That link doesn't work. But back to my question- Are the pins that need to be shorted for D3 to work likely on the PCM itself, or could the D3 switch connect to the multiplex control unit, which tells the PCM that the shifter is in D3? Thanks
Old Dec 25, 2018
  #2327
Re: WTF is P1713?
On normal PCM it looks like it has a D3 pin and a D3/D pin as well as R,P/N, and D2 pins on the actual PCM directly.
Maybe the single D3 pin need to be held while in D2 for that PCM to not complain on the “Stream ECU”. But it easily could be a different pin your harness is not even wired for.
Old Dec 25, 2018
  #2328
Re: WTF is P1713?
Makes sense, thanks. But what I am asking is if the Stream's D3 switch that senses when the shifter is pushed to the left could be connected to the multiplex control unit, or if it would have to be connected directly to the PCM. I was reading someone describing the operation of the D3 switch on a Civic EU1, which has the same shifter design. What they said is that the D3 switch tells the multiplex control unit when the shifter is in D3, and then the multiplex control unit tells the PCM to lock out 4th gear. Is that possible? I would think that the switch would tell the PCM directly. Thanks
Old Dec 26, 2018
  #2329
Re: Can transmission oil be too cold?
I noticed that my trans runs very cool in the winter. The oil cooling pipes on the transmission barely get warm, even after a 30 minute drive on the highway. I think I should get a thermostat on the transmission oil cooling lines so the oil stays at a reasonable temperature. Do you agree?
https://derale.com/products/fluid-co...s/13011-detail
Old Dec 26, 2018
  #2330
Re: I need a header for my D17A2
Well I ended up installing the stock header that came with my relatively new to me JDM D17A. RIP D17A2, you served me well for years. I immediately noticed that the low end torque is a LOT better with the stock header. The car feels a lot lighter when taking off from a stop, and it doesn't need to downshift as often when I need to accelerate. Power from idle to 4000 RPM is dramatically improved. I also really like that this header fits nicely. The Amazon header stuck out the front of the engine so far that it was about 1 inch from the cooling fan, and there was no way to get the heat shield on it.
The bad news is that I think it feels a bit less powerful from 5000 RPM to redline, although not a huge difference. Oh well
Old Dec 27, 2018
  #2331
there are civics running for decades in Canada.
Want to compare temps with them?
Old Dec 27, 2018
  #2332
Colin42's Avatar
This
It's fine.
Old Dec 27, 2018
  #2333
No. How long do you think their cars last?
Old Dec 27, 2018
  #2334
Colin42's Avatar
A long time as long as they don't rust out. Girlfriend's '99 has 395,000 kms on it, with the original auto trans, runs and drives perfectly fine.
Stop messing with the car and trying to "improve" it
Old Dec 27, 2018
  #2335
Wow, that's impressive!
Old Dec 27, 2018
  #2336
so you finally starting to listen to us?stock design is not bad in the EX
Old Dec 27, 2018
  #2337
Yes.
Old Dec 27, 2018
  #2338
Yes.
after more than a year, good, finally.
But though luck, more than a year turning a deaf ear to sound advice, causing chaos in the forums for no reason other than self satisfaction.
Sorry, but too late. Really. More than a year is just too much patience. Nope.
Good luck.
Old Dec 31, 2018
  #2339
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
Good luck.
Really? I have read most of his threads and while some of the questions may be a little out there, at least there is some thought behind them.
Have you ever heard the old saying "There are no stupid questions, only stupid answers."?
Old Dec 31, 2018
  #2340
Wankenstein's Avatar
That old saying is just "stupid"...lol
The problem with D17 was his tendency to create more problems than solve. Of course, it was his own problems he created with his own car or theories but, when offered advice he would basically ignore it and try to prove he was reinvening the wheel and that may qualify as stupid?
