Only starts with crank sensor UNPLUGGED, 2005 civic ex
Old Jul 30, 2024
Kyled09's Avatar
Kyled09 is an unknown quantity at this point
I had just recently finished up a valve job on the d17a2 head, put everything back together started car ran codes and had crank sensor code which I then realized that it was broken and not plugged in ( free hanging in bay)due to my timing belt breaking and hitting it. So I replaced the sensor with an aftermarket one and no start whatsoever just cranks. I figured that the sensor was bad or bad connection so I had another oem sensor off a donor civic same gen, and plugged it in and same thing just cranks. I unplugged the sensor completely and car starts up every time. I am stumped and would appreciate any help!
Old Jul 30, 2024
Re: Only starts with crank sensor UNPLUGGED, 2005 civic ex
get a new denso or NTK sensor.
Hondas hate aftermarket sensors.
Old Jul 30, 2024
Kyled09's Avatar
Sdaidoji, I have tried even with a new denso sensor it is doing the same thing
Old Jul 30, 2024
hunh, did it damage wires when the belt broke?
Old Jul 30, 2024
Kyled09's Avatar
The wires and connectors seem to be fine, I’m not to sure but my logic is the wires and plug should be fine because when I install the sensor and have it plugged in it keeps cranking and will not start but as soon as I unplug it it will start, so am I just getting a false reading on the crank because of the sensor. I’m not sure
Old Jul 30, 2024
Originally Posted by Kyled09
I’m not sure
same here...
all cases we see were aftermarket sensors that the ECU did not like...
Old Jul 30, 2024
Kyled09's Avatar
Im going to try and get a better look at the wires, I have an oem denso sensor on it right now that I know works fine. I’m gonna see what I can do
Old Jul 30, 2024
BrotatoChip's Avatar
Super Moderator
I cannot find the thread now, but at one point someone found some of the teeth broken off the crankshaft timing gear. The teeth that the crankshaft sensor reads.
Old Jul 30, 2024
Kyled09's Avatar
I had thought that it reads where it sits in the block it doesn’t seem like it reads the little teeth
Old Jul 30, 2024
Super Moderator
The sensor reads the teeth sticking out from the crankshaft timing belt pulley. I wish I could find that thread. Maybe @sdaidoji remembers?
Old Jul 30, 2024
Kyled09's Avatar
I
thought it read through the small hole, I will check out my teeth and see if so I have another gear for it
Old Jul 31, 2024
Two cases?
https://www.civicforums.com/forums/3...-solved-2.html
https://www.civicforums.com/forums/3...rt-solved.html
I keep a log in here
https://www.civicforums.com/forums/3...your-case.html
Old Jul 31, 2024
Super Moderator
I searched for a good 30 minutes and couldn't find them. I knew you kept the weird ones in a post but couldn't find it either
DeepEddyDirt
Electrical
Aug 8, 2022 08:10 AM
honda.lioness
Sep 17, 2017 04:19 PM
IROKGEN7
38
Feb 18, 2016 07:27 PM
mttpalmer
Apr 11, 2012 03:55 PM
xRiCeBoYx
Engine start problems
71
Apr 9, 2011 01:40 PM
